Basic PFMEA (Process Failure Mode Effects and Analysis) Questions
sushant_kulkarni
Dear all,
1) Does it true that FMEA is made once for any product( Process not
consider) after that not revised atall ?
2) Does it true that Inward inspection not required FMEA only control plan?
3) As all of you know sev., occurance as well as detection decide the RPN
value.
But for Process inprovement purpose we have to revised RPN no. but only
DETECTION matrix we have authority to change other two factor
sev. & occurance we canot change.
Can any one give me exact idea about the same.?
And if anybody change all three factor too?
Manix
Get Involved!!!
Re: FMEA - some questions?
1) No, FMEA is a live document and should be updated throughout the products life cycle. Your aim is to reduce RPNs to the minimum possible, and in line with a commitment to Continual Improvement, this will be reflected in your FMEA. This can apply to process, product or system. Though a DFMEA is usually considered optimum once you have finished the design phase (because your design phase should aim to get it all right first time, but in reality this is sometimes not the case). Plus your DFMEA will be an input into future projects.
2) We include incoming inspection on our FMEAs. I know some may not. I would, because how is this different from any other process? There is still the potential for things to go wrong and you need to identify and mitigate this risk. In fact, is this not the most important process to get right? Failures here have a knock on effect down the process chain, and the earlier you identify them, the cheaper it will be!
3) I find that Severity is the hardest to change on a PFMEA. I find this because the severity of an identified effect is usually just as serious no matter what you do in the process. This is where we talk about a process failing leading to a failure of the product/service (customer effect). E.g. if someone does not secure a component correctly in the process, the effect will be potential lethal projectile within the passenger compartment of a vehicle. The severity of the effect will not change no matter what controls you instigate to prevent the failure of the process. However, some things the severity can be reduced. If the effect of a certain failure is the fact that an operator may breath in toxic fumes (manufacturing effect) and you actually take measures to reduce the toxicity, then this would reduce the severity, from the operator becoming seriously ill to perhaps them just getting a cough! Occurrence and detection can easily be reduced depending on the controls you put in place. Preventative measures will reduce the occurrence and detection type measures will obviously change the detection rating.
Stijloor
"Severity" keeps people that are interested in FMEA excited! It's like a toy, can't get enough of it! :D :D
Stijloor.
rdd007
FMEA for incoming inspection imo is absolutely needed. We include it and every step right through putting it on the truck. I have a customer who would probably want us to put purchasing on there as well ... if it could go wrong, it will, and needs to be thought through/responded to.
David DeLong
Re: Basic FMEA Questions
Process FMEAs should be performed on all process steps that are costed into your process of producing the product.
Is Receiving Inspection costed in? Do you produce a product at Receiving Inspection? The only thing you do is a small amount of inspection; that is it. How can your company make improvements in producing the supplied product if you have no control in its production? You can't!!
You supplier should be performing the process FMEA and their products and not your company. Beware that a lot of suppliers might "fake it" though.
I remember one time when I was presenting FMEA training in an automotive supplier and they reflected a huge, huge FMEA of a product. It had Receiving Inspection, fork lift driving, stacking, etc. What a mess. Look at the example in the AIAG standard.
Keep your FMEAs to the processes where you have full control in making the product and keep out of the indirect actions in your plant that are covered in your overhead, including Receiving Inspection.
D.Scott
I am sure there are varying methods of developing an FMEA. I respectfully disagree that an FMEA should be based on process steps being "costed in". I also don't believe the "production of a product" applies. The controlling question should be "Is there a possibility of failure in this step?". If there is, IMHO it should be included in your FMEA.
In our company there is certainly a possibility of failure in receiving. The customer may have sent the wrong parts to be processed or perhaps there may be a defect in the parts as received. There is the possibility that raw materials received may be nonconforming in some way. The possibility of affecting the process has to be considered and a resulting control developed.
Your point about overkill is certainly valid. I have seen a lot of line items that could probably be eliminated with good team analysis. The AIAG FMEA reference manual is certainly a good place for any FMEA team to start but please remember the examples there are not meant to be inclusive of all process steps. The manual often refers to a team of representatives from all affected areas. It specifically mentions "manufacturing, materials, quality, service and suppliers". The idea given is to develop a summary of the team's thoughts, including an analysis of items that could go wrong.
The intent of an FMEA is to determine where problems could occur in your process and develop controls to prevent them from happening. If you recognize receiving as a potential failure, the team should list it and make a determination as to what they will do about it. The FMEA should reflect a knowledge of your process and identify all your risks. What I see as a risk may not be a problem at your company. If we all shared the same risks there would be no need to sit down and do an analysis.
In the new AIAG CQI-12 Special Process Assessment question 1.3 (Requirements and Guidance) states "The organization shall incorporate the use of a documented FMEA .... for each process. In any case they shall address all process steps from part receipt to part shipment .....". Granted, this is written for fasteners but it reflects a preference by AIAG.
Boil it all down and you are right back to whatever the customer accepts works for me. If they don't require potential receiving failures, don't put them in the FMEA.
Dave
All process steps that have the potential to affect product quality should be included in PFMEAs, regardless of whether or not they're "costed in." The point could be made that incoming inspection should be eliminated wherever possible, but that's not the question here.
One point of confusion I've seen regarding inspection processes has to do with the AIAG PFMEA manual requirement for each step in the process to assume that the material coming into that step is conforming, and to focus on the potential failure modes for that process alone. This does not apply to inspection, for obvious reasons, and it's unfortunate that the manual doesn't address the distinction. Inspection processes, incoming or otherwise, have their own set of potential failure modes. For example, it's possible to approve nonconforming material, or reject conforming material. It's also possible to mislabel the inspection status of the material. There are other possibilities, but you get the idea.
Again, if the process has the potential to affect product quality, it should be included.
Dave
I was with you 100% until the last sentence. Whether or not a customer requires attention to a given process shouldn't necessarily be a good reason to eliminate it from consideration. If there is potential for costs (or customer dissatisfaction) to be incurred due to failure, the process should be included whether the customer requires it or not.
D.Scott
I agree. :eek:
Dave
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A GMDN Registration Basic preliminary Information EU Medical Device Regulations 0
M Basic UDI and technical documentation EU Medical Device Regulations 1
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
B Seven Basic Quality Tools (January 23) [Paid] Training - Internal, External, Online and Distance Learning 1
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Evaluation of Basic Safety during EMC Immunity or Climate Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
M EU Basic UDI-DI Trigger Points - When is a new Basic UDI-DI required EU Medical Device Regulations 3
M Informational EU – MDCG 2018-1 v2 Guidance on basic UDI-DI and changes to UDI-DI Medical Device and FDA Regulations and Standards News 0
F MDR 2017/745 Basic UDI-DI, UDI-DI & UDI-PI EU Medical Device Regulations 0
L Unacceptable risk for basic safety prior to or after mitigation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
E Basic Risk based thinking questions Risk Management Principles and Generic Guidelines 5
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
M Medical Device News EU – MDCG 2019-1 MDCG guiding principles for issuing entities rules on Basic UDI-DI Medical Device and FDA Regulations and Standards News 0
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S Basic Dimension W/O using FCF Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Carbon Black (Master Batch) - Basic Requirements Manufacturing and Related Processes 5
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
L Lean Book for Basic Knowledge Lean in Manufacturing and Service Industries 2
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M "Basic Safety" versus "Essential Performance" IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Use of Excel and VBA (visual basic for applications) in quality systems Excel .xls Spreadsheet Templates and Tools 3
P Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA Federal Aviation Administration (FAA) Standards and Requirements 2
J Excel spreadsheet to use Basic and Mini MOST for Line Balancing Document Control Systems, Procedures, Forms and Templates 1
T How to report Basic Dimensions on a Dimensional Report (ISIR) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Basic ISO 13485 Training Material ISO 13485:2016 - Medical Device Quality Management Systems 5
M Basic Dimensions on Machining Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Basic International Standards required for a Manufacturing Industry (Optical Media) Other ISO and International Standards and European Regulations 4
L How to set up a basic electronic test equipment calibration laboratory General Measurement Device and Calibration Topics 3
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
T Basic Document Control Database (Excel/Access) Document Control Systems, Procedures, Forms and Templates 3
V The Purpose of Basic Dimensions on Prints APQP and PPAP 6
N Basic requirements and steps involved to get NADCAP Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
P Basic Food Hygiene Presentation Training - Internal, External, Online and Distance Learning 6
M Training Toolbox for Basic Food Hygiene - Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Q Basic questions about AS9100C Quality Standard Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Basic Educational Film - What Quality is all about ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Basic Internal Auditor Training Powerpoint File Internal Auditing 26
