Bench Testing & Pre-verification vs. Formal verification
I
Inclag
Hi All,
I'm having a challenging time with understanding what the difference between bench testing or pre-verification testing compared to formal verification testing with respect to how it relates to medical device development?
My interpretation is that the term bench testing and pre-verification are used to describe 'verification' activities that are conducted on prototypes that are under design control but are not yet actual production product that is to be marketed or submitted for regulatory agency approval. So in essence, it is a type of development verification activity. Since this testing and type of verification is conducted during development, it can be viewed as the verification activities that an organization determines are necessary in order to document and verify that a prototype is ready to be used in a pre-clinical, early feasibility study (IRB), IDE (FDA), or pivotal study.
Obviously, not all requirements or risk will be understood or captured early in the development process and therefore not all verification activities required for the final product will be fully understood until later in the process. My understanding is that this is in part why independent parties (IRB's, FDA IDE, etc.) play a hand a reviewing and approving clinical study devices.
So to summarize, the way I'm viewing this is that;
Bench Testing/Pre-Verification --> Used on prototypes --> Testing conducted is inclusive of best effort determination of necessary requirements that developer has determined is needed to ensure function and patient safety --> Independent parties (FDA, IRB's) are the gates that determine that inputs and outputs identified and the planned and executed verification activities are appropriate to move forward with a prototype study.
Formal Verification --> Used on product --> Testing is inclusive of all requirements. FDA is gate that reviews that all inputs and outputs meet the regulatory requirements for the production design.
Is the above understanding consistent with how others view the difference between bench testing and verification?
yodon
I'm not sure "pre-verification testing" is a thing (from a regulatory / compliance perspective).
Verification activities provide objective evidence that the product meets the (approved) requirements. Frequently, you can't verify requirements on production units as it may require special test configurations / setups. Rationale for the test approach should be documented in the test plan or protocol.
Clinical studies are outside the scope of verification and production equivalent devices need to be used. If not production devices, rationale needs to be documented why the devices are production equivalent.
Using the 'classic' V model, User Needs are at the top of the requirements tree. Validation provides the objective evidence that user needs are met. System requirements elaborate the user needs and verification provides the objective evidence that requirements are met.
Does that help?
Ronen E
Problem Solver
Moderator
Yodon’s response is very much spot on. I’m also new to the term/concept of “pre-verification”. Isn’t it just a fancy name for informal testing you do during development?
Bench testing is a category of testing that can be part of anything. Typically formal verification includes bench tests. You can do bench testing on prototypes or on production units. You can also base a regulatory submission on prototype tests.
I would definitely not recommend using any product, whether you call it a “prototype” or a “production unit” (or equivalent) in pre-clinical, early feasibility, IDE or pivotal study before it passed full, formal verification, including any necessary bench tests.
External parties play a part in reviewing and approving clinical studies (of any type) mainly for ensuring subject safety and rights are not compromised; not to help you complete your requirement-set or risk management process. The latter are taken care of through multiple design iterations - typically a new device is not fully developed through a single design/verification iteration. Typically you’d go back to the design inputs and the design itself after your first verification round.
I
Inclag
Thanks yodon and Ronen on your reposnses.
What I find challenging is the fairly binary criteria of performing full and formal verification on something such as an EFS study device. Part of my understanding of an EFS is that it is a small study used to gain valuable insights into the development of a new technology. As such it would seem unreasonable to me that all user needs and requirements would be completely understood or captured within this part of the development process as these could be key outputs of a EFS. Secondly, it wouldn't seem reasonable in some instances to have certain devices run through the full gamut of some of the verification tests such as IEC 60601, in order to proceed with an EFS.
Yes, user/patient safety is important and this should be the primary concern of the developer, however is there not reasonable justification as to why perhaps a developer may verify only certain clauses of IEC 60601 (ground fault, EMC, etc.) and exclude things like drop and ingress if the number of devices is limited and the device is going to be used in a controlled environment under supervision or use of trained individuals??
The reason I ask is because the last item noted is basically me paraphrasing some input from a regulatory/quality director that recently weighed in on a conversation I was sitting in.
Ronen E
Problem Solver
Moderator
"Full and formal verification" just means that all the design inputs stated (reviewed & approved) at that stage have been met. It doesn't mean that the design inputs are necessarily complete or watertight. And yes, an EFS may expose new needs or shortcomings in the application as understood/envisioned at that stage.
Going into a clinical trial, the reviewing committee should have access to all previous test summaries as well as justifications for tests not completed (e.g. certain 60601 clauses). That should allow you to argue for reasonability/proportionality and them to consider subjects' wellbeing against any residual risk.
K Mammography Machine Bench Testing - FDA 510(K) US Food and Drug Administration (FDA) 5
M Informational USFDA final guidance – Recommended Content and Format of Non-Clinical Bench Performance Testing Information in Premarket Submissions Medical Device and FDA Regulations and Standards News 0
Ronen E FDA News FDA issues guidance on bench testing in premarket submissions Other US Medical Device Regulations 0
J Is Bench or Clinical testing better? Other US Medical Device Regulations 2
J US import requirements for bench testing without 510k Other US Medical Device Regulations 3
M Bench Testing Requirements for Class 3 devices EU Medical Device Regulations 4
N Critical Analysis of Medical Device Bench Testing data ISO 13485:2016 - Medical Device Quality Management Systems 6
B Technical File Part A - Bench Testing CE Marking (Conformité Européene) / CB Scheme 3
shimonv Bench Testing as part of 510(k) Submission US Food and Drug Administration (FDA) 1
A Does the V&V (Verification and Validation) belong to Bench Testing for 510k? Qualification and Validation (including 21 CFR Part 11) 2
Le Chiffre 510(k) Changes: More bench testing and stricter design controls? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Can we use the data in intertek or TUV lab testing report as bench testing data? Other US Medical Device Regulations 2
A Bench test report translation to English for 510(k) submission Other US Medical Device Regulations 2
H Frequency of shelf life/sterilization/bench studies conducted on a medical device Other Medical Device Related Standards 1
F ≥5 micron macroparticles measurement in Laminar Airflow (LAF) bench (ISO Class 5) Miscellaneous Environmental Standards and EMS Related Discussions 0
S Bench Marking Automated Data Collection Benchmarking 4
M What is a Bench Test and how is it used? Reliability Analysis - Predictions, Testing and Standards 4
M What should be in an SOP for a Machine Operation - LAF Bench in our Clean Room ISO 13485:2016 - Medical Device Quality Management Systems 3
D Aircraft Coffee Maker Repair Bench Glassware Calibration General Measurement Device and Calibration Topics 7
L Clinical Investigation vs. Bench Test - Definition EU Medical Device Regulations 1
D Do Device Verification Bench Tests need to be GLP? US Food and Drug Administration (FDA) 7
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
J Any Difference Between Bench Top and Portable Hardness Tester? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Building a Calibration Room Test Bench - Finding components, test leads, etc. General Measurement Device and Calibration Topics 8
R How to determine magnification power? Illuminated bench-mounted magnifiers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Bench Top Oven Calibration Standards General Measurement Device and Calibration Topics 8
T Installation Requirements for Bench Top Device ISO 13485:2016 - Medical Device Quality Management Systems 1
L Definition Bench Test - Definition (in FDA context) and its difference with Clinical Study? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
A How to Determine ESD mat dimensions for work bench? Misc. Quality Assurance and Business Systems Related Topics 7
R Bench Marking in Construction Industry - Seeking Guidelines Benchmarking 8
J Does anyone know how to adjust/calibrate bench centers that are not parallel? General Measurement Device and Calibration Topics 4
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
