Ballooning a Print (Drawing) - A correct way to do a "bubble" print for a PPAP
Al Dyer
#21
Oh how can I say it -in my area of manufacturing, start at the top left work your way clockwise. There will be some anomolies but work your way arround clockwise and you will be the one that notes those are the static points. During that way you will points missed but go over them like it was the plan you had in the first place. Never let them know you sweat~!!!!
Al...
Wes Bucey
#22
FWIW:
In my machining business, we numbered the features in a regular pattern, BUT we also created an Inspection Plan which grouped the features in a manner to expedite inspection.
We grouped the attributes and characteristics in sections keyed to the inspection tool/instrument which would be used (we had one plan for First Article - ALL features; another plan for In-Process; a third for Final Inspection once in production)
The inspection would start from least complicated instrumentation through most complicated
  • confirm material cert,
  • visual for obvious blemishes, nonconformance,
  • external simple dimension check - caliper,
  • precision dimension check - micrometer
  • threads (gages or wires)
  • internal measurements (bores, threads, cavities)
  • special instruments (cnc optical comparator, CMM, hardness, chemical analysis, etc.)
This ordering would make for a more efficient inspection and allow replication using similar instruments for each stage of the inspection.
It just didn't make sense to us for the inspection routine to follow the numbering pattern dictated by starting in one corner of the drawing, switching from caliper to bore gage to super micrometer, back to caliper as each feature was examined..
Now, of course, programmed CMMs or optical comparators (or machine vision) can take dozens of measurements once the piece part is fixtured into the device, making the process even more efficient.
#23
Not sure where to post this or how to start a new thread.
Was searching google today and came across Combinumeral Font-this is the way to go.
Been Ballooning Prints for years and have tried many different softwares that never really worked for me, but the Combinumeral Font will place a balloon(circled) number on the print, I am using it in PDF.
This is a free font and will have to be installed to use it. ENJOY
fontsite.com/2092/combinumerals-ltdLet me know how you like it.
Happy Friday!
Gary Montaigne:)
Mark Paul
#24
I used to be quite pedantic about the way ballooning was done. This was brought on by a FORD STA w/ issues.
In my new position, I found that with up to 200 balloons what really mattered was how the CMM was going to spit the numbers out. To make life easy, I always ask the programmer if we ran the part 5 - 10 years ago. If so, what numbering did the long departed engineer and cmm guy use?
Sometime there is no rhyme or reason, the numbers are everywhere. However, since datapage and 'export to excel' are caput (don' ask) it makes it easy on the tech to fill out the ISIR when the ISIR numbers are in the same goofy order that the part is measured in. I can just sort the whole thing in excel for the customer. I've had to learn to let go...:notme:
tabort
#25
Happy Friday!
Gary Montaigne:)
Did you have any problems getting Combinumerals working in Acrobat? It works fine for me in Word but in Acrobat it just gives me left side semicircles on each number.
#26
Follow the link for instructions-wouldn't let me put in a link_
You can only number 1-99 with the combinumeral LTD font.
You would need to purchase the combinumeral pro version if you need to go past 99
you need to look up combinumeral instructions myfonts dot com
Use the letters on the Keyboard Q-P, A-;for 1-20
The number keys gives you the open and closed numbers, the number then shift and the number
tabort
#29
That's exactly what I needed! In word, it worked without using the Shift key and I had not seen that tutorial. Thanks!
N
ncwalker
#30
OK. I will bite and fight the stream ....
Absolutely do not forget to number the notes.
But as far as the dimensions go, IF it is a complex part (say 50+ dimensions) the best way to do it is to start with the datums. Number 1 is the primary datum, 2 is the secondary, ....
I will also add if you are doing this on a CMM, you should spit out the FORMS of the datums (typcially flatness and roundness) even if the print doesn't call for it. Why? When you start running the program, if the forms are ****, go ahead and stop the program. Because nothing else will be believable.
So 1-3 are your primary datums. Here is where you have a choice... you can then continue with all features based on these OR if there are secondary datum structures you can group ALL of them in the top. I like the first version, because contrary to popular belief you can't just switch alignment systems in a CMM. Everyone SAYS you can. Try it. You start to get round off accumulation errors.
My two cents.
(And yes, it's also nice to group them by HOW they are checked. First CMM stuff, then profilometer, micrometer, etc. Can't remember who said the comment).
P FAI Ballooning ASME Y14.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B HIGH QA Software - Auto ballooning software Quality Assurance and Compliance Software Tools and Solutions 2
W Red Ballooning Stamp for Adobe Acrobat Files Quality Manager and Management Related Issues 1
T Ballooning/Bubbling PDF drawings - My Dynamic Stamp AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 29
G Software Suggestions for Ballooning Drawings Quality Assurance and Compliance Software Tools and Solutions 9
J Explaining what a Quality Administrator does and Ballooning Prints Quality Manager and Management Related Issues 8
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
Ron Rompen Location of features identified on Print - Feature out of location Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Print Control Box - What does this dimension say? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Conflicting dimensions on customer print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Decimal places on Drawing (Print) Callouts Measurement Uncertainty (MU) 7
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
P New Yellow Print VDA 6.3 (2016) VDA Standards - Germany's Automotive Standards 10
E Position of a milled hex - Print Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Multiple Features With Only One Toleranced on the Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
K Assumed Alignment and Assumed Datum on a Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
A Algorithm to Detect flaw and burr on print characters Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
Q KPI's (key performance indicators) for a Print shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q In a Print Shop the Products are Special Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J A Euro sign on a print tolerance? Manufacturing and Related Processes 8
T More than One Original Test Report - Original Print General Measurement Device and Calibration Topics 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
N Excel Bubble Print Utility - Bubble Prints/Roadmap Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Ensuring Print Dimensions are in Control Plans, WI's and Receiving Inspection Document Control Systems, Procedures, Forms and Templates 3
M Radius Measurement question - Print that calls out a 5.5-5.7mm Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Print (Drawing) Bubble Techniques Document Control Systems, Procedures, Forms and Templates 45
H Example of Contract Review for Print Industry wanted Contract Review Process 4
