Bar coding of gages on usage instead of time
K
kat.k.
I am a calibration supervisor for a auto parts maker. Right now, over 50% of our workforce is laid off. All of the gage technicians were laid off because the plant managers said the gages were not being used so they weren't showing any wear. The Quality Manager gave me an approval for calibrations to fall past due except for the ones currently being used. After more than a month the technicians were called back to catch up on past due calibrations.
Our gage intervals are based on the length of time such as 6 months, one year etc.
Recently, one of our gage suppliers mentioned the use of bar coding gages on usage instead of time. Our gage system does have the option of usage verses time. Although this would eliminate the use of employed gage technicians, it would benefit the company.
Does anyone know about this method of gage calibration, how it works or where I can get more information?
Thank you
Kat
Hershal
Metrologist-Auditor
The concept can be valid; however there should be a maximum time as well, else you have ten years before you re-calibrate a caliper.
Jeff Frost
Kat,
First of all you need to look at the requirements of ISO 17025 to see if this method is acceptable. What are requirements of the Quality Management System Standard your organization operates under (TS 16949) and what do your customers contracts required?
Other items that must be defined are:
Gage preservation checks of unused calibrated gages.
Process for issuing gages to production
How user will know calibration status of gage
Maximum time between calibrations for unused gages in storage
Is this calibration control method acceptable to your customers
BradM
Kat, I am always excited about new opportunities to manage calibration activity.:agree1:
The thing is, I'm not sure if # of uses is the sole contributor to an item needing to be calibrated. Some mfg./models of instruments are less reliable than others. Too, I would surmise you have some kind of a staggered program, where the same gauges/same area does not come due at once.
I think the system might work after it got going. But it would be challenging getting it going. Primarily, how many uses indicates optimal calibration time, trying to schedule calibration resources when things come due.
Just some thoughts.
L Introduction of Compulsory Bar Coding of Medical Devices in the US? ISO 13485:2016 - Medical Device Quality Management Systems 19
L Bar coding - Medical device labelling - New Japan requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 1
1 How to measure straightness on a HEX Long Bar Manufacturing and Related Processes 7
I Can subgroup size change daily? (X-bar & R) Capability, Accuracy and Stability - Processes, Machines, etc. 5
L The ARL for an X bar Control Chart (n = 5) Statistical Analysis Tools, Techniques and SPC 5
G I-Chart and X bar Chart Control limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M CE Marking of Robotic Devices which use 5 Bar Pneumatics CE Marking (Conformité Européene) / CB Scheme 3
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Jen Kirley How to evaluate hazards in using bar code scanners in chemical manufacturing Occupational Health & Safety Management Standards 1
A Bar Lights vs LED-606 in vision inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J SST .625 dia Cold Rolled 303 bar and Magnetism Manufacturing and Related Processes 6
J Determining if there is Tin Plating on an Aluminum Bar Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Main difference between X-bar sigma chart / X-bar range chart Statistical Analysis Tools, Techniques and SPC 4
M Interpreting X bar and R Control Charts Statistical Analysis Tools, Techniques and SPC 2
M What is the difference between X Bar - R Charts and Average Chart? Statistical Analysis Tools, Techniques and SPC 7
B New website for AIAO-BAR - Unaccredited Accreditation Body ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 33
smryan Does the NIST certificate that came with my new ball-bar have any value? General Measurement Device and Calibration Topics 8
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
Sam Lazzara Bar Sealer vs. Impulse Sealer for Medical Pouch Heat Sealing Qualification and Validation (including 21 CFR Part 11) 4
S What decision rules should be applied for x bar-R chart? Statistical Analysis Tools, Techniques and SPC 10
I I-MR Chart vs. X-bar & R Chart - Differences Statistical Analysis Tools, Techniques and SPC 8
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
B If I know x-bar, spec limits, and Cpk, can I calculate the control limits? Capability, Accuracy and Stability - Processes, Machines, etc. 16
R X Bar R chart - Interpretation in MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C 1040 vs. 1040 Modified Bar Stock - Material Question Manufacturing and Related Processes 7
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
J ANOVA vs. X-bar/R Calculations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M X-Bar Chart - CQE Problem to Solve Statistical Analysis Tools, Techniques and SPC 3
K Individual x Chart - Why use the equation is barX+2.66 bar(MR) Statistical Analysis Tools, Techniques and SPC 6
S Validity of Craig Hane's Global Local Index for X-bar R Chart Assessment Capability, Accuracy and Stability - Processes, Machines, etc. 3
kedarg6500 Writing the symbol for R bar bar (double bar) in Excel Excel .xls Spreadsheet Templates and Tools 3
D For Reference Only or Calibration/Verification - Tape Measures for cutting bar stock ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
S Medical Gas Pressure Regulators - Anybody had testing conducted at 450 bar? ISO 10524 Other ISO and International Standards and European Regulations 5
D Relying on Supplier Records for Material Traceability - Bar stock and forgings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
hogheavenfarm Subjective vs Objective Finish Issues - Stainless Steel Bar Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
Q X-bar R chart question from CSSBB - QCI CD Professional Certifications and Degrees 2
M ANOVA / X Bar R Results are different - Why is the difference is so great? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G S30100 steel bar spec - related specs, ASTM or AMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Monitoring Out-of-control situations on X-bar and R chart Statistical Analysis Tools, Techniques and SPC 15
M CE Product Registration Bar Codes for each Product - Anyone? EU Medical Device Regulations 2
ScottK Brass bar stored in green wood boxes tarnished Manufacturing and Related Processes 5
ScottK Experts on Aluminum? 2024 T4 and T351 Bar Question Manufacturing and Related Processes 9
G Preventive Maintenance for Assembly Line Bar-Code & General Printers - Necessary? IATF 16949 - Automotive Quality Systems Standard 4
D Writing the symbol for X bar in Excel? Excel .xls Spreadsheet Templates and Tools 11
ScottK Portable Hardness Testing and Testers for Incoming Bar Stock Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
C Gage R&R for Uni-Micrometers on a rod or bar OD (Outside Diameter) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J ANSI Bar Code Validator MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Large CMM Calibration - Tetronom or Giant Ball Bar General Measurement Device and Calibration Topics 6
