Bioburden Monitoring - 'Off the Shelf' Bioburden/Microbiological Monitoring Software
Jimmy2
Does anyone one know of an 'off the shelf' bioburden/ microbiological monitoring software package?
This is for use in an orthopaedic implant cleaning environment within an ISO grade 8 cleanroom.
Cheers
Jim.
Ronen E
Problem Solver
Moderator
Re: Bioburden Monitoring - 'Off the Shelf' Bioburden/Microbiological Monitoring Softw
Cheers
Jim.
No disrespect but I wonder what would the added value of such software be. :confused:
Jimmy2
Absolutely no disrespect taken.
The value would be to have a repository for the significant amout of data I generate from settle plates / contact plates / active air samples / water analysis and bioburden samples.
It would be good to cut the data in many ways in order to show trends, plot graphs against limits etc. Would be useful in response to limit excursions / spikes.
As I use 11137-2 section 4 to rationalise a large number of products to one master product for dose audits I have 2 bioburden sampling regimes which generate a significant amount of data.
I imagine the package would not be that expensive or complicated.
I am no good with databases and the excell spreadsheets I use are a bit rubbish. Just checking of any off the shelf options out there first.
I take it you don't know of one then?
Ronen E
Problem Solver
Moderator
Sorry, but I never came across any such purpose-built software. I was going to suggest a spreadsheet until that point where you dismissed it... Other than that I would have used a general-purpose statistical analysis package, but if you don't already have one in house then the associated costs may be difficult to justify (you could go for shareware / freeware but getting to master it would also consume some resources).
Sorry :(
Jimmy2
No worries. Thanks for your help. Making the spread sheet better and / or using Minitab are two of the options I will explore if no packages to do it exist.
Cheers
Jim.
B Bioburden monitoring for surgical instrument provided non-sterile EU Medical Device Regulations 3
M Biological Monitoring Program Environmental Bioburden Test Method Needed ISO 13485:2016 - Medical Device Quality Management Systems 1
S Bioburden Monitoring Sample Size Increase ISO 13485:2016 - Medical Device Quality Management Systems 4
L Monitoring bioburden on clean room gloves Other Medical Device and Orthopedic Related Topics 1
E Bioburden tests duration and Monitoring of gloves ISO 13485:2016 - Medical Device Quality Management Systems 6
M Bioburden Frequency (sterile MD) Other Medical Device Related Standards 2
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
A ISO 11135:2014, B.1.4, BI resistance x product bioburden ISO 13485:2016 - Medical Device Quality Management Systems 6
D Sterility and BioBurden Testing for Plastics ISO 13485:2016 - Medical Device Quality Management Systems 5
C Sterility and Bioburden Testing - LAL passed under 0.5EU/mL Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
B Radiation Sterilization Dose Audit: Bioburden frequency Other Medical Device Related Standards 1
F Bioburden Testing requirements for Non-Sterile Dental Products EU Medical Device Regulations 6
V Cleanliness/Bioburden for Non-Sterile Gas Path Medical Devices Other Medical Device Regulations World-Wide 7
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
R Simulated product for bioburden testing Other ISO and International Standards and European Regulations 2
C What is the most appropriate Bioburden Test Method for Surgical Gloves ISO 13485:2016 - Medical Device Quality Management Systems 10
M Bioburden numbers and ECA gloves 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Bioburden testing for Class 10000 (Grade C) clean room ISO 13485:2016 - Medical Device Quality Management Systems 1
O Bioburden Testing - Non Sterile Product / Tapes - ISO 11737-1 Other ISO and International Standards and European Regulations 9
P Serial Testing of Bioburden for Medical Devices Other Medical Device Related Standards 2
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
P Frequency of Bioburden Testing EU Medical Device Regulations 3
B BioBurden and EndoToxin Questions Other Medical Device Related Standards 6
M Sterility Testing vs Bioburden Testing - Differences Qualification and Validation (including 21 CFR Part 11) 7
I Bioburden and Endotoxin (LAL) Testing proposal help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Bioburden Count Question - Bioburden is above the alert limit >1 CFU/component avg. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L GB15980-2003 Bioburden Count Trend on Operator Hands Other ISO and International Standards and European Regulations 1
0 Guideline/Method for Raw Material Roll Stock Bioburden Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Bioburden Requirements on Device used on Unbroken Skin Other Medical Device and Orthopedic Related Topics 4
A Microbial Limit (Bioburden)on dry nonwoven that used for making Hand sanitizing wipes ISO 13485:2016 - Medical Device Quality Management Systems 1
D Bioburden and Product Labels - VD Max studies on all the BOMs Other Medical Device and Orthopedic Related Topics 9
H Determining a New Product Bioburden Limit ISO 13485:2016 - Medical Device Quality Management Systems 11
L Validation of transfer materials - Bioburden of items from lab into cleanroom Other Medical Device and Orthopedic Related Topics 2
M Spinal Implant Testing Requirements - Bioburden, TGA & Ion Chromatography 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Establishing alert and action limits for clean room bioburden Other Medical Device and Orthopedic Related Topics 9
C ISO 11737 - Bioburden testing for non-sterile products Other ISO and International Standards and European Regulations 10
S What is a reasonable Bioburden limit? ISO 13485:2016 - Medical Device Quality Management Systems 13
I Microbiological Testing - Bioburden and Identification of Micro-Organisms ISO 13485:2016 - Medical Device Quality Management Systems 2
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Cleanroom Differential Pressure Monitoring, frequent manual observation US Food and Drug Administration (FDA) 6
J Need a contract monitoring Tool General Information Resources 0
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
K Monitoring the identified side-effects and contraindications ISO 14971 - Medical Device Risk Management 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
E Insulation diagram for ECG monitoring and diagnosis system. IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
