Basic Gage R&R Sample Questions
bobdoering
Stop X-bar/R Madness!!
#11
Re: Gage R&R Sample Question
I am not disagreeing that you should understand the difference, but never forget it is called MEASUREMENT systems analysis, not gauge analysis.
Gage R&R is one facet of measurement system analysis. Clearly, it is difficult enough to have a tool that already includes environment, gage, operator and part. To add measurement error to this tool will mask the answer you are trying to get from the tool: Is this gage an adequate gage for the measurement? Very few gages are adequate when used incorrectly - so I am not inclined to throw that into this particular tool's usage.
You should purposely separate each of the components of the measurement system to fully understand them. The part that I strongly disagree about is limiting the effect of the within part variation in the situation where it is not ALSO controlled during normal measurement. If this is not made clear, the person will control variation for the purpose of the study, get an acceptable %SV, then promptly allow the operators to measure however they will. This is only kidding yourself.
I understand your point. If you chose to do a gage R&R using the tool correctly and a gage r&r using the tool incorrectly to prove the point, it would be an interesting academic exercise. Unfortunately, most of the people that need that training are the quality professionals that do not recognize such issues as measuring one diameter out of an infinite number of diameters is not an adequate way to describe a circular feature - not the operators they are training.
But, to burden gage decisions on incorrect measurement is certainly not a fair assessment of the gage's capability. And, if the gage fails gage R&R because of that, I would be suspicious that one would recognize that the measurement error - not the other facets of the gage error - is what would need to be corrected. A more accurate gage would never resolve that problem!
bobdoering
#12
I disagree with that the parts have to be the actual parts that are being measured with the gage. You might want to have various different parts, with different sizes and dimensions to evaluate the range of the part and any Part x Operator interaction. Maybe I am naive, but that is how I see it :)
Generally speaking, gage R&R answers the question: Is the gage adequate for measuring a specific characteristic. Your approach may answer: Is the gage adequate for measuring any similar characteristic? If it is, then you may be lucky. If it is not, it may still be adequate for the specific characteristic originally questioned...but you will not know.
It goes back to the rule of life with gages: All gages are bad...but a gage may be good enough. GR&R is how you tell if it is.
Statistical Steven
Statistician
#13
Bob, if I understand your approach, if you used a micrometer to measure nails, you would perform separate GR&R studies for each part number. I would propose that if we can show that the gage is capable for measuring a range of nails sizes, we can reduce the total size of the GR&R study. I guess I am wrong in that approach.
bobdoering
#14
I did not say your approach was wrong, I just cited the risk of that approach. Of course, the correct answer is "it depends." It is possible to do gage R&R for similar dimensions (families), but they must be similar - e.g.: in process (for the PV to be valid).
V
virpatel
#15
Hello everyone,
Can anyone explain me what is d value in gage r and r. how to calculate d value?
Thank You
#16
Can you clarify your question?
The only d values that come to mind is the D4 value used in the Range method, or the ndc (number of discrete categories).
V
virpatel
#17
i am talking about d4 value which is used to calculate EV in gage R and R. Can you explain what is d4 value and how to calculate it? Moreover i have also seen d2 value instead d4 in some gage r and r examples. what is difference between these two?
Appreciate
Thank You,
svara
#20
Can anyone explain why the %GRR and NDC do not come out good when using a gage that measures extremely accurate? I'm measuring a 9mm width and I only vary by .03mm using 3 inspectors and 10 parts.
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A GMDN Registration Basic preliminary Information EU Medical Device Regulations 0
M Basic UDI and technical documentation EU Medical Device Regulations 1
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
B Seven Basic Quality Tools (January 23) [Paid] Training - Internal, External, Online and Distance Learning 1
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Evaluation of Basic Safety during EMC Immunity or Climate Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
M EU Basic UDI-DI Trigger Points - When is a new Basic UDI-DI required EU Medical Device Regulations 3
M Informational EU – MDCG 2018-1 v2 Guidance on basic UDI-DI and changes to UDI-DI Medical Device and FDA Regulations and Standards News 0
F MDR 2017/745 Basic UDI-DI, UDI-DI & UDI-PI EU Medical Device Regulations 0
L Unacceptable risk for basic safety prior to or after mitigation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
E Basic Risk based thinking questions Risk Management Principles and Generic Guidelines 5
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
M Medical Device News EU – MDCG 2019-1 MDCG guiding principles for issuing entities rules on Basic UDI-DI Medical Device and FDA Regulations and Standards News 0
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S Basic Dimension W/O using FCF Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Carbon Black (Master Batch) - Basic Requirements Manufacturing and Related Processes 5
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
L Lean Book for Basic Knowledge Lean in Manufacturing and Service Industries 2
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M "Basic Safety" versus "Essential Performance" IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Use of Excel and VBA (visual basic for applications) in quality systems Excel .xls Spreadsheet Templates and Tools 3
P Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA Federal Aviation Administration (FAA) Standards and Requirements 2
J Excel spreadsheet to use Basic and Mini MOST for Line Balancing Document Control Systems, Procedures, Forms and Templates 1
T How to report Basic Dimensions on a Dimensional Report (ISIR) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Basic ISO 13485 Training Material ISO 13485:2016 - Medical Device Quality Management Systems 5
M Basic Dimensions on Machining Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Basic International Standards required for a Manufacturing Industry (Optical Media) Other ISO and International Standards and European Regulations 4
L How to set up a basic electronic test equipment calibration laboratory General Measurement Device and Calibration Topics 3
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
T Basic Document Control Database (Excel/Access) Document Control Systems, Procedures, Forms and Templates 3
V The Purpose of Basic Dimensions on Prints APQP and PPAP 6
N Basic requirements and steps involved to get NADCAP Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
P Basic Food Hygiene Presentation Training - Internal, External, Online and Distance Learning 6
M Training Toolbox for Basic Food Hygiene - Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Q Basic questions about AS9100C Quality Standard Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Basic Educational Film - What Quality is all about ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Basic Internal Auditor Training Powerpoint File Internal Auditing 26
S Basic Environmental Aspects Register template wanted Document Control Systems, Procedures, Forms and Templates 1
