Backsliding QMS - My office has gone through major management change
Jaxter
:uhoh:I know I will get a lot of criticism on this, but...my office has gone through major management change and transition since our last audit, external and internal. Management is constantly busy with meetings, the work, the employees, billing, customers, reorganizing departments and all issues connected with these. To say we've been "slammed" is putting it mildly. Our next external audit is approaching. What is the worst that could happen if we have some major NC's? How many do you need to have to have your cert suspended?
I know that ISO is an ongoing process. We have been following our established proceedures, but seem to be lacking in follow-up of corrective actions from previous deficiencies. Things may not be a bad as I think, but would like some valuable input from some of you experts.
It's like we backslid and now need to catch-up in a few months.
:frust: Fustrated QCM
F
Frank Oros
If you are the only one in your organization that recognizes these 'gaps', then you could in fact have some rough road ahead with your registrar. On the other hand, if your management team recognizes the impact of the changes that they've made, have identified the gaps, have plans underway (documented) to repair the pot-holes and a forecasted get-well program, your registrar should recognize this as appropriate 'change management' and give you a handful of OFIs, with bookmarks for review when he/she returns in 6 mos- 1 year. If you have mission-critical metrics that you've historically measured without fail, these should be at the top of your list from a maintenance standpoint.
If the 'awareness' meetings haven't begun yet, get them underway and let the gantt charts, swim-lanes et al, fly.
Randy
If your asking about worst case scenario I'll help with the answer
Major nonconformity for failure to effectively maintain the system, 4.1...Potential suspension or revocation of certificate
There you go, worst case
:) Smile first.
Nothing is wrong
Have all that you have detailed as clear management review records and based on the management review outputs, list the decisions and actions that are to be taken. let the records be timely and if any open actions still, do again discuss in the management review and record changed course of action.
Attend to all such tasks that effect your customer requirements directly, others next and as you know Randy has spelled out the worst, I am sure you will not hit that.
Good luck.
Randy
HTML:
This is the question asked by the OP guys and it's been answered
HTML:
The answer to question #2 is 1
HTML:
HTML:
And Jaxter also says this .....
From us, you mean? No, I don't think so: Many, maybe even most of us, have experienced something similar at one time or another, and we would rather try to help.
I think you just hit what needs to be done: Basically, your registrar will be much more understanding if you can show them planned and ongoing actions intended to get you back on track, so get your facts straight by listing those things, and start ticking them off.
Yes. Like I said, it has happened to many of us, and I recognize the situation you describe. We, for instance, are currently picking up the pieces after a painful downsizing, and patching things together again.
/Claes
harry
From us, you mean? No, I don't think so: Many, maybe even most of us, have experienced something similar at one time or another, and we would rather try to help. ...........................
Exactly, especially in today's turbulent world. And it reminds me of some discussions going on the last few days regarding: Management Review Input - Changes that could affect the QMS
The management review is an area where you can show that actions and plans are being formulated to overcome the situation.
P
pldey42
My understanding (from teaching management systems for a leading accredited CB for several years) is that the certificate is not suspended when a CB auditor finds an NC, or even several. Suspension will only happen if the NCs are not fixed according to the plan agreed with the CB, and then only after at least one warning letter.
Certification does not mean there are no NCs in the system. It means there are NCs which are not being fixed to plan, and they're sufficient in number or severity to damage the credibility of the certification. (If certification meant there are no NCs, the system would never change, because while it's being changed to meet new or changed requirements, or to fix problems, there is an NC: something ain't workin' right.)
When major organizational change is happening the right thing to do is to redefine responsibilities, authorities and processes and use the QMS to communicate such changes, typically by revising relevant documents. The QMS should not be regarded as a problem by management, but a tool for helping them manage the changes effectively.
Any NCs found by the CB during this process, too, are not something to avoid. They should be used to help management to manage their changes effectively by fixing the NC,s and using the QMS as it should be used to avoid further NCs.
Don't worry about NCs, they're the whips you may need to remind managers of how useful the QMS can be, used properly: you're not responsible either for the NCs or the potential loss of certification: they are.
CB auditors understand (or should) that during major organizational change NCs will arise. They will not want to add to the turmoil and risk the organization losing customers by unnecessarily suspending the certification. Talk to them ahead of time, let them know what's happening, so that they audit with understanding of the background to the changes. They might be able to facilitate the changes by auditing with planned or expected change in mind, for example by asking whether existing processes will scale up (or down) to respond to the new environment.
Hope this helps,
Pat
treesei
This is quite normal when major changes occur with management and org. It takes time for every one to find his/her place under the new order and return to productivity. An reasonable auditor will see this and take it into consideration.
But don't wait. Start to take actions immediately to address gaps and plan/implement corrective actions. We may not be able to fill every gap before the audit but it makes a big difference to show the auditor, and emphasize it, that we recognized the gaps and have been taking actions to get things right: Here is the plan, here is the timeline, here is what we have done, here is what we will do in the next xx weeks.
B ISO cl. 5.3 - Ensuring that the integrity of the QMS is maintained ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Scalable QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Using an online software to maintain your QMS Quality Assurance and Compliance Software Tools and Solutions 7
I QMS and ISO 9001 Misc. Quality Assurance and Business Systems Related Topics 11
E Visual Management Boards & QMS ISO 13485:2016 - Medical Device Quality Management Systems 8
S Disparity between Job Descriptions in QMS & Contract ISO 13485:2016 - Medical Device Quality Management Systems 7
qualprod Minimize tomention other positions to ease the QMS management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S QMS certificate and Samlping EU Medical Device Regulations 0
H Mapping QMS+business processes in a medical device with class I and IIa+b Process Maps, Process Mapping and Turtle Diagrams 3
Y Must Initial importers have any QMS? US Food and Drug Administration (FDA) 1
qualprod QMS global effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q 13485 QMS turnkey ISO 13485:2016 - Medical Device Quality Management Systems 10
K New to Medical Device QMS and would like advice ISO 13485:2016 - Medical Device Quality Management Systems 20
N QMS standard for a research based Organisation Quality Manager and Management Related Issues 1
Moncia Integrated QMS and audit Other ISO and International Standards and European Regulations 5
J New QMS Auditor - seeking opportunities to gain audit experience Career and Occupation Discussions 3
Sam Lazzara Record signature requirements in proposed FDA 21 CFR 820 QMS Regulation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
qualprod External consultant into a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S Changing PCB Assembler and impact on QMS and MDD CE Certificate EU Medical Device Regulations 2
ChrisM Class 1 non-sterile device, need certified QMS or not? EU Medical Device Regulations 2
A CDRH Learn and DICE for Building a QMS 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
A QMS inside a Non medical device firm ISO 13485:2016 - Medical Device Quality Management Systems 4
S HELP in setting-up QMS Quality Tools, Improvement and Analysis 4
S How long the QMS must be maintained after device EOL? ISO 13485:2016 - Medical Device Quality Management Systems 6
K Processes interaction of QMS Process Maps, Process Mapping and Turtle Diagrams 4
P Can I exempt products/services from my AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J0anne QMS Implementation Iran ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
adir88 Substantial Change to QMS (Annex IX, Chapter I) EU Medical Device Regulations 0
Watchcat When to begin putting together postmarket production QMS for a mobile app? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
B QMS Functional Safety Checklist ISO 26262 - Road vehicles – Functional safety 0
D Proof QMS compliance for class I ISO 13485:2016 - Medical Device Quality Management Systems 1
A Need career advice on QMS & HSE (No hands on experience) Career and Occupation Discussions 6
M Sharing QMS Documents with Customers Document Control Systems, Procedures, Forms and Templates 13
M Options when MSA acc. to VDA 5 is NOK (Qms > 30%) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D QMS Realignment after business splits into 2 different companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G One-person QMS - possible? ISO 13485:2016 - Medical Device Quality Management Systems 18
A SaaS SaMD - Impact QMS ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO9001 QMS: Quality Manual Examples & Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
K Is implementing Electronic Signatures a Significant Change to the QMS? ISO 13485:2016 - Medical Device Quality Management Systems 10
qualprod Can a consultant be audited instead of QMS responsible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Do you follow your QMS for non-device software features? Medical Information Technology, Medical Software and Health Informatics 4
Ed Panek How to address a QMS Entry Error ISO 13485:2016 - Medical Device Quality Management Systems 8
D Digital Healthcare - QMS requirements Other US Medical Device Regulations 3
BeaBea QMS/ Training Management Software Service Industry Specific Topics 4
R QMS for Medical products & Pharmaceutical Drugs in one facility Medical Device and FDA Regulations and Standards News 3
C First Round of QMS Internal Audits - Ethical Dilemma Internal Auditing 10
N Handling B-Grade Products within the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Supplied Goods out of QMS / DtS? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Can outsourced processes be excluded from QMS scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
H QMS ISO 13485:2016 - ISO14971 IEC60304 etc ISO 13485:2016 - Medical Device Quality Management Systems 6
