Best Way to Tolerance a Cylindrical Section on a Part (Customer's Design and Drawing)
achorste
Hi all,
I'm not sure if I'm in the correct forum section here, butit seemed the best choice I could see, but anyway - I was looking for some advise from the experts:
We have cylindrical section on on of our parts we make for a customer (it's the customer's design and drawing). We have have an issue with the diameter of this cylindrical section at one point (undersize).
The drawing itself defines the diameter at one end of this cylinder, but does not mention any other points.
What would be the best way to identify on a drawing that the diameter (and tolerance) applies to the whole cylinder and not just at one point?
I've considered cylinricity for this purpose, but from what I can remember, this doesn't define the diameter (for example if the diameter was at bottom limit at the top section, applying cylindricity to the whole cylinder would allow for the product to be undersize at other sections).
Any help would be greatly appreciated! :D
Stijloor
Re: Best Way to Tolerance a Cylindrical Section on a Part (Customer's Design and Draw
Hi all,
I always start with asking what dimensioning standard does apply to your customer's drawing? Do you know?
Stijloor.
Dave Dunn
Hi all,
As Stijloor mentioned, it could depend on the standard that the drawing is made to, but per ASME 14.5M if there's not a note on the dimension (such as x plus draft, x minus draft, at theoretic sharp corner, etc.) then the dimension as you described it already applies to the entire length of the feature.
Cylindricity measures the form of your cylinder, but does not control the size. If you picture two theoretically perfect cylinders that run parallel to each other that encompass all the surface points of your part, the distance between the two theoretic cylinders is the cylindricity value. Since the standard plus/minus tolerance already controls form as well as size, adding cylindricity only has an effect if the cylindricity tolerance is smaller than the total dimensional tolerance. This is called refinement of form.
According to ASME14.5M, Rule 1 states:
“Where only a tolerance of size is specified, the limits of size of an individual feature
prescribe the extent to which variations in its form – as well as in its size- are allowed.”
bobdoering
Stop X-bar/R Madness!!
It's also good to know the usage of the part. Sometimes the print is not clearly dimensioned in spite of the dimensioning standard the customer used. Is it a fit or mating part? True position to MMC meaningful? How do they intend to test it? Pins? CMM? Makes a difference....thanks to fit.
How it is used and how the customer intends to qualify the part should be on the top of your list of questions.
dgeesaman
Agreed. If it's a post or a through-hole, they may be using only one end of it as a pilot, and the rest of the cylinder is a manufacturing simplification. In these cases it's helpful for the designer to use a tolerance zone.
David
R BMC (Best Measurement Capability) exceeding Tolerance! Measurement Uncertainty (MU) 8
D Best Gage R&R (GR&R - GRR) Method for Product Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Best profilometer for the money General Measurement Device and Calibration Topics 22
P Best Global Option to become an OBL/PLM/Virtual medical device brand in 2020 Other Medical Device Regulations World-Wide 2
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
A What are Practical data center best practices IEC 27001 - Information Security Management Systems (ISMS) 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
S Best software for customer support/complaints? Customer Complaints 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Informational MHRA launches consultation on how to best engage patients and the public Medical Device and FDA Regulations and Standards News 0
optomist1 Mobility Field Manufacturing Best - Worst Practices Manufacturing and Related Processes 5
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
S How to Learn all aspects of ISO 27001:2013 | The best way to grab the knowledge on 27001:2013 (Step by Step) IEC 27001 - Information Security Management Systems (ISMS) 7
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
M Over-labelling - Any requirements or best-practices? Other Medical Device Regulations World-Wide 0
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
M Informational BSI – MDR Documentation Submissions Best Practices Guidelines Medical Device and FDA Regulations and Standards News 0
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
P How to have employees buy-in of quality procedures. Best practices? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Expiry date vs. Best Before Date - Reagents ISO 13485:2016 - Medical Device Quality Management Systems 9
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Best approach to tackle difficult certifications Career and Occupation Discussions 2
E Best Ways to Close a Project APQP and PPAP 3
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
C What is the best ISO 22000 template pack to purchase? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
