Bias Study - How can I calculate significant 't' value? Page 87-90 of MSA manual
E
Ehsan Heidari
How can I calculate significant t value (look at P87,88,89&90 3th edition of MSA manual)?
E
Ehsan Heidari
Re: Bias Study
See the Stability tab in the file attached to my blog entry. Scroll to the bottom and you will find the bias study calculations.
Thank you Minner for your quick response! but as I asked in page 89(3th edition of MSA manual) are written :"t(v,[email protected]/2) is found using the standard t tables." can you explain it for me?
Re: Bias Study
Thank you Miner for your quick response! but as I asked in page 89(3th edition of MSA manual) are written :"t(v,[email protected]/2) is found using the standard t tables." can you explain it for me?
v means the degrees of freedom in the sample. This is typically n - 1 where n is the sample size.
@ means the alpha value. This is the amount of acceptable risk that you will make an incorrect conclusion that you have statistical significance when it is not. Alpha is normally set at 0.05.
E
Ehsan Heidari
Re: Bias Study
Ok, How can I calculate it? Or I saw your file, it is so useful but I have a question:
You calculate the t(bias) and t(critical) and explain for acceptable most t(bias) < t(critical) , but in MSA manual we have different chart(enclosed), what`s the relation between it and your formula?
Re: Bias Study
Significant t Value (two-sided) and t(critical) mean the same thing.
The 95% confidence limits of the Bias are additional values that are not included in my Excel file. See Wikipedia reference-linkConfidence interval.
E
Ehsan Heidari
Re: Bias Study
OK Minner,
1- How can I calculate 95% confidence limits of the Bias?(I want t table)
2- therefore in stability, after drawing Xbar-R diagram, I should to calculate t(bias) and t(critical) and if t(bias) < t(critical), it`s good and my work in stability is finished?
G
Grecu
I'm haveing the same problem , I don't Know how to calc. the confidence interval and I can not find this T Table.
:nopity:
harry
:nopity:
Pending further response from the experts in this field, you may want to go through the similar discussions in this thread: Bias Study Confidence Intervals - Page 88 of the AIAG MSA manual
't' table is given by Miner in post #11
There are a few more threads (good reading) on the same topic in the 'similar discussions' box below the page. Just scroll down this page.
E
Ehsan Heidari
Thank you Miner, I saw your post and I understand how can I calculate t(critical) but my last question is : "for setting calibration schedule I should use you formula(in your excel file) or Bias limitation in P88 Manual?:"
Thank Miner
T Bias & Linearity Study - How to calculate the P value for the Average Bias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
G Bias & Linearity Study and the Uncertainty of Standards Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
E Bias and Type 1 Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Conducting a Bias Study for a CMM with no Traceable Master or Reference value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Doubt on Bias study for EOLT (End Of Line Tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
kedarg6500 Bias Study-Finding degree of freedom-P 92 of MSA manual 4th Ed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Linearity and Bias Study Compliance Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
T Bias Study - Use of 't' statistic - Page 88 item 8 of v4 of the MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
L Recommend a 3rd Party Certifier for Master Value in Linearity & Bias Study General Measurement Device and Calibration Topics 0
B In a Linearity Study covering the operating range is it necessary to do Bias Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Measurement BIAS Study - No Measurement Variation Unacceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Selecting a Sample and Determining the Reference Value for a Bias Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Linearity and Bias Study - Bias Study fails - Seeking advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Do we need to perform Stability, Linearity & Bias study for Attribute data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Is minitab 'AIAG compliant' to perform GR&R, linearity and bias study? Using Minitab Software 4
S Bias Study Confidence Intervals - Page 88 of the AIAG MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Bias - Upper and Lower control Limit - Bias Study page 88 of the MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M MSA - Bias Study - Is there any easy method to follow and apply? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
optomist1 Data Bias - Surveys Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Hypothesis test for Bias, not for GRR. WHY ?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Wes Bucey A rant against gender bias wherever it appears Career and Occupation Discussions 4
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Bias formula in MSA 4th Edition vs 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
E Company-wide MSA - Measurement Equipment Bias, Linearity & Stability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
0 The Uncertainty of an Estimate of the Bias ISO 5725-1 - Help Measurement Uncertainty (MU) 8
M Are Bias, Stability, and Linearity studies required by TS 16949 7.6.1? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
E Gage Linearity and Bias Questions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A What is Final Bias? Bias - [σb * (tv, 1-α/2)] ≤ 0 ≤ Bias + [σb * (tv, 1-α/2)] Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Customer Demands (MSA=Bias + GRR/2). Can somebody explain what it means? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
X Bias Analysis issues in MSA Fourth Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Gage Bias and Linearity - How to interpret the Minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S MSA 4th Edition formats in Excel wanted - GR&R, Bias, Stability and Linearity Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Degrees of Freedom - How to calculate degrees of freedom and bias General Measurement Device and Calibration Topics 3
Q What qualifies as Control of Bias GLPs 21 CFR 58.120? US Food and Drug Administration (FDA) 1
S Bias Calculation in Excel Worksheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Linearity, BIAS & Stability - How many studies do I need to do for a device? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R EMP (Evaluating the Measurement Process) Studies for Bias Effect Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 2: Bias Imported Legacy Blogs 4
L Gang Fixturing - Bias vs. Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S How to calculate Bias - MSA Third Edition book on page 85 to 88 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Bias example-about Df=10.8 - Where to find the df table Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Stability, Bias and Linearity samples - Measurement Systems Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K CI (Confidence Interval) for bias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M When to use Linearity and Bias - appropriate for paper tensile strength? Quality Tools, Improvement and Analysis 6
RoxaneB How to Handle Emotional Bias during Upcoming Audit? Internal Auditing 12
