Average and standard deviation of Cumulative Data
If i calculate average of cumulative data or std seviation for a period (for example 2 year complaints ratio every month) is it proper or not? can u make some comments?
Thank you
What analysis are you doing? in other words what do you want to understand form the data? let's start there as that is what drives the correct analysis.
Hi Bev D
Some friend from the company want to decide new kpı value from last year monthy kpı values which are calculated cumulative. They took average and std. dev. of the monthly kpı values to calculate new years target as average - 1 std dev.
John Predmore
A word of caution: The average of 24 monthly ratios is not mathematically equal to the ratio of the cumulative total numerator divided by the cumulative total denominator, unless the denominator for every month is of equal size. You can convince yourself the average of the ratios is not equal to the ratio of the averages (except in limited cases) by experimenting with columns of data in an electronic spreadsheet. When you speak of averaging standard deviations, you must be even more cautious of the calculations and what they represent.
If you ask which calculation is correct, you have to do what BevD explained, decide which analysis you desire to complete.
It would actually be more helpful if you could post the actual monthly data with both numerators and denominators as well as the average and SD calculations. Manipulated data hides many sins...
Mike S.
Happy to be Alive
Bev and John are right, IMO.
Also, does anyone even know if the process described by the kpi is in control or not?
On what basis did someone select the new target as prior average - 1 std dev? That sounds awfully arbitrary. Is anything being done to help make that goal achievable?
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
Proud Liberal How long does your company take to close an 8D on average? Problem Solving, Root Cause Fault and Failure Analysis 12
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
J0anne GCC Submissions - Average review time for SGH qualification files Other Medical Device Regulations World-Wide 10
K Average height of adults by sex by state Other Medical Device and Orthopedic Related Topics 10
M What is the difference between X Bar - R Charts and Average Chart? Statistical Analysis Tools, Techniques and SPC 7
M Average Run Length (Student Question) Statistical Analysis Tools, Techniques and SPC 3
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
G Improve final GR&R value by taking average of more measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
K Can I do an average measurement values for a sample? Statistical Analysis Tools, Techniques and SPC 1
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Counting the Average Times of Alarms in a Process using Minitab Using Minitab Software 5
Q How to determine the average baseline for the following data in SPC Quality Tools, Improvement and Analysis 3
D Rounding Numbers - Adding numbers in Excel - I want the average Excel .xls Spreadsheet Templates and Tools 3
T Bias & Linearity Study - How to calculate the P value for the Average Bias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
G Product Returns are above average for Labeling Problems Quality Manager and Management Related Issues 4
R GR&R (Gage R&R) - Average Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B XbarR or EMWA (Expontionally Weighted Moving Average) or MA Chart - Which to Use Statistical Analysis Tools, Techniques and SPC 6
R What is the Sigma Level of the Average Company? Six Sigma 11
Stijloor Toyota drags down new-vehicle quality average World News 9
P ISO 27001 Controls - Industry average % IEC 27001 - Information Security Management Systems (ISMS) 3
Stijloor The ARMA (Autoregressive Moving Average) Chart Statistical Analysis Tools, Techniques and SPC 6
D Influence of the Coverage Factor - Worksheets based on the Average and Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B To IMR or Moving Average chart now that's the question! Statistical Analysis Tools, Techniques and SPC 11
M Inferences from Distribution? (Average per hour/the average pay of the staff) Six Sigma 2
O Average Life Cycle Duration for a large number of medical equipment types Other Medical Device and Orthopedic Related Topics 2
Randy US Average Hourly Employee Cost Career and Occupation Discussions 3
K Calculating Control Limits in Average and Range Charts Statistical Analysis Tools, Techniques and SPC 3
C What does the average employee need to know about the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Control Chart - Minimum point & average insulation thickness for Automotive Wires Statistical Analysis Tools, Techniques and SPC 9
DanteCaspian 5S Workplace Average for those that score 5 S Lean in Manufacturing and Service Industries 5
T Monitoring a shift of the average in an SPC chart Statistical Analysis Tools, Techniques and SPC 11
T What is Average Run Length & Average Production Length when used in Control Charts? Statistical Analysis Tools, Techniques and SPC 4
C Is Parts/Process Average Testing SPC by Another Name? Statistical Analysis Tools, Techniques and SPC 3
D Average fill label - "e" Mark, probably a UK specific requirement. Manufacturing and Related Processes 8
D Queuing System - Calculating Average Arrival Rate λ Statistical Analysis Tools, Techniques and SPC 3
W Advice on the best way to approach a double moving average using Minitab 15 Using Minitab Software 3
K Average Salary for Quality Personnel? Career and Occupation Discussions 12
E Moving Range Average Calculation in Excel (in a single cell only). Excel .xls Spreadsheet Templates and Tools 9
S Average Cost of ISO 13485 Registration in US ISO 13485:2016 - Medical Device Quality Management Systems 10
D How to Measure a Diameter - Average or Maximum/Minimum? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
D When to Create a New Baseline Average for a Process Statistical Analysis Tools, Techniques and SPC 2
D Stable process but the average baseline is unacceptable Statistical Analysis Tools, Techniques and SPC 8
N Average range of measurement system NDC number Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
