Big problems with Inspection - Manual Operation - Needs experts
TheRiddle
Hello all!
how's your day?
I'm working for lollipops Industry as quality control leader..
my team in packaging department have a problem with inspection
1- we package lollipop in cans with 50 lollipops manually (problem in the count), sometimes it may be 47 lollipop in the can, sometimes It 55, sometimes 45
2- visual inspection (problem in defects)
so we have a lot of defects 1% defects in the box
we have 100% inspection but we still have defects .. It's so hard to turn our process to be automatic packaging .. by the way we produce more than 5000 cans per day
so how can we pass the problem of the manually counter of lollipop?
and how can we pass the lollipop defects in the cans?
G
Gert Sorensen
Re: Big problems with Inspection needs experts
Hi, and welcome to the Cove.
I can't tell you about the defects, but perhaps you can elaborate a bit about the kind of defects? That may help you to get more qualified answers.
Regarding the count, the easiest way to address that would be to weigh the boxes. You should be able to establish a limit that is easy to verify.
Alexisss
Hello all!
how's your day?
Hi!
for the packaging problem, use scale and weigh the box with the contents!
for the defects, can you give us a couple of examples? are there defects at the cans or the lollipops? When you say 1% defects in the box, you mean 1% of the boxes are defective? Cause if you got 1% defects in the box and the box has 50 pcs, then you got 0.5 defects per box, which doesnt sound ok...
thanks
qusys
Hello all!
how's your day?
For the question 1, I agree with the other covers.
In any case it seems strange that you cannot find an automatic solution to package the product. Is it an organization choice or did you have already try automatic solution that did not satisfy you?:bigwave:
TheRiddle
thank you for your attention and replay
I have a lollipop defects I know the root cause but we cant solve the root cause because it will be expensive, because we have old machines and we need to change it and I will attach a pic of our defects .. so my problem is how to not deliver the defects to our customer
we are already weighing the boxes but we still have the problems
by the way one of our critical problem is the empty wrapping which the customer in the boxes and they think that we are cheating them
Hi!
thanks
thank you Alexissss
we are already weighing the boxes but we still have problem in the count
and the defects in the lollipop.. we have 1% of the boxes contain lollipop defects
TheRiddle
the company can't use automatic solutions because we don't have the facilities and the money to build new automatic system. I'm suffering with that but i have to think positive
qusys
Undestood.
As to the wrong number of lollypops in the cans, I think that you could adopt a solution to modify the can, given that you are in cost reduction to rquest capitals to buy automatic equipment for packaging.
You could insert in inside the can a sort of a "coin" with holes, so that you can insert the lollupops inside this hole. In a can you can put two/three layers and have the right quantity inside each one.
This method could be considered a sort of "poka yoke", because the operator immediately check if a "hole" is missing of the related lollypop. :bigwave:
H
Hodgepodge
Two possible solutions here:
1) Weigh the lollipops, then put them in the box. The difference in the weight of the boxes and or "empty wrapping" could be misleading.
2) Use a scale that measures to a greater accuracy.
True Position
If the piece price is low enough it may be cheaper to just write 50 on the box and set your counting scale and automated counting system to 52 or 53 pieces. Most of your customers get slightly more then they ordered, some get just what they ordered and a couple get significantly more.
While your lolipop cost is higher you save significantly on inspection and customer complaints. I know bolt suppliers who do similar.
TheRiddle
Undestood.
our lollipop is looklike balls what about a sheet of paper between groups of lollipop each group have 10 lollipops ????.. I will try to do that
can you tell me more information about the scale?
thank you for your support:) but the problem is that our lollipops are expensive :(
1 A New Job - Replaced a QM who passed away - BIG Problems Quality Manager and Management Related Issues 25
D Big companies suffer from quality management system? ISO 13485:2016 - Medical Device Quality Management Systems 1
K IoT, AI, Big Data and National Strategies of Other Countries (in your country, do you have any?) IEC 27001 - Information Security Management Systems (ISMS) 12
Ninja Getting eaten by Big Business - My company was bought by a huge multinational Coffee Break and Water Cooler Discussions 54
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
J What's the big picture on Notified Bodies? EU Medical Device Regulations 4
H Interesting Article:Weak Supplier Relations Costing Big 3 Automakers, Nissan Billions World News 4
L Continental Automotive (or any other big German OEM) APQP list wanted VDA Standards - Germany's Automotive Standards 5
A VSM: Between OP1 and OP2 there is a big conveyor. How to represent that on VSM?? Lean in Manufacturing and Service Industries 6
Q ISO 9001 - 3 BIG questions to help a Newbie's Sanity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Electrical Surgical Tool with Big Metal Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Setup Time Reduction Project - How big should my team be? Six Sigma 2
AnaMariaVR2 Big Tobacco Lawyers going after Big Food US Food and Drug Administration (FDA) 1
AnaMariaVR2 Big Data The Reading Room 4
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
F ISO 9001 Certification for a Big Government Entity - One Certificate for each Dept.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T The best way to pull some meaningful stats from a really big project? Using Minitab Software 3
S How big is your Medical Device Technical File? CE Marking (Conformité Européene) / CB Scheme 3
Manix Engaging 'Big' Suppliers in Quality Improvement Supplier Quality Assurance and other Supplier Issues 3
A When a Company is Too Big for Quality Service Industry Specific Topics 20
A How Big/How Small - Size limitation on a company being ISO 9001 certified? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
AnaMariaVR2 3 Regulations that Could Have a Big Bearing on Pharma in 2011 US Food and Drug Administration (FDA) 0
M Gage R&R for Big Parts - Approving a Variable Gage using only 1 Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N G8D (the form) - No one will want to use a big, long form Problem Solving, Root Cause Fault and Failure Analysis 7
Marc Microsoft Losing Big To Apple On Campus After Work and Weekend Discussion Topics 18
Marc Google Bargains Away Net Neutrality - Big Business Winning After Work and Weekend Discussion Topics 1
Stijloor "Big Brother" Google? World News 1
M ISO 29001 Certification Industry - How big and who are the players? Other ISO and International Standards and European Regulations 2
G First time flyer - My big concern other than crashing is air sickness! Coffee Break and Water Cooler Discussions 41
J Internal Audit Teams - How big the audit team should be and who should be on it General Auditing Discussions 6
A The ?Big D? (aka Dallas, TX) becomes the ?Green D? Other ISO and International Standards and European Regulations 3
T The "Big Three" can do something right! World News 11
S The Big 3 - Customer Specific Requirements Customer and Company Specific Requirements 6
Marc The end of the road for U.S. carmakers? Are the Big Three worth saving? World News 27
R Can I use Nonparametric Method to big samples? Statistical Analysis Tools, Techniques and SPC 22
Wes Bucey Big Brother! - Even in your color laser printer After Work and Weekend Discussion Topics 15
U SPC, The Big Picture Statistical Analysis Tools, Techniques and SPC 10
Stijloor ASQ's (American Society for Quality) Next Big Thing...... ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 16
C Gutting the Control Plan of all details and and getting it accepted by the big 3 FMEA and Control Plans 11
H Big Batch (Large Lot) Sampling - Label Printing - MIL-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
J Auditor training - Is there a big difference between auditing ISO 13485 & ISO 9001? ISO 13485:2016 - Medical Device Quality Management Systems 8
A My Company wants to Implement ISO 9001-2000 and become Certified - The Big Start ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
ScottK Local Community Message Board - Big Brother? Coffee Break and Water Cooler Discussions 18
ScottK Is using a 3rd party auditor for supplier audits a big trend? Supplier Quality Assurance and other Supplier Issues 14
Marc Big Three get March 2007 U.S. sales beating, Toyota cheers World News 0
L Big Shipping Error - Shipped without the CE mark on them - Need advice! CE Marking (Conformité Européene) / CB Scheme 5
D Big *ss Fans World News 6
J BIG 3 customer asks us - Will TS 16949 make you more effiecient? IATF 16949 - Automotive Quality Systems Standard 4
O PPAP Process Map - Does anyone map out the PPAP process for the Big Three? Process Maps, Process Mapping and Turtle Diagrams 2
Marc Detroit's Big Three seek White House help World News 6
