Biocompatibility of Medical Device
L
luloo117117
Question:
1) Is touth brush medical device? If so, does it complied with Biocompatibility requirements?
2) Is paper cup we used at home or at hospital for drining water medical device? If so, does it complied with Biocompatibility requirements?
Roland Cooke
This is a rather bizarre post. :confused:
Toothbrushes, toothpaste, household soap, toothpicks, hairbrushes etc are not typically considered to be medical devices.
For toothbrushes I can't be sure that is the case in every country in the world, but it would be my guess.
As for biocompatibility, any product needs to be safe for use. If that means you need to demonstrate the product is biocompatible, well, that's what you need to do. Note that that wouldn't necessarily mean you would have to do additional testing.
Paper cup? Doesn't sound like a medical device. Look in ISO13485 for the definitions of a medical device.
E
eyeboat
Typically, MDD etc. defines medical device as instrument, etc. intended for diagnostic or therapeutic purposes. ISO 10993 is a good reference even if the item does not meet the definition of medical device. At least I hope my water glass meets it.
MIREGMGR
The OP seems to be rather silly until one re-reads the 13485 definition of a "medical device".
13485's definition should include something like "objects of types that are broadly used in common hygiene procedures and daily life activities by healthy individuals are only medical devices if they are specially adapted to meet a medical need, and/or they are prescribed by or at the direction of a physician."
L
luloo117117
http://www.medicinenet.com/script/main/art.asp?articlekey=51647
The following information on FDA website can answer the question if toothbrush is biocompatible or not.
http://www.fda.gov/cdrh/pdf2/K020776.pdf
“The flment was determined to be biocomgatible using the methods recommended in IS0 10993 Biological Testing ofMedica1 and Dental Materials and Devices.
Summary:
The antimicrobial agent used is the DENTOSANB filament does not raise any new safety or
effectiveness concerns. The biocompatibility and effectiveness of the antibacterial agent was
tested using established scientific methods and test protocols. Therefore, the Medoral Hygienic
Toothbrush with DENTOSANB filaments is believed to be substantially equivalent to the
predicate devices.”
SteveK
When I used to work for a large oral hygiene product supplier, looking after the technical aspects of such items a toothbrushes etc, the main emphasis was that the polymers were "food grade". The same would apply to your cup, a plastic butter container, PET pop bottle etc etc. However, there was a special case were I did some work on softness of bristles for a company supplying very very soft bristle brushes for oral care for people with cancer (I assume oral) - so in this case this may be going over the boundary. However, this was all a shed load of years ago.:2cents:
MIREGMGR
Heh. I finally bothered to look this up in the FDA classification database.
The answer is for toothbrushes is yes. Product Code EFW, Class I, GMP exempt, regulation = 872.6855. As always, patient contact materials are expected to conform to ISO 10993 per guidance memo G95-1 and other guidance info.
The answer for drinking cups is no, unless they're a DAAD (daily activity assist device) for a person with abnormal physical limitations, in which case they're Product Code ILC, Class I, GMP exempt, regulation = 890.5050.
bio_subbu
In addition to above Powered toothbrush is classified in FDA Sec. 872.6865
Powered toothbrush.
(a)Identification. A powered toothbrush is an AC-powered or battery-powered device that consists of a handle containing a motor that provides mechanical movement to a brush intended to be applied to the teeth. The device is intended to remove adherent plaque and food debris from the teeth to reduce tooth decay.
(b)Classification. Class I (general controls). The device is exempt from the premarket notification procedures in subpart E of part 807 of this chapter subject to the limitations in 872.9.
Thanks and Regards
S. Subramaniam
bio_subbu
Question:
Hi
If you look the definition in European Medical device guidance document (Definition of "medical devices”, Definition of "accessory", Definition of "manufacturer" (MEDDEV 2.1/1, 2004 point no 1.1 (d) page No 5), Tooth brush is not a medical device, it considered as a Medical toiletry purpose, find the definition below.
Medical - toiletry purpose
The definition of "medical device" should be understood to include products intended to be used principally for a medical use. Therefore products intended to have a toiletry or cosmetic purpose are not medical devices even though they may be used for prevention of a disease. Examples for products for which a medical purpose can normally not be established:
- tooth brushes, dental sticks, dental floss;
- baby diapers, hygiene tampons;
- contact lenses without corrective function intended to provide another colour to the eyes,
- bleaching products for teeth [needs to be further discussed with regard to products intended specifically for application by dentists]
- instruments for tattooing.
Examples for products, where depending on the circumstances, a medical purpose can be established :
- incontinence products.
Attached is MEDDEV 2.1/1, 2004
Regards
S. Subramaniam
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Biocompatibility Test for a Non Contact Medical Device US Food and Drug Administration (FDA) 11
D Biocompatibility requirements for a Class IIa medical device CE Marking (Conformité Européene) / CB Scheme 7
T Biocompatibility for "Desktop" used Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 4
J Biocompatibility for Class I Non-Sterile Medical Device EU Medical Device Regulations 2
V Biocompatibility of Medical Device Internal Parts Other US Medical Device Regulations 9
M Biocompatibility 10993-1 vs. Sterilization Cycle - Medical Device in EU ISO 13485:2016 - Medical Device Quality Management Systems 6
M Medical Device Biocompatibility Testing - End Product or Components - ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 22
S Biocompatibility testing for nasal prongs made of medical grade silicone 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
Ajit Basrur Is Biocompatibility study performed on medical devices for possible contaminants? Other Medical Device Related Standards 4
M Biocompatibility of Medical Devices (ISO 10993 vs Japan requirement) Japan Medical Device Regulations 1
T Biocompatibility Testing for Implantable Medical Devices according to ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 4
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
Watchcat Summary of De Novo Biocompatibility Information, 2015-2018 Other US Medical Device Regulations 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 12
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
K Biocompatibility classification for Lancet CE Marking (Conformité Européene) / CB Scheme 7
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
F Biocompatibility Device Categorization: Priming with Blood Other Medical Device Related Standards 1
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Biocompatibility on aged devices Other Medical Device Related Standards 3
Gamula Biocompatibility GLP conform tests outside China China Medical Device Regulations 1
I Biocompatibility Impact on Autoclaved Silicone Other Medical Device Related Standards 3
D Should Biocompatibility Tests be performed on Production Samples? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R What is the expectation for Biocompatibility Testing when switching Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
planB Biocompatibility: Blue Book Memorandum #G95-1 superseded by new FDA guidance Other Medical Device Related Standards 1
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
R Biocompatibility Test of Blue Gown vs Blue Drape 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R FDA Biocompatibility questions for Surgical Gown 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Biocompatibility tests in AAA LAC Laboratory ISO 13485:2016 - Medical Device Quality Management Systems 6
B Biocompatibility for Packaging Materials Other Medical Device Related Standards 3
J Biocompatibility Evaluation component other than Testing Other Medical Device Regulations World-Wide 1
J Grouping Products and Testing Sterile and Biocompatibility - Validating Products Other Medical Device Regulations World-Wide 3
S Laminaria - Is a Biocompatibility Study Required? EU Medical Device Regulations 6
