Bias Study - Use of 't' statistic - Page 88 item 8 of v4 of the MSA manual
tdvd101
Page 88 item 8 of v4 of the MSA manual (and page 86 item 6 in V3) states that the t statistic (= tbias) should be calculated. It seems to me that the only values that are used in the examples given in the manual to calculate the 95% confidence intervals are the product of the significant t value (from t tables with given degrees of freedom) and the standard error of the mean.... so what is the point in calculating the t-statistic if it is not used?
I wonder if anyone could throw some light on this for me?
Re: Bias Study - Use of t statistic - Page 88 item 8 of v4 of the MSA manual
The t - statistic is intended to be used for a one sample t - test. The null hypothesis is that bias equals zero.
The t - statistic should be compared to the critical t - value, or to establish the p - value.
If the t - statistic is greater than the critical t - value, or if the p - value is < 0.05, then the bias is considered to be statistically significant. If the t - statistic is less than the critical t - value or the p - value is greater than 0.05, bias is not statistically significant.
tdvd101
Thanks Miner.. I think I understand the principle, but can't see how it is used in the MSA manual (sorry, must be dim!). As I see it, you work out the number of degrees of freedom (in their example 14 - using v4 data from the MSA manual); find the significant t-value for alpha = 0.05 2 tail from t-tables (in their example giving 2.14479 for 14 degrees of freedom); then multiply the significant t value by the standard deviation of the mean (ie 2.14479 x 0.0547 = 0.1173) and finally add and subtract this from the average bias to give upper and lower limits respectively (ie 0.124 and -0.110). If the bias lives within this range then the bias is not significant. Would it be possible to give an example using the data in the MSA manual to show where the t statistic (of 0.12) is used in the calculation?.. Sorry to be a pain....!
debyang
The t value=0.12 is supposed to be used to derive the p value. But the manual did not show it. As before, the MSA 4th edition still has some confusion left.
tony s
Information Seeker
According to page 88, no. 9: "Bias is acceptable (statistically zero) at the @ level if - the p-value associated with tbias is less than @."
My question would be, how can I calculate the p-value?:frust:
Hope you can help us on this.
tony s
Information Seeker
Thanks Miner.
I tried to supply the computed df = 14, t value = 2.1448, (see page 92 also of the MSA AIAG 4th Ed) on the Stat Trek T Distribution Calculator and resulted to a value of cumulative probability = 0.9750. I'm not sure if this is the pvalue.
Does this mean that the bias is not acceptable since the pvalue is greater than @ (as stated in page 88)?
Please help me to clarify. Thanks
The table that you cited uses an alternate (i.e., older) approach to p-values. Because it was more difficult to manually calculate a p-value, the common practice was to determine the critical t-statistic (i.e., the value of the t-statistic for a p-value = alpha). The actual, calculated t statistics was then compared to the critical t value. If the calculated value was greater than the critical value, the test was significant.
In table III-B 2, the calculated t statistic was 0.12. This is smaller than the Significant (critical) t value of 2.14479, so the bias is not determined to be significant. If you enter 0.12 into the calculator, you will get 0.5469. The p-value is 1-0.5469 = 0.4531. It is actually slightly different because the Stat Trek calculator is for a 1-tailed test, and the book example cites a 2-tailed test. You would need an appropriate table or a different calculator that does 2-tailed probabilities.
G Bias & Linearity Study and the Uncertainty of Standards Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
E Bias and Type 1 Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Conducting a Bias Study for a CMM with no Traceable Master or Reference value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Bias & Linearity Study - How to calculate the P value for the Average Bias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Doubt on Bias study for EOLT (End Of Line Tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
kedarg6500 Bias Study-Finding degree of freedom-P 92 of MSA manual 4th Ed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Linearity and Bias Study Compliance Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
E Bias Study - How can I calculate significant 't' value? Page 87-90 of MSA manual Capability, Accuracy and Stability - Processes, Machines, etc. 18
L Recommend a 3rd Party Certifier for Master Value in Linearity & Bias Study General Measurement Device and Calibration Topics 0
B In a Linearity Study covering the operating range is it necessary to do Bias Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Measurement BIAS Study - No Measurement Variation Unacceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Selecting a Sample and Determining the Reference Value for a Bias Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Linearity and Bias Study - Bias Study fails - Seeking advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Do we need to perform Stability, Linearity & Bias study for Attribute data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Is minitab 'AIAG compliant' to perform GR&R, linearity and bias study? Using Minitab Software 4
S Bias Study Confidence Intervals - Page 88 of the AIAG MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Bias - Upper and Lower control Limit - Bias Study page 88 of the MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M MSA - Bias Study - Is there any easy method to follow and apply? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Hypothesis test for Bias, not for GRR. WHY ?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Wes Bucey A rant against gender bias wherever it appears Career and Occupation Discussions 4
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Bias formula in MSA 4th Edition vs 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
E Company-wide MSA - Measurement Equipment Bias, Linearity & Stability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
0 The Uncertainty of an Estimate of the Bias ISO 5725-1 - Help Measurement Uncertainty (MU) 8
M Are Bias, Stability, and Linearity studies required by TS 16949 7.6.1? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
E Gage Linearity and Bias Questions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A What is Final Bias? Bias - [σb * (tv, 1-α/2)] ≤ 0 ≤ Bias + [σb * (tv, 1-α/2)] Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Customer Demands (MSA=Bias + GRR/2). Can somebody explain what it means? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
X Bias Analysis issues in MSA Fourth Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Gage Bias and Linearity - How to interpret the Minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S MSA 4th Edition formats in Excel wanted - GR&R, Bias, Stability and Linearity Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Degrees of Freedom - How to calculate degrees of freedom and bias General Measurement Device and Calibration Topics 3
Q What qualifies as Control of Bias GLPs 21 CFR 58.120? US Food and Drug Administration (FDA) 1
S Bias Calculation in Excel Worksheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Linearity, BIAS & Stability - How many studies do I need to do for a device? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R EMP (Evaluating the Measurement Process) Studies for Bias Effect Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 2: Bias Imported Legacy Blogs 4
L Gang Fixturing - Bias vs. Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S How to calculate Bias - MSA Third Edition book on page 85 to 88 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Bias example-about Df=10.8 - Where to find the df table Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Stability, Bias and Linearity samples - Measurement Systems Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K CI (Confidence Interval) for bias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M When to use Linearity and Bias - appropriate for paper tensile strength? Quality Tools, Improvement and Analysis 6
RoxaneB How to Handle Emotional Bias during Upcoming Audit? Internal Auditing 12
S If I do Linearity and Bias Studies, are Stability Studies Required? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
