Availability of Work Instructions for Standards Room Personnel
Andrews
Availability of work instructions
The standards room personnel , performing calibration, does not have the work instruction for calibration in his room.But he is aware of the existence of such a work instruction and that it is available with the Manager , who is in the next block.He even goes to the extent of taking the auditor to the Manager and is able to locate the instruction.
Is this a non-conformance because the Manager reasons that the existing standards room personnel has 25 years of experience in this field and therefore does not need an instruction.When asked why he prepared the instruction in the first place he explains that this was done so that any new person who joins can quickly understand.
Angela-2007
Completely my opinion, but I don't think that I would write that as a non-conformance. Standard states that instructions should be available at the time needed without disruption to the job being performed. The key word is "should" not "shall". I might inquire about a training record to prove training.
Raffy
Even though he has 25years experience, the instruction should be documented so that you have a basis to show on the auditors. :evidence:
Raffy
E
energy
Nooooooo! You think?
Randy said:
Watch it Raffy!! Jim is trying to back you into a corner.:eek:
Woe is me. Again? Here's another ambush in progress: Sure sneaks up on ya real quiet like. Reckon you gots to sleep with one eye open. :p
Jim Wade said:
Hello again, Dave
Your top-level diagram does not describe process interaction just sequence; as you made clear, "the interaction, in terms of inputs, outputs and controls, are defined in greater detail in the next level of documentation".
Just to be clear: are the documents you showed (proc22r4.doc & proc007r3.doc) examples of that next level?
rgds Jim
:biglaugh: :ko: :smokin:
work instructions
Are you saying, Raffy, that all jobs need written work instructions?
Okay, I take this on. For the most part the answer is YES!!!!
Let me explain. There are different types of work instructions. I need to have shoulder surgery. Will my surgeon need a work instruction? YES! The work instruction might not tell her “how” to cut into my body, but the work instruction better tell her who the patient is, which shoulder she needs to cut and what she is doing in there.
Too many times we think of work instructions as a step-by-step task guide. Most work instructions are closer to routers, control plans, etc. A work instruction for a receptionist might be the list of phone extensions. It doesn’t tell the receptionist how to work the phone, but give direction on what numbers to transfer calls to. Even here, there is a work instruction that tells us how to reply to a post.
So in a sense, all jobs do need work instructions.
If you know your stuff, even ambushes (not that this was an ambush) can be safely negotiated.
Angela-2007
So if you classify the extension listing as a work instruction, then would you control it? Seems a little extensive.
Angela
Angela-2007
D.B. would you take that as far as to have a procedure for changing a toner cartridge in the copier?
Angela
Control of phone listings
Not really, Angela. Remember the extent of control is up to you. It might be possible for the receptionist himself (herself) to approve the listing. At any rate, every company I've worked for has had a rev level on the phone listing (normally by date). People and numbers change, the phone list must change accordingly. Does this have to be on the master list? There is no requirement for a master list (never was).
As far as the toner cartridge, do you need a procedure? Probably not. Do you need a work instruction? Every copier I’ve seen has the work instruction on the door panel. And once again, if you don’t need a work instruction, then you don’t need one. That’s why I said “for the most part”.
In Andrew’s original post, I’m sure the calibration tech had some sort of work instruction. How else would he know what gauge to calibrate when? Once again it all depends on what you call a work instruction. The control is up to you.
R Food Safety - Availability of free manuals and instructions Food Safety - ISO 22000, HACCP (21 CFR 120) 8
Watchcat Impact of MDR on Availability of Medical Devices in EU EU Medical Device Regulations 5
M FDA News USFDA draft guidance – Principles of Premarket Pathways for Combination Products; Draft Guidance for Industry; Availability Medical Device and FDA Regulations and Standards News 0
D AEA (Aerospace Experience Auditor) Challenges - Finding availability of AEA for witness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B TS 16949 Auditor Availability and Registrar Scheduling Delays Registrars and Notified Bodies 4
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Would my AS 9110 certificate lapse due to non availability of auditors ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Availability of Lean Manufacturing Training The Woodlands TX Training - Internal, External, Online and Distance Learning 4
M Voluntary Action by Human Operator Influences Availability? Reliability Analysis - Predictions, Testing and Standards 2
Q Availability Calculation for monitoring Overall Equipment Efficiency Manufacturing and Related Processes 2
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
S Clarification on TS 16949 Clause 8.2.3.1 - "... availability..." IATF 16949 - Automotive Quality Systems Standard 15
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
D ISO 9001 - Responsibilities of Top Management in ensuring availability of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Availability for Contract Quality Writing/Templates Work Career and Occupation Discussions 2
J Availability of Prints During Assembly - Pneumatic staple and fastener tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Available (Availability), Uptime and EPE in VSM (Value Stream Mapping) Lean in Manufacturing and Service Industries 3
J AS 9100 Lead Auditor Course availability other than USA Training - Internal, External, Online and Distance Learning 2
X Definition Availability - Measurability - Manufacturing Process Capability - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
D Definition OEE definition - Overall Equipment Effectiveness - Definition of A (Availability) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
S 8.2.3.1 Reliability, Maintainability and Availability - How to satisfy requirement? Reliability Analysis - Predictions, Testing and Standards 4
C On-Site Contracted Services - Development and availability of key MRO items Service Industry Specific Topics 2
Marc TL9000 (Telecommunications) - Availability of the Standard TL 9000 Telecommunications Standard and QuEST 8
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
U Intended Users in IFU (Instructions for Use) EU Medical Device Regulations 5
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
M User manual / instructions for use for class II device always required? Medical Device and FDA Regulations and Standards News 3
L MDR - Information in the instructions for use - clausole 23.4.(z) EU Medical Device Regulations 2
S ISO 18223-2 Temperature symbol in the Legend table in the Instructions for Use Other ISO and International Standards and European Regulations 4
S Providing IFU (Instructions for Use) in multiple languages EU Medical Device Regulations 0
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
Z IFU (Instructions for Use) Symbol - 7010:M002 - can it be in black? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
N Electronic Instructions for use (eIFU) EU Medical Device Regulations 2
Marc Elsmar Xenforo Software Instructions #2 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
Marc Elsmar Xenforo Software Instructions #1 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
M Batch record supersedes all other instructions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Updating class I device IFU with instructions to use class II cleared device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
K IATF 16949 Cl. 8.5.1.2 - Requirements of Work Instructions and Documents IATF 16949 - Automotive Quality Systems Standard 2
J Work Instructions - We have approx 1,000 work instructions from over the years Document Control Systems, Procedures, Forms and Templates 8
Ajit Basrur Incoming Inspection for Instructions for Use (IFU) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Product Instructions (IFU) - Placement Requirements - ISO 13485:2003/2016 Other ISO and International Standards and European Regulations 2
C Manufacturing Process Work Instructions - Format Manufacturing and Related Processes 4
