Bad Parts cause Customer line stop
Graciel
Hello.
Did someone have a situation caused by bad parts from your process that caused customer line stop? Can you share how this experience was and if something was made to avoid it.
Thanks.
Jen Kirley
Quality and Auditing Expert
I am currently a Supplier Quality Engineer for medical devices and see (too) many "line down" situations caused by parts issues, some of which were my suppliers.
The worst case involved flaws in painted molded PVC enclosure parts: namely the front cover, which is like automotive in that customers perceive quality in part on appearance of the portion of the unit they see every time they perform a procedure with it. I spent 2 weeks in the supplier's Minnesota plant in mid-December, part of which was at the (outsourced process) paint shop that applied the finish.
In the end, the corrective action was to fire that subcontractor and go back to their previous one, which added lead time due to its distance but so it is.
Johnnymo62
Haste Makes Waste
Because you have posted in the IATF 16949 section, I assume you are shutting down a Tier 1 auto manufacturer.
This was very expensive, hurt my former company's reputation and was very stressful. I recommend doing everything you can to avoid the situation.
We had to pay the expense of hand delivering good parts across Michigan to the Detroit plant. There was also the cost of paying for rework in the yards at the plant. Fortunately, Ford found the issue before they put vehicles on trains which would have been a huge cost.
We also had to warn all other assembly and engine plants to 100% verify the condition did not exist on similar parts. This was charged to us also.
It cost around $325,000. It could have been much more expensive. We were able to get a little back from our sub-supplier but it was months of negotiations and hassle.
Fortunately, it was a simple design issue that should have been noticed and could be permanently fixed. Unfortunately, we had to pay for extensive error proofing for this and across all similar parts.
A proper drawing/design review with barb to tube fit dimension analysis would have caught this. It should have been noticed and the tube drawing corrected all through the APQP and PPAP processes also.
Ron Rompen
I have (unfortunately) been in the position of shutting down an OEM plant. We were a Tier II supplier to a major Tier I at the time. This was due (primarily) to our Tier I customers design defect. However when we reviewed our CA with the OEM, part of the blame was assigned to us, for failing to note the design defect at our manufacturing feasibility review. It seemed a bit of a stretch at the time, but looking back now I find that I am at least somewhat in agreement. It was a learning experience for us, and one that (hopefully) I won't repeat again in the future.
There are times when dealing with automotive OEMs that you're damned if you do and damned if you don't. Back in the nineties, when working for a tier-1 to GM doing injection molding of interior trim parts, , we were notified that a part we made was failing in the field. It was a rear-shelf speaker grill, and there was a trainload of cars in Mexico wherein the grills were warping from sun exposure. The parts had passed all of the prescribed testing, which we did in-house. It turned out that the specified material wasn't matched with the proper testing requirements, which was clearly a GM mistake. In times past, our engineering people had made various suggestions about materials for different projects to their GM counterparts, and were uniformly told to mind their own business and let GM worry about the materials. At some point, our people just stopped making suggestions.
Our building was invaded by GM people for about three days, and it seemed that the purpose was to find some way to blame the problem on us. We retested the parts in their presence and demonstrated that the specified material was in use. Although they finally had to accept defeat, one of their people at one point told us that we should have known it was the wrong material and warned them, because we were the "experts." They were shown further evidence that such helpful hints had been rebuffed in the past, and finally went back to Detroit with their tails between their legs.
optomist1
A Sea of Statistics
...it has been my experience that the really good suppliers are the ones that among other things, are proactive, perform due diligence...and with the right measure of diplomacy inform the customer of the "errors in thinking, material selection, testing, scheduling or design". At times it certainly seemed as though we were being rough on suppliers....However, better to be rough and a bit over-bearing early on than to drag a supplier through the "Product Related Issue", i.e. one that affects the assembly point, resulting in a yard hold. At this point the suppliers risk increases astronomically, as does the scrutiny and risks...out come the microscopes.
outdoorsNW
Jim, good to see you were able to push back and prove GM was to the problem.
Several time now at two different aerospace mfgs, we have referred to certain people as the [large aerospace company] proofreading department. In one case, when they used a high volume off the shelf connector they did not follow the connector's recommended hole pattern, and the case did not fit the connector, delaying the project by several weeks while we had new metal case parts made to the correct hole pattern for the connector.
jimmymustang06
We get warned about this from time to time (we're tier 2, bulk material supplier). Our T&C's state we don't pay for consequential damages. However, we will bend over backwards, hiring sorting companies and/or expedited shipping, issuing credits, etc.
It is my opinion (30 years) that the tier 1's have gotten out of hand, with regards to their requirements for incoming quality (particularly for us commodity suppliers). Years ago, we were given defect PPM levels as a requirement (we supply millions of pounds monthly). Nowadays, most of our customers have moved to 0-defect policies. It seems they have reduced their in-line inspection over time (presumably to save money), and are flabbergasted when their customer finds a defect. We supply a part that is inspected via eddy current analysis. The equipment is set up according to ASTM standards. They receive a part with an issue that ASTM doesn't consider as a "defect", but through their processing, make the issue worse, fail to inspect for it, and send it to their customer, but send us a complaint. They want to know what we're going to do so they don't receive any of the issues going forward! We're not selling parts, we're selling a commodity product. If it were green beans we were supplying, our customers are rejecting truck loads every time they found one bad bean. Sorry, rant over.
Q Can there be a mix of good and bad parts for a variable GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
G Cpk vs. "Bad" Parts - Unreasonable Diameter Tolerance and a 1.67 Cpk Statistical Analysis Tools, Techniques and SPC 22
O How many bad parts needed for Attribute MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
ScottK Sampling Probability Question - Difference in % bad parts in a lot of 3100 pieces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
C Video talking about car accidents and legal problems due to bad quality parts IATF 16949 - Automotive Quality Systems Standard 1
M Does C=0 strictly mean 1 bad, all bad, all the time? ISO 13485:2016 - Medical Device Quality Management Systems 6
qualprod Ideas to stop bad practices in daily work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
optomist1 Aircraft Cockpit Automation - Good or Bad Human Factors and Ergonomics in Engineering 72
L How to Introduce the Quality Function to the production floor in a bad environment Misc. Quality Assurance and Business Systems Related Topics 6
V Inference of bad predicted-R-Sq - But very good R-Sq and Adj-R-Sq. Using Minitab Software 2
P Bad communication in construction projects are probably the biggest generators Quality Manager and Management Related Issues 4
A How can a sample can give information about bad products in whole lot? Quality Manager and Management Related Issues 3
D Requiring a "bad" part for attribute MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
T Zinc Phosphate Test Panels look bad - Need Help Manufacturing and Related Processes 2
B How do you measure whether a QMS is good or bad? Quality Manager and Management Related Issues 9
H Correcting Bad Process Habits Quality Manager and Management Related Issues 11
B How to Correct Bad Employee Performance-Attendance and/or Tardiness Quality Manager and Management Related Issues 84
Q Employees perceive CAPA as Bad - How to cope with the situation Nonconformance and Corrective Action 15
M Cost of Quality - Is it good or bad and why - Critical Review Research Philosophy, Gurus, Innovation and Evolution 28
I Do we need GOOD and BAD Wire Harness "Dummy" Samples? IATF 16949 - Automotive Quality Systems Standard 3
J Easy Method to Test a Caliper - Good or bad? General Measurement Device and Calibration Topics 10
P VDA 6.3 - Process Audit - You think you had it bad? VDA Standards - Germany's Automotive Standards 35
F Incentives for blowing the whistle on bad quality? Philosophy, Gurus, Innovation and Evolution 11
Colin Bad news/good news day Coffee Break and Water Cooler Discussions 22
J Bad driver? Blame your genes Coffee Break and Water Cooler Discussions 7
Wes Bucey Update: State of mind during the job hunt (Good habits vs. bad habits) Career and Occupation Discussions 12
Pancho Dvorak keyboard - one cure for RSI and bad typing habits Imported Legacy Blogs 1
H My job sucks so bad Funny Stuff - Jokes and Humour 20
Wes Bucey Agencies and Agents - good guys or bad guys? Career and Occupation Discussions 9
R Sampling - Total probability of accepting bad lot - Producer's risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
bobdoering You know things are gettting bad: US anti-kidnapping expert kidnapped in Mexico Coffee Break and Water Cooler Discussions 2
T Accountability… A good word or a bad word... Imported Legacy Blogs 2
J Soldering Standard which shows good and bad soldering Document Control Systems, Procedures, Forms and Templates 5
A What bad grammar in posts annoys you most? Coffee Break and Water Cooler Discussions 101
J Bad ISO/TS Auditors - Is it a translation problem or am I nuts? General Auditing Discussions 19
C Gauge R&R Studies Bad, but Process has a Cmk of over 7 IATF 16949 - Automotive Quality Systems Standard 8
I Document Control: The Good, the Bad and the Ugly Document Control Systems, Procedures, Forms and Templates 13
A Gage R&R Criteria - under 10%, %EV, %AV, %PV and Consequences of Bad GR&R. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
Marc Want to Buy a Smart ForTwo? Too Bad, They're Sold Out World News 13
Wes Bucey Exit (Escape?) Strategy (Employment FMEA) - Good and Bad Experiences Career and Occupation Discussions 23
Jim Wynne Using Famous Quotations to Describe Bad Managers Coffee Break and Water Cooler Discussions 10
ScottK Bad Want Ads in the Paper - Add your examples Career and Occupation Discussions 3
W Auditors - Some are Good and Some are Bad General Auditing Discussions 56
L Ellsworthband - Good or bad? Software Quality Assurance 8
D How to compare Cpk and ppm (bad pieces) Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Operating programs - Good or Bad? Looking at JobBoss Manufacturing and Related Processes 18
J How to deal with an employee who has a bad attitude? - Employee Attitudes Coffee Break and Water Cooler Discussions 15
