Biocompatibility Device Categorization: Priming with Blood
Hi All,
We have devices used for extracorporeal circulation of blood. Some parts of the device are only used for "Priming" of the circuit, which means that said parts come into contact with the priming solution (usually Saline solution), but not directly with the Patient, since they are removed from the circuit before the actual application of the device. Since the priming solution is later mixed with the patient's blood, we consider these parts of the device as having indirect contact to the blood path acc. to Annex A of ISO 10993-1:2009.
The question that arises now: In some cases, the device is primed using blood from a blood preservation (so not the patient's own blood).
Can we still consider These parts of the device as having only indirect contact to the blood path? :confused:Although it technically has direct contact to blood?:confused:
Thanks for the answers
Freddo
planB
Freddo,
if I understood you correctly, you use 2 different priming solutions, which are both not patient blood, that are used in the very same way.
Thus, the nature and duration of patient exposure with regards to your device compartment is independent of the actual composition of the priming solution. Therefore, you should end up with the same device category.
HTH,
Gerhard
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Biocompatibility Test for a Non Contact Medical Device US Food and Drug Administration (FDA) 11
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
D Biocompatibility requirements for a Class IIa medical device CE Marking (Conformité Européene) / CB Scheme 7
T Biocompatibility for "Desktop" used Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 4
J Biocompatibility for Class I Non-Sterile Medical Device EU Medical Device Regulations 2
I Biocompatibility Testing Requirements for a Class I device - Does not contact patient 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
V Biocompatibility of Medical Device Internal Parts Other US Medical Device Regulations 9
M Biocompatibility 10993-1 vs. Sterilization Cycle - Medical Device in EU ISO 13485:2016 - Medical Device Quality Management Systems 6
M Medical Device Biocompatibility Testing - End Product or Components - ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 22
L Biocompatibility of Medical Device Other Medical Device and Orthopedic Related Topics 8
M Predicate Device - Question on Biocompatibility and IEC 60601-1 Testing Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
Watchcat Summary of De Novo Biocompatibility Information, 2015-2018 Other US Medical Device Regulations 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 12
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
K Biocompatibility classification for Lancet CE Marking (Conformité Européene) / CB Scheme 7
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Biocompatibility on aged devices Other Medical Device Related Standards 3
Gamula Biocompatibility GLP conform tests outside China China Medical Device Regulations 1
I Biocompatibility Impact on Autoclaved Silicone Other Medical Device Related Standards 3
D Should Biocompatibility Tests be performed on Production Samples? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R What is the expectation for Biocompatibility Testing when switching Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
planB Biocompatibility: Blue Book Memorandum #G95-1 superseded by new FDA guidance Other Medical Device Related Standards 1
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
R Biocompatibility Test of Blue Gown vs Blue Drape 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R FDA Biocompatibility questions for Surgical Gown 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Biocompatibility testing for nasal prongs made of medical grade silicone 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
J Biocompatibility tests in AAA LAC Laboratory ISO 13485:2016 - Medical Device Quality Management Systems 6
B Biocompatibility for Packaging Materials Other Medical Device Related Standards 3
J Biocompatibility Evaluation component other than Testing Other Medical Device Regulations World-Wide 1
J Grouping Products and Testing Sterile and Biocompatibility - Validating Products Other Medical Device Regulations World-Wide 3
S Laminaria - Is a Biocompatibility Study Required? EU Medical Device Regulations 6
M Biocompatibility in Respiratory Products - Help interpreting whitepaper IEC 60601 - Medical Electrical Equipment Safety Standards Series 22
