Best Fit Alignment vs. Hard Datums
Maxebolo
hello guyz,
need help please,
B/P calls out for datum's( profile) on a composite part(fiberglass), with a surface variation of .030" all over the surface.
when i run it thru verisurface (faro arm) using the datums it shows a bad report, but when i do best fit all points are now within tolerance? how could this be? should i use hard datums instead of best fit?if so, why, any mathematical explanation? Help Help...
smkeilman
Maxebolo,
This is my first post here, so I won't be offended if you take what I have to say with a grain of salt.
I use FARO's hardware and software, but don't use Verisurface, but I think I can help you. Draw a symmetrical trapezoid. Imagine you are measuring the profile around the trapezoid, and the print calls for a rectangle. If you measure the profile all around the trapezoid, it could be possible to have a good profile using best fit all points. The reason for this is that the two bases will be fit well, and any squareness errors are going to be split between the two sides. If you force an alignment to CAD using the left side, you will see a good fit at that side, squareness errors at both bases, and a parallelism error at the right side roughly equal to the sum of the squareness errors from the best fit scenario.
The reason you are getting different numbers is because the datums are changing the way the computer is solving the alignment to the CAD data. Using a best fit all points algorithm, the errors across ALL surfaces will be minimized, regardless of any other orientation constraints brought about by datums. Using the datum alignment algorithm, the datums will be matched and minimized prior to any other profile calculation. You should notice a smaller profile reading on the datums using the datum alignment versus the best fit.
I think it is very likely that your datums result was calculated correctly and that your part is not to print, unfortunately.
richw26
Does anyone have a way to calculate profile (gage points, x-y-z) in excel? The CMM program that one of plants is using does not have the option to calculate it. Any help or direction here will be much appreciated.
smkeilman
It depends quite a lot on the type of features you are trying to measure. First of all, it's not impossible, just very difficult. The biggest problem you will have is writing an equation for the nominal surface as a function of x, y, and z. For a plane, this is not exceptionally difficult, but for features such as a cone or torus, this will get prohibitively hairy. It will likely be cheaper (in terms of man-hours) to simply upgrade the measurement system, especially in the long run.
Z
zancky
IMHO
All the algorithms try to reduce the sum of the squares of the differences between the actual data and the calculated surface.
For most of the features there isn't any exact solution.
If you wont to solve by yourself you should
1) write the mathematical formula of the surface
2) write the formula for the sum of the squares
3) identify the parameters (xyz origin, direction etc)
4) write an algorithm to find the minimum (usually Newton Raphson)
5) write a program/macro
6) validate the program by some emulation.
if point 4 it is too hard you can try to scan each parameters within a probable range (nested "for " cycles).
I have apply point 4 for a torus in a CMM running in windows NT4 machine but there was only 2 free parameters.
I have tried also the alternative method (nested "for" cycles) for a strange features, but with 6 parameters I need a C++ program with multi-thread (8!)
running on a I-7 in order to get the results within 3 minutes
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
J Which chapter in Quality Manual will best fit this form (truck reservation)? Quality Management System (QMS) Manuals 1
S what is the Best Fit and what is 2D-fit and what is difference between these? Statistical Analysis Tools, Techniques and SPC 3
P Find the best fit of data: linear or quadratic Reliability Analysis - Predictions, Testing and Standards 4
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Best profilometer for the money General Measurement Device and Calibration Topics 22
P Best Global Option to become an OBL/PLM/Virtual medical device brand in 2020 Other Medical Device Regulations World-Wide 2
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
A What are Practical data center best practices IEC 27001 - Information Security Management Systems (ISMS) 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
S Best software for customer support/complaints? Customer Complaints 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Informational MHRA launches consultation on how to best engage patients and the public Medical Device and FDA Regulations and Standards News 0
optomist1 Mobility Field Manufacturing Best - Worst Practices Manufacturing and Related Processes 5
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
S How to Learn all aspects of ISO 27001:2013 | The best way to grab the knowledge on 27001:2013 (Step by Step) IEC 27001 - Information Security Management Systems (ISMS) 7
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
M Over-labelling - Any requirements or best-practices? Other Medical Device Regulations World-Wide 0
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
M Informational BSI – MDR Documentation Submissions Best Practices Guidelines Medical Device and FDA Regulations and Standards News 0
P How to have employees buy-in of quality procedures. Best practices? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Expiry date vs. Best Before Date - Reagents ISO 13485:2016 - Medical Device Quality Management Systems 9
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Best approach to tackle difficult certifications Career and Occupation Discussions 2
E Best Ways to Close a Project APQP and PPAP 3
