Basis used for Calibration or Verification of Measuring Equipment
m.dayakarreddy
This is my first post, but i am a user of this from long back. And i am getting useful stuff from you all.
And coming to the point, i need the best clarification reg. the below statement, plz help me.
7.6 Basis used for calibration or verification of measuring equipment where no international or national standards exist
So, I m expecting help regarding the above statement.
1. For some simple instruments (which are used to check the length and Weights) did we need to do calibration against the international or national standards? (Normally by external vendors)
2. Or did we do this by own, as by taking a master block as reference to verification? And for the record purpose (.....where no international or national standards exist), shall I explain the steps I had followed in verifying my equipments in document?
And is this document is enough as a record for ISo clause 7.6 a?
Al Rosen
Holed-up in a Hotel in South Florida
Re: 7.6 Basis used for calibration or verification of measuring equipment where no in
You can do it either way as long as the means you use is traceable to the international or national standard for length or weight. There is a standard for length and weight. Sometimes companies develop tools or methods for which there are no standards and that is what is referred to in 7.6.
m.dayakarreddy
Thanks for your Reply.
And still i am not clear about, what report i have to maintain to the above statement(7.6 a). If you have any format or if you have useful information regarding this, plz share with me.
Thanks in advance
BradM
Thanks in advance
I would think that would fall into a validation of sorts. What kind of process are you interested in?
Essentially you have an accepted standard (like Al stated), or you have to qualify the process you are going to use. Make sense?:)
Big Jim
The way I view this is that if there is a standard, either national or international, you need to use it. That means that if you are going to calibrate your own calipers, you would use gage blocks that are traceable to that standard (in the USA that would usually be NIST).
If you have a unique piece of testing equipment for which there has not been developed a national or international standard, but you have figured out a way to calibrate it for your needs, you need to explain how you perform the calibration.
This DOES NOT mean that you can choose to ignore the traceability to international or national standards simply because you choose not to have a gage block set that has that traceability.
samsung
shall I explain the steps I had followed in verifying my equipments in document? And is this document enough as a record for ISO clause 7.6 a?
Whatever basis (method/ criterion) you have used to calibrate/ verify the equipment has to be recorded in addition to recording the calibration / verification results in order to meet the requirements of 7.6 (a). The method may have been developed indigenously, locally or borrowed from some unauthenticated source only if no standards (national or international) exist.
m.dayakarreddy
Thanks to all,
Now i am clear with this report.
Some of the msgs here, are useful for me to under stand this.
And i had seen some useful links from OLD ELSMAR /forums.
From all, finally, i came to an idea like,
Calibration certificate:- It basically states, What is gauge(name, nos..)? is that made is right? & Gauges/tools are traceable to that country's standard. And along with it the actual attributes identified for that gauge.And name of the verifier, sign, validity period.
Shall any one comment on this plz.
Big Jim
Thanks to all,
I think you have the concept. A proper calibration certificate has all of those things, including information about its traceability.
Dr.mr555
The engineers at our company have developed an automated test system to stress test communication & computer systems embedded in our products. Test result outputs include router throughput rates, SATA transfer rates while monitoring temperature to assure safe operational thresholds are not exceeded.
Some of these output values are provided by onboard router or SBC sensors.
My question is should this test system be calibrated or verified in some way, and how that might be accomplished?
Thanks for help!
D Equipment calibration standard traceability - The basis used for calibration General Measurement Device and Calibration Topics 5
A Where no standards exist the basis used for calibration shall be recorded General Measurement Device and Calibration Topics 4
R Confusion - Which tools are used and why on a daily basis? Quality Tools, Improvement and Analysis 3
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
Ronen E A Rational Basis for Design Verification Design and Development of Products and Processes 5
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
ScottK Statistical basis for 30 pieces for FAI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A How to systemically improve product quality in short-term and long-term basis? Preventive Action and Continuous Improvement 1
W "On An Annual Basis" - Definition ISO 13485:2016 - Medical Device Quality Management Systems 12
C Occurrence Ranking: What is the basis for 1 in 1,000,000? APQP and PPAP 4
A System Audit on the basis of VDA 6.3 VDA Standards - Germany's Automotive Standards 5
M What is the basis of ALARP (As Low as Reasonably Practicable) ISO 14971 - Medical Device Risk Management 9
M Checksheet for each QC department to record their daily tasks on an hourly basis Document Control Systems, Procedures, Forms and Templates 15
D Physical Movement Deterrent for Quarantine of Goods on a Pallet-by-Pallet Basis Nonconformance and Corrective Action 8
L Regulatory basis for the practice of quality as the last signatory on approvals 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Should I Audit OHSAS 18001 on a Contract or Site Basis? Occupational Health & Safety Management Standards 1
M Basis for the Derivation of Inspection Levels (I, II, III & Special) AQL - Acceptable Quality Level 8
Q Basis for Verifying Corrective Actions and Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 12
R Minitab for I-MR - Monitoring Process on Temporary Basis & Temporary Limits Using Minitab Software 6
A How to Rate a Risk Acceptability and on What Basis is it Measured? ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
D What is the basis for having 1 or 6 Quality Manuals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Basis for Establishing Gage Tolerancing - "Gage Maker's Tolerances" General Measurement Device and Calibration Topics 4
P Discussion with Plant Manager (on the basis of ISO/TS 16949) IATF 16949 - Automotive Quality Systems Standard 7
P Please comment on revision status of document on a per page basis Document Control Systems, Procedures, Forms and Templates 25
O The Basis of %GRR (% Gage R&R) and other Statistics - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
V Quality System documents - Can Amendments be made on an 'as and when' basis? Document Control Systems, Procedures, Forms and Templates 6
V Should We Evaluate Suppliers on a Regular Basis or only when Issues Arises? Supplier Quality Assurance and other Supplier Issues 7
T Basis for Calibration Method and Intervals (Frequency) - FAA approved repair station Federal Aviation Administration (FAA) Standards and Requirements 10
T What is the basis for retained documents? Medical device manufacturer - FDA/GMP Document Control Systems, Procedures, Forms and Templates 9
F Attribute Gage R&R Basis for Applications - Personal Perception Criteria Statistical Analysis Tools, Techniques and SPC 3
Scott Catron Statistical basis for square-root sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
Z Ford Requirement - Annual Layout - Completely re-validate parts on an annual basis? Customer and Company Specific Requirements 1
A Measurement Brain Teaser - What constant is the basis for the meter? General Measurement Device and Calibration Topics 16
V Is an 8D Report suitable as a basis for the effcetiveness of preventive action? Nonconformance and Corrective Action 16
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
John Broomfield Informational Terms used in quality management [Deleted] Misc. Quality Assurance and Business Systems Related Topics 6
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
R Foam mattresses used in hospitals - compliance with MDR requirements? EU Medical Device Regulations 6
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
I Custom software services to be used by medical software ISO 13485:2016 - Medical Device Quality Management Systems 1
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
R PMCF - centers/countries used CE Marking (Conformité Européene) / CB Scheme 0
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
