Best off presentation of process flows
Qualygirl
#11
When I go deep into myself and look at what has happened in the small, certified company over the years.
With very close, direct contact with employees and management, I have to say that this group does not care what process / representation is present.
Only for me as a management representative and auditor it is easier and simpler if a clean, comprehensible process is in place so that a clear degree of fulfillment can be recognized and assessed.
Also makes itself better for Cert-Auditot and for the detection of weak points, which then lead to changes if necessary.
There is no job description in the company.
Implementation follows instructions.
My favorite: for a process description with a table.
Now it would be super fantastic if I could get a few approaches from the experts.
thanks
darkopsghost
#12
In computer programing, programmers create a Flow Chart to determine what the program will do and when it will do it. Inputs, decisions, outputs, and records. A Block Diagram is for a visual representation of what needs to happen, an Outline if you were.
In the Quality World we have it relatively easy unless we are creating a process as we are only reporting how a process works. We don't have to use fancy objects or fancy software to do it.
Within Word (and other software I'm sure ) there are Flowchart Shapes that can be inserted into a Word document.
Think the process through, to scribble it out on paper may help, Insert the object (Shape) in your document, and put text in it to represent what that block is doing, Insert arrows to show process flow, add some color if you like and you're done. It can be as simple or complex as you want to make it.
If it is in a process that calls use of another process you can leave it at just that, as a "Call TO" that additional process which will be defined within it's own documentation for that additional process. The last thing you want is detail from an additional process buried within a separate process. Change one and fail to change the other and that's an automatic write up when it's caught.
On an overall Process Map of all Processes, don't forget to add detail on Process Interaction from one process to another. You want Customer Input at the top (requested Job or Work to be performed) ((I actually break up my individual processes into their own columns; more on this later)), what that Input drives (actions) within your company (those are the Key Activities within those processes, what happens to make that activity work, i.e. Contract Review, Quoting, Order Acceptance, Order Processing, Supplier Approval, Purchase Orders, Non-Conforming Product, etc.) and how it all works together, and you want to show the outputs of each of the processes.
I list all Metrics driven by each of those Processes and add Support Activities such as Management Review, CAPA, and Record Keeping.
By putting your Processes in columns you can easily add arrows to show Interaction from one Process to another.
Be concise but I tend to make it as simple and clean as I possibly can. No need to confuse anyone; someone within a process, an Auditor, or yourself during an Audit.
Qualygirl
#13
Hello
do you not include any inputs / outputs in a swimlane diagram and how / where do you put used documents there?
That is totally unclear to me:
Are there any examples of this?
John Broomfield
#16
Try this guide on deployment flowcharting:
Deming Flowchart - [PDF Document]
Yes, you may show the inputs originating from other processes and entities serving your process from the swimlane that receives the input (and you may identify the relevant document) as necessary for competent users to understand the process sufficient for its effective planning, operation and control.
You may also identify any records produced and refer to your filing and archiving procedure.
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
Q Best country to import medical devices into Europe Other Medical Device and Orthopedic Related Topics 0
M Best accreditation body for AS9100D Lead facility auditor? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Best profilometer for the money General Measurement Device and Calibration Topics 22
P Best Global Option to become an OBL/PLM/Virtual medical device brand in 2020 Other Medical Device Regulations World-Wide 3
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
A What are Practical data center best practices IEC 27001 - Information Security Management Systems (ISMS) 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
S Best software for customer support/complaints? Customer Complaints 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Informational MHRA launches consultation on how to best engage patients and the public Medical Device and FDA Regulations and Standards News 0
optomist1 Mobility Field Manufacturing Best - Worst Practices Manufacturing and Related Processes 5
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
S How to Learn all aspects of ISO 27001:2013 | The best way to grab the knowledge on 27001:2013 (Step by Step) IEC 27001 - Information Security Management Systems (ISMS) 7
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
M Over-labelling - Any requirements or best-practices? Other Medical Device Regulations World-Wide 0
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
M Informational BSI – MDR Documentation Submissions Best Practices Guidelines Medical Device and FDA Regulations and Standards News 0
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
P How to have employees buy-in of quality procedures. Best practices? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Expiry date vs. Best Before Date - Reagents ISO 13485:2016 - Medical Device Quality Management Systems 9
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Best approach to tackle difficult certifications Career and Occupation Discussions 2
E Best Ways to Close a Project APQP and PPAP 3
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
C What is the best ISO 22000 template pack to purchase? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
