Basic Internal Calibration Procedure to check the Accuracy of a Balance
chillipatch
Does anyone have a Procedure for using 'test' weights to internally check the accuracy of a balance? We have had our 'test' weights calibrated yesterday but we do not yet have a procedure. We are only after something simple, looking at doing the internal check each Monday. Thank you in advance.
Ajit Basrur
Re: Internal Calibration vs. Accredited Calibration for Balance - Differences
The magic Google gave - http://www.ssfpa.net/images/stories... - Equipment/SOP Scales Calabration Check.doc
chillipatch
Thank you Ajit - that's exactly what I was looking for. I tried Google - must have missed out on the key words that got you the result. Greatly appreciated.:thanks:
Ajit Basrur
I am glad that it met your requirement !
brianthermophilus
What does testing the low weight and high weights achieve? Wouldn't you be repeating the same sensitivity test twice? As long as the weight has a mass equal (or as close as you can get) to the nominal capacity of the weighing instrument.
I understand that a 2pt check would be measuring nonlinearity of the instrument but wouldn't that property be covered during sufficient frequency through calibration and maintenance.
I'm curious if most members use a 1pt or 2pt verification checks on their balances.
Thank you.
BradM
Well... just my :2cents:
Obviously in business each seeks the path of least resistance; the easiest and fastest. However... one must also perform that which is needed.
Prior to verifying the balance, are there internal weights for the balance? Is the balance internally calibrated prior to use?
To verify a balance,
  • Verify previous performance. Is there excessive drift? Is this balance being adjusted a lot?
  • Verify proper installation. The balance should be leveled, and vibration/draft free.
  • Verify weights to be used. They should be within current calibration, be a complete set, and should be handled properly. The weights should be checked for contamination. If contaminated, they should be appropriately cleaned. If they are heavily contaminated, they may need to be verified if they are still within tolerance.
  • Next, determine the use of the balance. This would include verifying the use range of the balance. Also, determine the surface area used during weighing.
  • Using the weights, verify across the use range. Also, if a large surface area is used on the weigh pan, corner load verification should be performed.
  • Document the results accordingly.
Important is to 1) verify the balance for the weighing operation to be performed, and 2) verify if the balance is drifting. The full calibration should involve not only the above, but verifying the accuracy of the internal calibration weight.
The procedure noted from google is okay for a scale, but typically for a precision balance, there are several parameters that are verified:
1. zero
2. linearity
3. eccentricity
4. repeatability
5. hysteresis
6. span
and if required, minimal sample weight (USP41) and measurement uncertainty of the calibration.
M Basic Internal Auditor Training Powerpoint File Internal Auditing 26
D Basic Requirements and Qualifications for ISO 9001 Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A GMDN Registration Basic preliminary Information EU Medical Device Regulations 0
M Basic UDI and technical documentation EU Medical Device Regulations 1
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
B Seven Basic Quality Tools (January 23) [Paid] Training - Internal, External, Online and Distance Learning 1
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Evaluation of Basic Safety during EMC Immunity or Climate Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
M EU Basic UDI-DI Trigger Points - When is a new Basic UDI-DI required EU Medical Device Regulations 3
M Informational EU – MDCG 2018-1 v2 Guidance on basic UDI-DI and changes to UDI-DI Medical Device and FDA Regulations and Standards News 0
F MDR 2017/745 Basic UDI-DI, UDI-DI & UDI-PI EU Medical Device Regulations 0
L Unacceptable risk for basic safety prior to or after mitigation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
E Basic Risk based thinking questions Risk Management Principles and Generic Guidelines 5
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
M Medical Device News EU – MDCG 2019-1 MDCG guiding principles for issuing entities rules on Basic UDI-DI Medical Device and FDA Regulations and Standards News 0
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S Basic Dimension W/O using FCF Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Carbon Black (Master Batch) - Basic Requirements Manufacturing and Related Processes 5
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
L Lean Book for Basic Knowledge Lean in Manufacturing and Service Industries 2
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M "Basic Safety" versus "Essential Performance" IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Use of Excel and VBA (visual basic for applications) in quality systems Excel .xls Spreadsheet Templates and Tools 3
P Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA Federal Aviation Administration (FAA) Standards and Requirements 2
J Excel spreadsheet to use Basic and Mini MOST for Line Balancing Document Control Systems, Procedures, Forms and Templates 1
T How to report Basic Dimensions on a Dimensional Report (ISIR) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Basic ISO 13485 Training Material ISO 13485:2016 - Medical Device Quality Management Systems 5
M Basic Dimensions on Machining Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Basic International Standards required for a Manufacturing Industry (Optical Media) Other ISO and International Standards and European Regulations 4
L How to set up a basic electronic test equipment calibration laboratory General Measurement Device and Calibration Topics 3
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
T Basic Document Control Database (Excel/Access) Document Control Systems, Procedures, Forms and Templates 3
V The Purpose of Basic Dimensions on Prints APQP and PPAP 6
N Basic requirements and steps involved to get NADCAP Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Basic Food Hygiene Presentation Training - Internal, External, Online and Distance Learning 6
M Training Toolbox for Basic Food Hygiene - Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Q Basic questions about AS9100C Quality Standard Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Basic Educational Film - What Quality is all about ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Basic Environmental Aspects Register template wanted Document Control Systems, Procedures, Forms and Templates 1
