Biocompatibility for Packaging Materials
benderspeck
Hi All,
I recently received a question about biocompatibility of our packaging materials for permanent implant device. The question was about how we account for extractables regarding how they could negatively impact the biocompatibility of the device over the shelf life period. I have the basic cytotox, sensitization, irritation data, but nothing that would qualify as extractables.
The material we are using is HDPE, which I know has a lonnnnnggg history (pharmaceuticals/food packaging and implants). However, I can't seem to find the data for it. Any suggestions? (I'm trying to avoid running the extractables study)
Ronen E
Problem Solver
Moderator
Hi All,
1. "HDPE" is too generic - you need to relate to the specific grade you are using.
2. Your first stop for information regarding your packagaing materials shold be your supplier (if they're not the manufacturer then this would be the next stop).
3. "Extractables" doesn't mean too much in biocompatibility terms. Even the tests you mentioned typically involve extraction, i.e. extraction is just a tool. Perhaps the intent was "leachables"?... IMO you should begin with a theoretical analysis / evaluation of the risks - what sort of materials originating in the packaging materials may end up in/on the implant, in what amounts, do they pose significant risks, what is the mechanism of transfer for each etc. Once you have a clear view on these aspects, you can start planning bench testing for quantifying, if necessary. Additional biocompatibility testing is only the last step, and you might actually find out / prove that it's not even necessary.
Cheers,
Ronen.
blargon
Extractables & leachables studies are more common with pharma (or if your device has a drug component or is a combination device) rather than med device packaging. Extractables are generally substances that can leach into the packaged container under extreme conditions (like elevated temperature, direct exposure to intense sunlight or harsh solvents, assessed in a controlled extractables study), leachables leach from the device / packaging under more normal conditions.
And here's an extended definition*
? Extractables are chemical entities, both organic and inorganic, that will extract from components of a container closure system or device into solvents under controlled conditions. They are used to identify and quantify potential leachables.
? Leachables are chemical entities, both organic and inorganic, that migrate from components of a container closure system or device into a drug product over the course of its shelf-life.
? Leachables are usually present in drug product matrices as complex mixtures at trace levels relative to the active pharmaceutical ingredient (API).
* courtesy of Dr. Frank Moffatt, 'Extractables and leachables in pharma ? A serious issue'
As Ronen mentioned, 'HDPE' is generic, your supplier should be able to advise. They may have done this testing. Extractables from HDPE could be residual solvents, cleaning agent, lubricants..
planB
Benderspeck,
adding to what the previous poster wrote:
It is your final, permanently implantable device that has to be biocompatible, and _not_ your packaging according to ISO 10993-1:2009. You have to demonstrate that at the point of use your _device_ does not cause any biological reactions which are unacceptable - not your packaging.
To this end, you may want to gather "material characterization" data according to ISO 19883-18:2005, both by your own physico-chemical studies (i.e. leachables and extractables) on your device in its final packaging and after having undergone all manufacturing steps (e.g. including terminal sterilization), as well as relevant literature and prior relevant clinical experience.
Literature on you packaging material like (material safety) data sheets listing its exact composition (e.g. additives like colours, stabilizers and plasticizer, release agents, denesting additives) and its manufacturing (e.g. injection molding) will be necessary to support your conclusions drawn from your won leachables/extractables studies performed on your final device.
HTH,
Gerhard
A Biocompatibility: Selection of worst-case device Medical Device and FDA Regulations and Standards News 1
Judy Abbott Biocompatibility requirements for submission to Chile Other Medical Device Related Standards 1
J Biocompatibility for endoscope external handle/grip US Food and Drug Administration (FDA) 3
S Validity of biocompatibility reports ISO 13485:2016 - Medical Device Quality Management Systems 4
O ISO10993 - Biocompatibility in medical vacuum systems (vacuum pumps) Medical Device and FDA Regulations and Standards News 2
E Biocompatibility testing of our applied part seems redundant Other Medical Device Related Standards 2
S Biocompatibility requirement for electrode adapters Other Medical Device Related Standards 1
S ASTM F86 x Biocompatibility Issues Medical Device and FDA Regulations and Standards News 1
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
Watchcat Summary of De Novo Biocompatibility Information, 2015-2018 Other US Medical Device Regulations 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 13
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
K Biocompatibility classification for Lancet CE Marking (Conformité Européene) / CB Scheme 7
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
F Biocompatibility Device Categorization: Priming with Blood Other Medical Device Related Standards 1
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Biocompatibility on aged devices Other Medical Device Related Standards 4
Gamula Biocompatibility GLP conform tests outside China China Medical Device Regulations 1
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
I Biocompatibility Impact on Autoclaved Silicone Other Medical Device Related Standards 3
D Should Biocompatibility Tests be performed on Production Samples? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R What is the expectation for Biocompatibility Testing when switching Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
C Biocompatibility Test for a Non Contact Medical Device US Food and Drug Administration (FDA) 11
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
planB Biocompatibility: Blue Book Memorandum #G95-1 superseded by new FDA guidance Other Medical Device Related Standards 1
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
R Biocompatibility Test of Blue Gown vs Blue Drape 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R FDA Biocompatibility questions for Surgical Gown 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Biocompatibility requirements for a Class IIa medical device CE Marking (Conformité Européene) / CB Scheme 7
S Biocompatibility testing for nasal prongs made of medical grade silicone 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
J Biocompatibility tests in AAA LAC Laboratory ISO 13485:2016 - Medical Device Quality Management Systems 6
J Biocompatibility Evaluation component other than Testing Other Medical Device Regulations World-Wide 1
J Grouping Products and Testing Sterile and Biocompatibility - Validating Products Other Medical Device Regulations World-Wide 3
S Laminaria - Is a Biocompatibility Study Required? EU Medical Device Regulations 6
M Biocompatibility in Respiratory Products - Help interpreting whitepaper IEC 60601 - Medical Electrical Equipment Safety Standards Series 22
