Hi Friends,
I am a process validation engineer in a medical device manufacturing company and we are in the process of validating the Tyvek pouch peel strength requirements in accordance with the revised standard BS EN 868-5:2018.
Here are the key guidelines from the relevant stndards:
the instructions in 1b and 2a are contradictory as they both cannot be met.
Please help me understand the interpretation / intent of this requirement.
At the same time is it possible to access the documents which will explain the intent behind this requirement...discussions which the technical committee had while finalising this requirement.
Thanks in advance,
Player64
- BS EN 868-5:2018 states that:
- Follow ASTM F88/F88M.
- Record the average force over the middle of measured profile by discarding 10% on each side of curve.
- ASTM F88/88M states that:
- The initial ramp-up from zero to the force required to peel is not indicative of seal strength so it should not be included in the calculation of average strength.
- The amount of data discarded on each end must be same for all tests within any set of comparisons of average seal strength.
- Section 9.8.1 – Follow machine manufacturer’s instructions to select the desired algorithm.
Thanks in advance,
Player64
