Best Engineering Practices related to Top Assembly Drawings
Dosumi
looking for best engineering practices related to top assembly drawings.
Can the top level drawing contain two difference sizes of the same assembly were the differences are identified and listed in the BOM?
Chennaiite
Never-say-die
We do not fiddle with BOM for mentioning dimensions. Doing so might have some implication in Assembly. We predominantly use BOM for procurement planning and for us, Drawing is the one which gets transferred into sketches for Assembly station indicating size, torque and all that.
Under the scenario you specified, we use tables as a part of drawing itself. Drawing will refer some size as constant 'a' or so. Table will provide the value of 'a' depending on its parent assembly or application.
Dosumi
Chennaiite
Thanks for the reply.
We do not put dimensions in the BOM. The BOM only list different parts related to the assemblies.
What I'm looking for is a engineering or drafting standard that references the use of assembly drawing that contain more the one size unit(or some other designation) such as 123456 & 123457. Something similar to -1 right side shown and -2 left side opposite. This is for a submission that a reviewer stated drawings have multiple part numbers and I need to know if this is an accepted industry practice and if so were could I find the document to reference the acceptability of this practice.
I am trying to justify referencing two sizes units on one drawing, one has a 12inch width and the other a 14inch width. Engineering referenced the two sizes on one drawing indicating in the BOM the different parts that make up the size 12 and the size 14, there are also common parts used on both assemblies.
P
PaulJSmith
I have not seen this as any kind of "standard practice" in any of the industries I've worked (electronics, automotive, aerospace, musical instruments). Generally, if there are different part/assembly numbers associated with each part, then they would be found on their own drawings. That's not to say that it cannot be done, but it doesn't seem like any kind of industry standard.
Ronen E
Problem Solver
Moderator
Chennaiite
Although I can't point to any published standard, I think using a single drawing for more than one final assembly part number can be acceptable (seen it practiced), as long as there are controls in place to make sure there is no confusion as to which one is being referenced at a given point, and how to deal with it. I guess that's you reviewer's concern. Now, if they want to cite you for that, please ask them to point to the regulation or other written requirement that negates your practice. Then you will more likely be able to address it effectively.
Cheers,
Ronen.
Dosumi
Thanks everyone for your Insights
I've worked in a few different industries Aerospace, commercial equipment and medical device and I don't remember seeing this practice until my present company. When I first encountered this it really didn't send up any red flags as it was understandable and not confusing as the products are fairly simple in design.
I believe my main issue is the reviewer is new, Biomedical engineer 2012 attained MS 2013 and is working as a Research follow. :applause:
I will leave the drawings as is and request a reason as to why they need to be changed.
Again
S Industry Best Practices for managing outside Engineering Consultants Design and Development of Products and Processes 3
Anerol C Who is the best Registrar for Metal-Engineering industry? Registrars and Notified Bodies 10
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Best profilometer for the money General Measurement Device and Calibration Topics 22
P Best Global Option to become an OBL/PLM/Virtual medical device brand in 2020 Other Medical Device Regulations World-Wide 2
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
A What are Practical data center best practices IEC 27001 - Information Security Management Systems (ISMS) 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
S Best software for customer support/complaints? Customer Complaints 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Informational MHRA launches consultation on how to best engage patients and the public Medical Device and FDA Regulations and Standards News 0
optomist1 Mobility Field Manufacturing Best - Worst Practices Manufacturing and Related Processes 5
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
S How to Learn all aspects of ISO 27001:2013 | The best way to grab the knowledge on 27001:2013 (Step by Step) IEC 27001 - Information Security Management Systems (ISMS) 7
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
M Over-labelling - Any requirements or best-practices? Other Medical Device Regulations World-Wide 0
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
M Informational BSI – MDR Documentation Submissions Best Practices Guidelines Medical Device and FDA Regulations and Standards News 0
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
P How to have employees buy-in of quality procedures. Best practices? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Expiry date vs. Best Before Date - Reagents ISO 13485:2016 - Medical Device Quality Management Systems 9
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Best approach to tackle difficult certifications Career and Occupation Discussions 2
E Best Ways to Close a Project APQP and PPAP 3
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
C What is the best ISO 22000 template pack to purchase? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
