Biocompatibility in Respiratory Products - Help interpreting whitepaper
planB
#11
Roland,
sorry if I was not clear enough.
Let me quote from the European MDD, Article 2:
"Member States shall take all necessary steps to ensure that devices may be placed on the market and put into service only if they do not compromise the safety and health of patients, users and, where applicable, other persons when properly installed, maintained and used in accordance with their intended purpose."
This clearly implies that you have to consider operators - and yes, this involves some degree of workload, which to my experience can be limited as I intended to ppoint out previously.
HTH,
Gerhard
planB
#12
This might be also of interest, taken from the blog of an ISO Technical Committee member responsible for ISO 10993 series revisions:
"Respiratory Devices - a new paradigm in biocompatibility
ISO 10993-1 does not deal well with biological evaluation of respiratory devices ? such as ventilators, masks and inhalers ? which have indirect patient contact via the gas pathway. The current approaches in Part 1 set out requirements which were really intended for indirect blood contact devices such as infusion equipment. This has resulted in regulatory expectations for testing which are infeasible such as requests to conduct extensive biological testing including implants on more than 100 separate internal components of ventilators. In a radical departure, a separate ISO Committee (ISO TC 121) is developing a new ISO 18562 for biological evaluation of respiratory devices. If accepted, these standards will remove indirect contact respiratory devices from evaluation under ISO 10993 ? and usher in a new paradigm which focuses on the composition of the delivered gas rather than the composition of the device itself. This should provide a safety assessment approach based on assessment against acceptable limits of volatile organics and particulates which is not only cheaper and simpler to perform ? but also much more robust and protective of the patient. Respiratory devices were discussed at length in Mishima and TC 194 is fully supportive of the approaches embodied in ISO 18562."
HTH,
Gerhard
milagre
#13
Dear Gerhard,
It's good to see the problem is at least being addressed currently. I really hope I can find a way to not get caught up with "requests to conduct extensive biological testing including implants on more than 100 separate internal components of ventilators". It is definitely worrisome that testing like that seems to be normal for respiratory equipment right now....
Do you have any advice for avoiding that kind of testing? It would certainly save a lot of work, and I'm not even sure if it would be in the budget if we were told to test every component separately.
Ronen E
Problem Solver
Moderator
#14
Dear Gerhard,
You're not required to test every component separately (even under the current paradigm), and besides there are many ways to reduce the testing burden for a given device. The requirement is "Biological Evaluation" and testing is only one avenue. Consult your accreditted test lab, they should be familiar with the above. If they have no previous experience with repsiratory devices, consider looking for another that does.
Cheers,
Ronen.
milagre
#15
Ah alright. The most incite I have gotten on specifically how to test was from the whitepaper, where they talked about creating an extraction medium with ratios of different components from the airstream as the sample to extract from. I contacted one test lab that initially said they were experienced in respiratory products, but it seems that experience may be limited to CPAP masks specifically.
Any recommendations for test labs before I go poking around?
Ronen E
Problem Solver
Moderator
#16
Here are two I would have considered:
http://www.ul-mdt.com/
http://www.namsa.com/Services/Core-Services/Non-Clinical-Testing/Biocompatibility-Testing
Cheers,
Ronen.
K
kanwal
#18
In evaluating biocompatibility of a product, it is essential to understand the interactions the product and its components have with the human body of the patient, the user and others coming in contact with the device or the component.
The interactions can be either through leachates from the device or its components or particles of the device or components.
Hence the issue of biocompatibility of components would be assessed based on the ability to release leachates or particles that can be infused into the atmosphere or transferred through physical contact to which the patient or user is exposed through physical contact.
Ronen E
Problem Solver
Moderator
#19
:topic:
ISO 10993-1 does not deal well with biological evaluation of respiratory devices – such as ventilators, masks and inhalers – which have indirect patient contact via the gas pathway. The current approaches in Part 1 set out requirements which were really intended for indirect blood contact devices such as infusion equipment. This has resulted in regulatory expectations for testing which are infeasible such as requests to conduct extensive biological testing including implants on more than 100 separate internal components of ventilators. In a radical departure, a separate ISO Committee (ISO TC 121) is developing a new ISO 18562 for biological evaluation of respiratory devices. If accepted, these standards will remove indirect contact respiratory devices from evaluation under ISO 10993 – and usher in a new paradigm which focuses on the composition of the delivered gas rather than the composition of the device itself. This should provide a safety assessment approach based on assessment against acceptable limits of volatile organics and particulates which is not only cheaper and simpler to perform – but also much more robust and protective of the patient. Respiratory devices were discussed at length in Mishima and TC 194 is fully supportive of the approaches embodied in ISO 18562."
HTH,
Gerhard
Hi all,
Does anyone out there (Marcelo?) have any inside information on the progress in developing ISO 18562, and expected release dates of the various parts? I saw on the ISO sub-committe's webpage that they are in "30.60" (comment review?) status.
Thanks!
Ronen.
Marcelo
#20
Not sure, I don´t follow ISO TC 121 work as close as I did in the past, but I´ve checked the ISO project portal and the next stage, DIS, is schedule for the beginning of 2016, and publication for the beginning of 2017.
I´ve asked a friend who is the secretary of ISO/TC 121/SC 3 for any other info.
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
Watchcat Summary of De Novo Biocompatibility Information, 2015-2018 Other US Medical Device Regulations 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 12
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
K Biocompatibility classification for Lancet CE Marking (Conformité Européene) / CB Scheme 7
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
F Biocompatibility Device Categorization: Priming with Blood Other Medical Device Related Standards 1
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Biocompatibility on aged devices Other Medical Device Related Standards 3
Gamula Biocompatibility GLP conform tests outside China China Medical Device Regulations 1
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
I Biocompatibility Impact on Autoclaved Silicone Other Medical Device Related Standards 3
D Should Biocompatibility Tests be performed on Production Samples? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R What is the expectation for Biocompatibility Testing when switching Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
C Biocompatibility Test for a Non Contact Medical Device US Food and Drug Administration (FDA) 11
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
planB Biocompatibility: Blue Book Memorandum #G95-1 superseded by new FDA guidance Other Medical Device Related Standards 1
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
R Biocompatibility Test of Blue Gown vs Blue Drape 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R FDA Biocompatibility questions for Surgical Gown 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Biocompatibility requirements for a Class IIa medical device CE Marking (Conformité Européene) / CB Scheme 7
S Biocompatibility testing for nasal prongs made of medical grade silicone 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
J Biocompatibility tests in AAA LAC Laboratory ISO 13485:2016 - Medical Device Quality Management Systems 6
B Biocompatibility for Packaging Materials Other Medical Device Related Standards 3
J Biocompatibility Evaluation component other than Testing Other Medical Device Regulations World-Wide 1
J Grouping Products and Testing Sterile and Biocompatibility - Validating Products Other Medical Device Regulations World-Wide 3
S Laminaria - Is a Biocompatibility Study Required? EU Medical Device Regulations 6
S Laminaria - Biocompatibility Study? Imported Legacy Blogs 1
M Three final products in one biocompatibility test? Other Medical Device and Orthopedic Related Topics 2
S Selecting materials for implants to comply with ISO 10993 biocompatibility Other Medical Device Related Standards 4
S Laminaria Stick (Cervical Dilator) - Biocompatibility Test required? ISO 13485:2016 - Medical Device Quality Management Systems 1
T Biocompatibility for "Desktop" used Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 4
M Biocompatibility Test requirements for 510k - Orthopaedic Implant Screws US Food and Drug Administration (FDA) 2
A Biocompatibility omission justification for FDA 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
Ajit Basrur Is Biocompatibility study performed on medical devices for possible contaminants? Other Medical Device Related Standards 4
