Background of Annex X section 1.1d of MDD 93/42/EEC
Marcelo
#21
From the Oxford dictionaries:
well established [adjective]
Firmly established, especially because of a long existence.
I was trying to say that there's no definition in the regulations that enable a clear, technical judgement.
There are many views for this exception. But I do not find a convincible one so far.
If there were clear, technical definitions in the regulations, the view would be more clear. Right now, it too open for interpretation. Even the MEDDEV does not help because it still do not say how we can "deem not appropriate to use clinical data".
Marcelo
#22
Marcelo,
I understand that you are trying to use IVD devices / IVD regulation to clarify a point, but I think it creates a distraction rather than clarifies. This thread originated from an MDD clause, relating the (non-IVD) medical devices. IVD is a different world with its own use patterns and its own regulations (be it the IVDD or the IVDR).
Yeah, it was only to making a point, and I'm also mostly talking about non-IVD here, too.
I also think that non-IVD diagnostic devices should be treated more similarly to therapeutic devices than to IVD devices (and the regulation seems to "think" the same)
Agreed, but I think the problem is when we begin talking about the benefit and the link of benefit with clinical data, and maybe the real problem is exactly the old, "legacy" devices.
Ronen E
Problem Solver
Moderator
#23
The only problem with the explanation "intended for well established and lower-risk devices" (and I've heard this many times) is that it's not technical and really not actionable.
So, can I use it for all class I devices? What is "well established"?
That's why I prefer an explanation related to the technical aspects of clinical performance and clinical safety. This way I can create a sound rationale.
The human mind can rationalise in both a deductive and an inductive way.
What I mean to say is that when you (or an auditor, or anyone) sees a "well established, low risk device", you know it from miles. A dry, non-sterile cotton tip is an example.
Can all class I devices be exempted? Probably not. But ones that apply the same design for over 30 years, and are still common (ie didn't cause a lot of trouble and weren't yet replaced by something much better) - in other words, are "well-established" and "low risk" - probably can. And in many cases there will also be well-established published standards to cover such devices anyway, so it all fits together nicely.
Does that eliminate grey area completely? Probably not, but that's the business. I think it's still quite workable.
Ronen E
Problem Solver
Moderator
#24
FWIW, 2007/47/EC (the 2007 amendment of the MDD) states in its preamble ("whereas section"):
(8) In the light of technical innovation and the development of initiatives at the international level it is necessary to enhance the provisions on clinical evaluation, including clarification that clinical data is generally required for all devices regardless of classification and the possibility to centralise data on clinical investigations in the European databank.
I couldn't find in that section more specific clues as to why the clause subject of this thread was introduced or what was the authors' intention in doing so.
Marcelo
#25
Can all class I devices be exempted? Probably not. But ones that apply the same design for over 30 years, and are still common (ie didn't cause a lot of trouble and weren't yet replaced by something much better) - in other words, are "well-established" and "low risk", probably can. And in many cases there will also be well-established published standards to cover such devices anyway, so it all fits together nicely.
Again, I agree.
And as always, I think we are talking most the same thing, but maybe my point is not clear.
I do not disagree that the exception can be applied to low risk,well established devices (even if we do not have a definition and have to use common sense).
My problem is, does it applied "only" to low risk, well established devices? If not, how can I justify not using clinical data? And that's when i tried to rationalize the benefit part. And as I mentioned above, a lot of manufacturers do not have clinical data. Do they need it, meaning, do they need to begin doing clinical investigations? This is what is not clear in either the regulation or the MEDEV.
Ronen E
Problem Solver
Moderator
#26
My problem is, do it applied "only" to low risk, well established devices?
In my opinion, yes. It makes decision making easier, although it disappoints some manufacturers.
For discussion's sake - by showing that the device's nature & design are such that there's no reasonable doubt about it's safety (including unacceptable side effects) and performance, that would need proof from an actual clinical setting. I realise that this probably narrows down the applicability to simple, low-risk devices, but I think that this was the actual intent. If the device works in a complicated, harder-to-predict way, how can you show that it's safe and effective other than through actual, statistically valid use?
I don't argue for everyone starting to run clinical investigations like mad, just for uniformity sake.
I do, however, argue that yes, most manufacturers need to have clinical evidence on file. I also think most of them actually have it, but many are too lazy to collate it and analyse it properly, or are trying to save the costs of a properly done literature search and analysis. If a device is not novel or has been around for long, there must be some sort of cumulative evidence for its safety and performance.
Roland chung
#27
I tend to agree with Ronen. But again, how to interpret the "Where demonstration of conformity based on clinical data is not deemed appropriate"? After the long discussion, it seems to be depended on the common sense.
Marcelo
#28
Yeap, but then again we go back to begin requiring clinical investigations for a lot of devices that are in the market today. And you are right, the intent seems to be this, but what I'm arguing is that applying the intent for all devices (in particular when using the new MEDDEV) may seem a bit unfeasible, for several reasons.
My experience is different. Most actually do not have it (and it's worse with the MEDDEV makes it more difficult to use "equivalent" devices, which was the justification in the past) and this include all types of manufacturers I work with. And they are not trying to save on the cost. But anyway, maybe it's only I that am experiencing this.
Sure, but not in "clinical data" as defined. They may have a lot of other data, for example, low count of adverse events, etc. But this is not clinical data. So if we say that these devices, which may not be low risk, simple devices, need clinical data, these other justifications do not count, we do need clinical data and, due to the lack of data, we need a clinical investigation.
Roland chung
#30
I do not know why you mentioned the clinical investigation again and again. This is not the intent of regulations. It is not true that there are no literatures for many products.
It is important to recognise that there is considerable diversity in the types and history of technologies used in medical devices and the risks posed by them. Many devices are developed or modified by increments, so they are not completely novel. It may be possible to draw on the clinical experience and literature reports of the safety and performance of an equivalent device to establish the clinical evidence, thereby reducing the need for clinical data generated through clinical investigation of the device under evaluation.​
T ISO 9001 Auditor Career without Quality Background? Career and Occupation Discussions 6
T With a Quality background, How high (designation) can you go in an organization? Career and Occupation Discussions 24
S How to Train People who have no ISO 9001:2000 Background (managerial level)? Training - Internal, External, Online and Distance Learning 1
G Question on Historical Background on ISO 10012 General Measurement Device and Calibration Topics 2
J CAPA History/Background Required - MSc Thesis on a CAPA System - Medical Devices Nonconformance and Corrective Action 5
S Shainin DOE - Paired Comparison? Background of this theory? Binomial distribution? Six Sigma 16
A Cell Manufacturing - The background and use of "manufacturing cells" presentation Lean in Manufacturing and Service Industries 5
H No background/training at all with TS 16949 - How do I get started? IATF 16949 - Automotive Quality Systems Standard 7
G What Is Your Company's Head Honchos Background - Poll Misc. Quality Assurance and Business Systems Related Topics 28
V Background of people in SQA (Supplier Quality Assurance) Supplier Quality Assurance and other Supplier Issues 5
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
S EU MDR Annex I Chapter III 23.4 z EU Medical Device Regulations 2
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
K Section 13.6 Annex 1 MDD 93/42/EEC for Glove EU Medical Device Regulations 0
D Is PMCF really a continuous activity per Annex XIV,Part B? EU Medical Device Regulations 5
R MDR, Annex I, 23.1 Interpretation - IFU on the website EU Medical Device Regulations 5
L EN 62368 (In an Annex - M.4.2.1) Secondary Lithium Battery Charging Safeguards CE Marking (Conformité Européene) / CB Scheme 2
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
K Applicability of Cybersecurity EU MDR 2017/745 Annex 1 23.4(ab), 14.2(d) CE Marking (Conformité Européene) / CB Scheme 3
K Applicability of eIFU as per EU MDR 2017/745 Annex 1 23.1 CE Marking (Conformité Européene) / CB Scheme 0
I IVD - 98/79EC - class IIa - Annex to the EC from the NB states the CM as one of the facilities? CE Marking (Conformité Européene) / CB Scheme 2
R Identify Medical Device characterstics as Annex C of ISO 14971 Risk Management ISO 14971 - Medical Device Risk Management 5
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 1
Rincewind MDR - GSPR - Annex I - Chapter II EU Medical Device Regulations 4
R An indication that the device is a medical device (MDR, Annex 23.2q) - applicable for accessories? EU Medical Device Regulations 5
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
S EU MDR Annex XIV - Clinical Evaluation Plan - What do these methods mean? EU Medical Device Regulations 16
K Annex XVI Device Transition Timeline under the MDR EU Medical Device Regulations 2
M EU MDR - Annex II 3b - What documents fall under this requirement? EU Medical Device Regulations 3
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
J MDR Annex VIII, Rule 6 Classification - Implication for lower risk CV products? CE Marking (Conformité Européene) / CB Scheme 3
Z 21 CFR and Annex 11 mapping document Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A EU-MDR Annex I Requirement 10.1(d) EU Medical Device Regulations 3
T Post-Market Surveillance Plan - Requirements outlined in Annex III (1.1b) EU Medical Device Regulations 2
D Applicable MDR Annex's for Class IIa Medical Devices EU Medical Device Regulations 0
J MEDDEV 2.12/1's new MIR & IMDRF terms & codes (IMDRF Annex) EU Medical Device Regulations 1
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
D Example for Accessories of "Annex XVI non-medical devices" and how to classify it now with respect ot EU MDR Other Medical Device Regulations World-Wide 1
P Performance evaluation (IVDD Annex VIII) & Design and Development Validation Studies EU Medical Device Regulations 1
H Critical Supplier Agreement acc. to NBOG 2010-1 Annex II EU Medical Device Regulations 10
L EU-MDR-Annex I - 10.4 (CMR & Endocrine-disrupting properties) - Labeling Content EU Medical Device Regulations 5
T EU-MDR-Annex I - 10.4 (CMR & Endocrine-disrupting properties) EU Medical Device Regulations 0
M Annex II - Technical Documentation. V&V, Performance and Safety EU Medical Device Regulations 3
S MDR Annex II Design & Manufacturing info - 'Adjuvants' definition EU Medical Device Regulations 3
J IVDR and MDR ANNEX I Requirements Template EU Medical Device Regulations 7
M Annex I - General Safety and Performance Requirements. Precise identity - how provided EU Medical Device Regulations 6
S Class II Medical Device Conformity Assessment Route according to Annex V only CE Marking (Conformité Européene) / CB Scheme 7
