Best way to evaluate the differences between 2 gauges
0
02SCvette
I am being asked to evaluate the differences between 2 gauges and the best way to qualify the new gauge.
The assembly involves 2 plastic parts that are snapped together within seconds of being molded.
The test is to record the amount of force it takes to unsnap the parts.
The original tester is a force gauge with a custom holding fixture.
The new tester is a different model force gauge with a new custom design holding fixture. (The customer supplied both holding fixtures and motorized force test stands)
One of the issues is repeatability. The first test value is typically higher than the results if the same 2 parts are snapped back together and the test repeated. The values seem to stabilize after the initial test so if the first test reported 4 pounds, the 2nd through 10th test would result in a range of 2.5 - 2.7 pounds (just an example).
I believe the holding fixture design change will be the the largest factor. The original design uses an air bladder to grab the part evenly. The new holding fixture uses a cam actuated arm that grabs the part.
So based on this, how should I conduct the GR&R's and rationalize the use of the new gauge.
Your comments would be greatly appreciated. :)
Thanks,
Mike
First, read my blog entry on the comparison of two gages.
Then I recommend that you test and disregard the data from the first test result of each part. Next, randomly assign the parts to a tester for the second test, following by using the other tester for the third test. This will randomly spread any variation caused by differences between the 2nd and 3rd test across both testers.
Analyze the data as discussed in my blog entry.
0
02SCvette
Thank you for the response. I appreciate the information. Since the first value tends to be higher, what type of GR&R would you conduct on each set up? Because the first value is typically higher, I had cycled the parts before beginning the GR&R on the original gauge a few years ago. By doing this the results dropped from over 40% to around 10%. I went with 10 parts, 3 operators, 3 trials.
It has been discussed that we should consider it to be a destructive test since the values are lower after the initial test. Thoughts on using that technique?
Thanks again.
Thanks again.
If the subsequent results after the first stay stable, a standard, crossed R&R study is appropriate. A nonreplicable, nested study is only appropriate if the results continued to drop.
The R&R study is focused on the measurement variation, not the mean. As long as the parts stabilize, you are in good shape.
D Which Indicator is Best to Evaluate our HR Training Programs? Training - Internal, External, Online and Distance Learning 7
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Best profilometer for the money General Measurement Device and Calibration Topics 22
P Best Global Option to become an OBL/PLM/Virtual medical device brand in 2020 Other Medical Device Regulations World-Wide 2
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
A What are Practical data center best practices IEC 27001 - Information Security Management Systems (ISMS) 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
S Best software for customer support/complaints? Customer Complaints 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Informational MHRA launches consultation on how to best engage patients and the public Medical Device and FDA Regulations and Standards News 0
optomist1 Mobility Field Manufacturing Best - Worst Practices Manufacturing and Related Processes 5
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
S How to Learn all aspects of ISO 27001:2013 | The best way to grab the knowledge on 27001:2013 (Step by Step) IEC 27001 - Information Security Management Systems (ISMS) 7
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
M Over-labelling - Any requirements or best-practices? Other Medical Device Regulations World-Wide 0
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
M Informational BSI – MDR Documentation Submissions Best Practices Guidelines Medical Device and FDA Regulations and Standards News 0
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
P How to have employees buy-in of quality procedures. Best practices? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Expiry date vs. Best Before Date - Reagents ISO 13485:2016 - Medical Device Quality Management Systems 9
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Best approach to tackle difficult certifications Career and Occupation Discussions 2
E Best Ways to Close a Project APQP and PPAP 3
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
C What is the best ISO 22000 template pack to purchase? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
M Best Type of Grease for Vex Plastic Gears Manufacturing and Related Processes 5
