Big problems with Inspection - Manual Operation - Needs experts
TheRiddle
#21
You shall do a research because there are many companies that provides ad hoc solution.
However, I did not understand.
I thought you had the problem of counting of the lollipops to put in the envelop.
My idea went in that sense.
this is the can that I have problem with
DEAD LINK TO A GRAPHIC REMOVED
somashekar
#22
I guess you have resource of manual labor to assign and train to the packaging section and provide them simple tools and solutions.
My Suggestion:
Get some simple trays made which have 10 cavities that can hold 5 units each and this 5# can be easily and visually seen and counted. Let a counting person place 5 units in each of the 10 cavity of a tray and check same time the count and place 1 extra in the middle of the OK tray.
The packer person will pack all contents when he sees the centre unit in the tray and return empty tray back to the counting person. This way each pack will have atleast 50 or 51 units (your counting problem solved) and the trays can be reused over and over again.
See how it can work for you and how your people will appreciate the ease and method and adopt it with simple training.
By the way can you explain your counting of 50 units and the can packing process steps.
TheRiddle
#23
My Suggestion:
Great Idea:applause: but i think it may be increase the cycle time of production
the count operator is already collecting 5 lollipop and put it in the can without the trays making 50 but we don't have the accurcy with counting:confused:
somashekar
#24
Oooooh OK, but you and me do not know if he is putting 9 times or 11 times making it 45 or 55 ?
About the cycle time, it can only be commented after application and running rather than upfront. Perhaps a simple line balancing is necessary to get the desired volumes run.
I believe counting tasks must not be left to memory of the operator and it must be system built, as well as visible for online supervision.
I also believe that when manual tasks give repeated problems it is good to split the task where one can exercise simple check and correction on the other.
TheRiddle
#25
agreed
I will try to implement that Idea
The Specialist
#26
TheRiddle;
Despite your production-line problems, which I know you are most interested in ‘fixing’…
Can I ask; How are the final packaged products managing to get to the customer?
Are you conducting check-weigh of 100% of packaged product or just a sample?
Are you re-working those products which do not meet weight specifications?
TheRiddle
#27
TheRiddle;
Specialist thank you for your interest
yes there is production-line problems and it's critical problems .. and these problems are the root causes for alot of problems .. it's manual lines and the human mistakes around 40% of these problems .. the managers way here to solve the problems is salary deduction so they are suffering from these problem since the company has been built and they couldn't prevent these problems . I'm newer for this company and the owner asks me to decrease the customer complaint first and there is no facilities in this time to prevent the root causes
there is alot of operators and supervisor and inspector which they produce a thousands of lollipop cans .. we weigh 100% of these cans but we still have the problems with the count
yes we are
msbettyhunt
#28
There is a machine that helps in counting problems while packaging at pdimachinery (bulk-case-pack-by-count). I can't share here the links as per security reasons.
1 A New Job - Replaced a QM who passed away - BIG Problems Quality Manager and Management Related Issues 25
K IoT, AI, Big Data and National Strategies of Other Countries (in your country, do you have any?) IEC 27001 - Information Security Management Systems (ISMS) 12
Ninja Getting eaten by Big Business - My company was bought by a huge multinational Coffee Break and Water Cooler Discussions 54
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
J What's the big picture on Notified Bodies? EU Medical Device Regulations 4
H Interesting Article:Weak Supplier Relations Costing Big 3 Automakers, Nissan Billions World News 4
L Continental Automotive (or any other big German OEM) APQP list wanted VDA Standards - Germany's Automotive Standards 5
A VSM: Between OP1 and OP2 there is a big conveyor. How to represent that on VSM?? Lean in Manufacturing and Service Industries 6
Q ISO 9001 - 3 BIG questions to help a Newbie's Sanity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Electrical Surgical Tool with Big Metal Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Setup Time Reduction Project - How big should my team be? Six Sigma 2
AnaMariaVR2 Big Tobacco Lawyers going after Big Food US Food and Drug Administration (FDA) 1
AnaMariaVR2 Big Data The Reading Room 4
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
F ISO 9001 Certification for a Big Government Entity - One Certificate for each Dept.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T The best way to pull some meaningful stats from a really big project? Using Minitab Software 3
SteveK How big is your Medical Device Technical File? CE Marking (Conformité Européene) / CB Scheme 3
Manix Engaging 'Big' Suppliers in Quality Improvement Supplier Quality Assurance and other Supplier Issues 3
A When a Company is Too Big for Quality Service Industry Specific Topics 20
A How Big/How Small - Size limitation on a company being ISO 9001 certified? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
AnaMariaVR2 3 Regulations that Could Have a Big Bearing on Pharma in 2011 US Food and Drug Administration (FDA) 0
M Gage R&R for Big Parts - Approving a Variable Gage using only 1 Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N G8D (the form) - No one will want to use a big, long form Problem Solving, Root Cause Fault and Failure Analysis 7
Marc Microsoft Losing Big To Apple On Campus After Work and Weekend Discussion Topics 18
Marc Google Bargains Away Net Neutrality - Big Business Winning After Work and Weekend Discussion Topics 1
Stijloor "Big Brother" Google? World News 1
M ISO 29001 Certification Industry - How big and who are the players? Other ISO and International Standards and European Regulations 2
G First time flyer - My big concern other than crashing is air sickness! Coffee Break and Water Cooler Discussions 41
J Internal Audit Teams - How big the audit team should be and who should be on it General Auditing Discussions 6
A The ?Big D? (aka Dallas, TX) becomes the ?Green D? Other ISO and International Standards and European Regulations 3
T The "Big Three" can do something right! World News 11
S The Big 3 - Customer Specific Requirements Customer and Company Specific Requirements 6
Marc The end of the road for U.S. carmakers? Are the Big Three worth saving? World News 27
R Can I use Nonparametric Method to big samples? Statistical Analysis Tools, Techniques and SPC 22
Wes Bucey Big Brother! - Even in your color laser printer After Work and Weekend Discussion Topics 15
U SPC, The Big Picture Statistical Analysis Tools, Techniques and SPC 10
Stijloor ASQ's (American Society for Quality) Next Big Thing...... ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 16
C Gutting the Control Plan of all details and and getting it accepted by the big 3 FMEA and Control Plans 11
H Big Batch (Large Lot) Sampling - Label Printing - MIL-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
J Auditor training - Is there a big difference between auditing ISO 13485 & ISO 9001? ISO 13485:2016 - Medical Device Quality Management Systems 8
A My Company wants to Implement ISO 9001-2000 and become Certified - The Big Start ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
ScottK Local Community Message Board - Big Brother? Coffee Break and Water Cooler Discussions 18
ScottK Is using a 3rd party auditor for supplier audits a big trend? Supplier Quality Assurance and other Supplier Issues 14
Marc Big Three get March 2007 U.S. sales beating, Toyota cheers World News 0
L Big Shipping Error - Shipped without the CE mark on them - Need advice! CE Marking (Conformité Européene) / CB Scheme 5
D Big *ss Fans World News 6
J BIG 3 customer asks us - Will TS 16949 make you more effiecient? IATF 16949 - Automotive Quality Systems Standard 4
O PPAP Process Map - Does anyone map out the PPAP process for the Big Three? Process Maps, Process Mapping and Turtle Diagrams 2
Marc Detroit's Big Three seek White House help World News 6
M Aftermarket and Big Three Supplier - How does this affect the quality system? IATF 16949 - Automotive Quality Systems Standard 3
