Hello everyone,
I am currently working towards getting a CE mark for a continuous positive airway pressure (CPAP) device. This device accepts air and oxygen inputs, mixes them into a gas stream, humidifies the gas stream, and then delivers it to the patient through a patient circuit.
My question is about biocompatibility of components of the airstream. I found a whitepaper that covers biocompatiblity for respiratory equipment, and it has been generally helpful. It explained that the common classification of respiratory equipment for 10993-1:2009 is "surface device with mucosal membrane contact". This determinition is because the air, not actual device components, has mucosal membrane contact.
The problem I am having is about which components in the airstream need to be biocompatible. Obviously the patient circuit should be, but what about the metal fittings in the internal pneumatic system of the device? To what extent do these components need to be biocompatible?The whitepaper offers an explanation to this question, but I am having trouble understanding it. I am hoping you all can help. They say that:
I don't know what it means when it starts talking about creating the test articles. Do you? Any advice is appreciated.
** If this topic sounds familiar, it could be because my co-worker posted about it previously here --> Where does Contact begin for Biocompatability?
The materials used as components in some respiratory devices can inherently lead to some failures in the biocompatibility test battery due to the nature of the materials. Some materials such as brass, copper or natural rubber latex, are commonly found to be cytotoxic if extracted as independent samples resulting in concentrations in excess of those found in the actual clinical exposure.
For this reason, it is suggested that test articles be representative of all gas path materials (either assembled or disassembled). Due to complex material configurations, it is often advantageous to extract based on a weight ratio (4 grams/20 mL) rather than a surface area extraction ratio.
