Biocompatibility for endoscope external handle/grip
Class 2 endoscope medical device has a flexible lower insertion portion into the human body and upper body which is a grip/handle controlled by the surgeon wearing a glove. The grip/handle is made from plastic which has no contact to the human body. Does it count as indirect contact if the surgeon holds the grip/handle while touching the flexible insertion part during human body entry? Does the grip/handle requires biocompatibility?
Yes, i did read through the ISO 10993-1. Under attachment G: Glossary, contact, i'm unable to identify whether the grip hold is under non-contact or indirect contact. The surgeon will hold the grip with gloves on and it will not be in contact with patient. What i am not sure is if the surgeon touches the grip and touches the insertion part(which enters patient body), does it count as indirect contact?
• Indirect contact – term used for a device or device component through which a fluid or gas passes, prior to the fluid or gas coming into physical contact with body tissue (in this case the device or device component itself does not physically contact body tissue)
• Non-contact – term used for a device or device component that has no direct or indirect contact with the body (e.g., stand-alone software or database), and for which no biocompatibility information would be needed other than confirmation that there is no contact with the human body
Ronen E
Problem Solver
Moderator
It's a risk assessment issue.
I tend to think that standard surgery practices do not allow the surgeon to touch anything and then touch the device part that penetrates the patient's body (especially if it's surgically invasive, i.e. does not just go into the gastrointestinal tract, etc.). If that wasn't the case, it would have been necessary to assess a whole array of scenarios where the surgeon touches all kinds of objects and then the invasive device. I can't, however, confidently dismiss the issue because I don't know enough about OR practices, and I also guess they vary from place to place.
I would document to issue in the risk management file (hopefully being able to dismiss this scenario as unlikely). If you wanted more predictability you could ask the FDA about it in a Q-Sub, but it seems a little disproportional with the issue, and it might take too long. You could ask them informally, but the answer will be pretty much worthless - they make sure to not commit to anything they say/write outside a formal process.
Judy Abbott Biocompatibility requirements for submission to Chile Other Medical Device Related Standards 0
S Validity of biocompatibility reports ISO 13485:2016 - Medical Device Quality Management Systems 4
O ISO10993 - Biocompatibility in medical vacuum systems (vacuum pumps) Medical Device and FDA Regulations and Standards News 2
E Biocompatibility testing of our applied part seems redundant Other Medical Device Related Standards 2
S Biocompatibility requirement for electrode adapters Other Medical Device Related Standards 1
S ASTM F86 x Biocompatibility Issues Medical Device and FDA Regulations and Standards News 1
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
Watchcat Summary of De Novo Biocompatibility Information, 2015-2018 Other US Medical Device Regulations 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 13
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
K Biocompatibility classification for Lancet CE Marking (Conformité Européene) / CB Scheme 7
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
F Biocompatibility Device Categorization: Priming with Blood Other Medical Device Related Standards 1
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Biocompatibility on aged devices Other Medical Device Related Standards 4
Gamula Biocompatibility GLP conform tests outside China China Medical Device Regulations 1
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
I Biocompatibility Impact on Autoclaved Silicone Other Medical Device Related Standards 3
D Should Biocompatibility Tests be performed on Production Samples? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R What is the expectation for Biocompatibility Testing when switching Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
C Biocompatibility Test for a Non Contact Medical Device US Food and Drug Administration (FDA) 11
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
planB Biocompatibility: Blue Book Memorandum #G95-1 superseded by new FDA guidance Other Medical Device Related Standards 1
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
R Biocompatibility Test of Blue Gown vs Blue Drape 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R FDA Biocompatibility questions for Surgical Gown 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Biocompatibility requirements for a Class IIa medical device CE Marking (Conformité Européene) / CB Scheme 7
S Biocompatibility testing for nasal prongs made of medical grade silicone 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
J Biocompatibility tests in AAA LAC Laboratory ISO 13485:2016 - Medical Device Quality Management Systems 6
B Biocompatibility for Packaging Materials Other Medical Device Related Standards 3
J Biocompatibility Evaluation component other than Testing Other Medical Device Regulations World-Wide 1
J Grouping Products and Testing Sterile and Biocompatibility - Validating Products Other Medical Device Regulations World-Wide 3
S Laminaria - Is a Biocompatibility Study Required? EU Medical Device Regulations 6
M Biocompatibility in Respiratory Products - Help interpreting whitepaper IEC 60601 - Medical Electrical Equipment Safety Standards Series 22
S Laminaria - Biocompatibility Study? Imported Legacy Blogs 1
