I am a 3rd party auditor. The exams are taken after a 3 day training class given in Southfield MI by Plexus. The exams cover 5 separate areas and each exam is separate from the others. The testing takes all of the 4th day. Specifically, you will be tested on SPC, FMEA, and Control Plan from the AIAG manuals, the other 2 tests are the IATF 16949:2016 manual and lastly Rules (in my case 5th edition). You must score a minimum of 80% on each test. You could conceivably score 100% on 4 of the tests and get a 79 on another and you do not pass! Bone up on the AIAG manuals and take self exams wherever you can get some quizzes. All tests are timed for 90 minutes - do not waste any time as time management is key, there is no forgiveness for not finishing in 90 minutes. The IATF exam will be one where you read a scenario of a company totally frought with many problems - do not fall for getting involved and thinking of all the things you need to do to fix the problems as your 90 minute clock is running and when you get to the quiz questions you realize you have just wasted too much time on the scenario. On test day you will be given a schedule of where to be at what time - your classmates will not be in the same tests as you. After an exhausting day of 5 tests you then will be given a company scenario and you are required to make an audit plan which you will take into an oral defense room where 2 Plexus personnel will have you explain your audit plan and why you selected certain things to audit - I can not say how this oral defense is scored but they have a say in your passing somehow. You must study very hard as the first time pass rate is somewhere at about the 25% level - most do not pass the first time due to time management and not completing the tests in 90 minutes. Good luck! After you have been granted the IATF 3rd party certificate you will be in the field for 2 years then back to Southfield for your 2 year testing. First 2 years as an auditor your Auditor ADP number will start with a 3. If you do not pass totally at your 2 year exam you will be a 'Yellow" auditor status and your ADP number will be a 4- something. If you full pass at the 2 year exam your ADP # starts with a 5 and you are basically good to audit forever - or at least a very long time.
Dear Buford,
Thanks for your great explanation.
I think the process you have described, is slightly different with the following flowchart by IATF, especially in training and exam days (3.5 days and 1.5 days) exam sequence and their times.
Has the exam process been changed?
