Biological equivalency - Dermal filler
Hi everyone,
I would like to ask you about a dermal filler consist of hyaluronic acid. if additives /preservatives are different from the device presumed to be equivalent although the main substances are the same, is it possible to claim equivalency?
shimonv
You cannot claim equivalency without evidence or evaluation. I suggest you turn to consultancy firm that is able to do a biological evaluation report.
Thanks for your comment.
Both devices shall use the same material and substances according to the guideline; we got confused.
If we prove that this change does not pose a risk, can we claim biological equivalency? Or is it impossible concerning the'' same '' wording in the article?
Raisin picker
You have to demonstrate (not just claim) that the differences do not influence the performance and safety of the device. Especially under MDR (Annex XIV, 3, emphasis by me):
The characteristics listed in the first paragraph shall be similar to the extent that there would be no clinically significant difference in the safety and clinical performance of the device. Considerations of equivalence shall be based on proper scientific justification. It shall be clearly demonstrated that manufacturers have sufficient levels of access to the data relating to devices with which they are claiming equivalence in order to justify their claims of equivalence.
That means, you have to show where you found the exact formula of the equivalent device (can be e.g. IFU od own lab analysis). You have to name the differences and provide evidence that these do not affect the clinical properties.
So, in my opinion, I think you can go that path, but provide a good reasoning. Best check with your NB as soon as possible, since this is most likely a class III device.
Thank you very much for your comment.
''Biological: the device uses the same materials or substances in contact with the same human tissues or body fluids for a similar kind and duration of contact and similar release characteristics of substances, including degradation products and leachables;''
Although the second paragraph lets to justify the differences without any expectation for any characteristic( biological, technical, and clinical) considering performance and safety, in the first paragraph it has been stated that both devices shall use the same material/substances. On the other hand, it has been stated that some issues may be similar rather than same, related to technical and clinical characteristics. We understood that although the manufacturer demonstrates that the differences do not influence the performance and safety of the device, it is not allowed to use another substance/material those different from the device presumed to be equivalent, biologically they must be the same, so biological differences are not allowed to justify.
However, the second paragraph has in contradiction with the third indent of the first paragraph, as you mentioned.
Thanks a lot for your help.
T Biological Evaluation (10993) & Risk Management ISO 14971 - Medical Device Risk Management 9
K Biological indicator system classification under MDR EU Medical Device Regulations 2
B Biological evaluation plan and report Other Medical Device Related Standards 5
L Biological Assessment (ISO 10993-1) Other Medical Device Related Standards 1
A Demonstration of Equivalence - Need for comparing biological characteristics for an SamD EU Medical Device Regulations 1
M Informational Work in progress at the FDA for biological evaluation – Color Hazard and RISk calculator (CHRIS) Medical Device and FDA Regulations and Standards News 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
M Informational MHRA guidance updated to reflect the mDR – Clinical investigations of medical devices – Biological safety assessment Medical Device and FDA Regulations and Standards News 1
Gamula CFDA Biological Evaluation Report China Medical Device Regulations 2
D Biological and Chemical Risks to the user in the Hazard Analysis ISO 14971 - Medical Device Risk Management 1
B Self Contained Biological Indicators as internal PCD Other Medical Device Related Standards 2
M Biological Monitoring Program Environmental Bioburden Test Method Needed ISO 13485:2016 - Medical Device Quality Management Systems 1
B Number of Biological Indicators for Routine Monitoring of ETO Sterilization Cycle Other Medical Device Regulations World-Wide 8
S IV Catheter Biological Evaluation - EtO Residuals - Permanent Contact Definition Qualification and Validation (including 21 CFR Part 11) 2
J Biological Evaluation requirements per ISO 10993 - Medical Device Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 10993 (Biological Compatibility) Approved Materials US Food and Drug Administration (FDA) 23
W ISO 10993 (Biological Evaluation of Medical Devices) for Suppliers Other ISO and International Standards and European Regulations 8
S Requirements of USP24 NF18 1995 for the Biological Test for Plastics Other Medical Device and Orthopedic Related Topics 3
M Biological Indicator Ethylene Oxide Sterilization Other Medical Device and Orthopedic Related Topics 11
D MDD 2007/ - Essential Requirement Checklist - Physical and Biological Properties EU Medical Device Regulations 4
I Glass Packaging Material (Jars) - Chemical, Physical and Biological Controls Manufacturing and Related Processes 1
T How to treat something (biological hazard) you know is there... Food Safety - ISO 22000, HACCP (21 CFR 120) 7
J Effects of substrate on biological indicator organisms US Food and Drug Administration (FDA) 2
K Sample format for Equivalency Protocol /Report Using Minitab Software 5
M 60601-1 3rd Edition Compliance with Particular Standards & Equivalency IEC/EN stds EU Medical Device Regulations 6
S AAMI TIR28:2009 Product adoption & process equivalency for ETO sterilization Other US Medical Device Regulations 2
E Irritation test - Dermal Filler - 52-week implantation study EU Medical Device Regulations 0
F CLASS III - Preparing a registration dossier for a dermal filler Other Medical Device Regulations World-Wide 8
J Are dermal fillers & PDO sutures for aesthetic purpose under CE MDD? EU Medical Device Regulations 6
