Battery-Life Statistics
Marc
What if automakers measured gas mileage by rolling their cars downhill with their engines idling? They might, Newsweek's Daniel Lyons suggests, if they took inspiration from the MobileMark 2007 notebook battery-life benchmark test, the creation of a consortium called BAPCo, whose members are - surprise - computer makers and other tech companies. Laptops score big numbers, Lyons explains, because they're tested with screens dimmed to 20%-30% of full brightness, Wi-Fi turned off, and the main processor chip running at 7.5% of capacity. Professional reviewers see company-generated battery-life claims as a joke. 'The rule of thumb is that in real-world use you get about 50 percent of rated battery life,' says a Gizmodo associate editor. Leading the call for reform is the not-necessarily-altruistic AMD, who gripes that MM07 was created in Intel's labs and rigged so Intel chips would outscore AMD chips, which draw more power when idle.
Does your computer (or other device) get the battery life as advertised, and if so, for how long (knowing that with time battery life decreases)?
harry
From my experience - Almost all brands of laptops/notebooks claimed that their batteries will last for 3hr+ for the normal batteries but when used, you get about 2hr+ (about 60%-70%). Six months down the road, you may be left with less.
sparky58
Mark,
You are closer than you might think ref automotive manufacturers!
Most emissions and mileage figures are obtained from rolling roads. The usual "trick" is to disconnect all "auxilliary" services from the power-plant and run them from outside power sources.
I have a three-year-old Dell XPS M140 that came with a six-cell battery. I don't recall what Dell said about battery life because I knew whatever they said wasn't accurate. Out of the box it was set to dim the screen when on battery power, and I changed that. It's good for about two hours. Dell wanted $175 for a nine-cell battery, and I got one on eBay for $50. The big battery will go for about 3.5 hours. I haven't noticed any deterioration of battery life yet.
N Nickel Metal Hydride Rechargeable Battery Service Life - IEC 61436 ISO 13485:2016 - Medical Device Quality Management Systems 3
S Rechargeable NiMH Battery Life in Medical Devices - Replacement Intervals Other Medical Device and Orthopedic Related Topics 2
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
L EN 62368 (In an Annex - M.4.2.1) Secondary Lithium Battery Charging Safeguards CE Marking (Conformité Européene) / CB Scheme 2
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
T Battery Powered Device - MOP and Patient Auxiliary Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F IEC 62133 cell vs. Battery Pack - Certification on the cell only IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E IEC 60335-1 li-ion battery requirements Other ISO and International Standards and European Regulations 0
E CB scheme applicability for battery powered medical devices CE Marking (Conformité Européene) / CB Scheme 0
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Assembly of cells into battery - Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Leakage Current test and Dielectric strength for Battery operated ECG device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Battery Enclosure Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Lithium battery powered Medical Device - 15.3.3 Impact test, broken enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Classification of a device that uses an existing battery IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Dielectric Test of Battery Powered Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E Electrical safety (battery-powered medical device) EU Medical Device Regulations 1
L Battery requirements for medical device (US/Canada/EU) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Testing ME equipment powered by Battery EU Medical Device Regulations 0
K IEC 62133 Test Report for Lithium Battery Certification IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S IEC 60601 Main requirements for Lithium Ion Battery Powered Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Testing a Low Current (Battery) DC Medical Device Other Medical Device Related Standards 4
M Battery Powered Measurement Equipment and Low Voltage Directive CE Marking (Conformité Européene) / CB Scheme 1
B Primary lithium battery protection and vented gas IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Measuring LiON Battery State of charge - Transporting batteries by Air RoHS, REACH, ELV, IMDS and Restricted Substances 1
W EMC, ESD for battery operated apparatus Other Medical Device and Orthopedic Related Topics 1
A IEC60601-1 - Battery Charger Requirement - Home Healthcare Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F Ambulance Battery Isolation - IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M IEC 60601 Charger requirement for Lithium Ion Battery Powered Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
C Battery Powered Beauty Products minimum Legal Certifications Requirements CE Marking (Conformité Européene) / CB Scheme 7
E Requirements for primary battery powered ME with BF-applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Requirements for Using Lithium battery instead of Alkaline IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
X IEC60601 Battery powered devices intended for measuring bio-impedance IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Is IEC 60601-1-2 compliance/testing required for battery powered Class I Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Demonstrating battery safety in 510(K) submission for the FDA Other US Medical Device Regulations 9
D Battery Powered Medical Device Battery Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B Flammability Ratings for Internal Battery & Hand-Held ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
thisby_ Medical Device Battery Powered Equipment connected to Charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T Polymer Lithium Ion Battery and Ventilation Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
M IEC60601-1 Battery Powered Body Worn Device Leakage Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M IEC 60601-1 testing for device with its own 2V battery power supply necessary? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T IEC 62133 Certified Battery Manufacturers Other Medical Device Related Standards 3
K Li Ion battery for medical device: transportation safety Other Medical Device Related Standards 2
A Boeing 787 Battery Investigation - NTSB findings to date AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Medical Device Battery Labeling Requirements in the US US Food and Drug Administration (FDA) 1
