Blocking In a DOE
I am running a 10 factor 16 run 2** (10-6) 1/64 fraction resolution III DOE. on a test process to try and uncover the strongest individual test factors that are best able to uncover a leak with our units. There are six operators who perform the testing so I want to block them out so that their individual "noise" wouldn't affect the test results. The DOE is set up with 6 blocks and six replicates
My question is since the runs are randomized, it shouldn't matter that the 6 individual operators will run through the sequence of 16 tests each at the same time rather than running all 96 tests sequentially. I can't think of any reasons but I thought I would hit up some experts.
I attached the DOE matrix for review.
No, it should not matter. The block is on the Operator, not on time nor on noise factors that might be associated with time. Just make sure that each operator follows the random order specific to that operator.
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
S EN 300 328 V2.2.1 page 73 - Receiver Blocking CE Marking (Conformité Européene) / CB Scheme 1
O Receiver Blocking test - EN 301 893/300 328 CE Marking (Conformité Européene) / CB Scheme 4
Ajit Basrur Blocking a Mold Cavity - 16 cavity mold which has been validated for a part ISO 13485:2016 - Medical Device Quality Management Systems 12
S Asterisk in DOE minitab software Using Minitab Software 23
J Selecting factors for screening DoE design Statistical Analysis Tools, Techniques and SPC 8
J Including Repeats in DoE using Minitab Using Minitab Software 5
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 4
K Power point training slides on DOE (Design of Experiments) Wanted Training - Internal, External, Online and Distance Learning 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
M I have 3 different factors - DOE help Statistical Analysis Tools, Techniques and SPC 3
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
R Is there any Excel .xls Spreadsheet available for DOE with 3 factors? Six Sigma 1
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
D Interpretation of DOE interaction plot Using Minitab Software 8
D Minitab - Design combinations (DOE) Using Minitab Software 4
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
N 3 factor - 3 level experiment with DoE and Minitab Using Minitab Software 10
M DOE: Significant factor or not Using Minitab Software 2
P When can we apply DOE (Design of Experiments)? Six Sigma 8
S DOE Analysis - Experiments with 5 Factors Statistical Analysis Tools, Techniques and SPC 11
R [Minitab] DOE Output vs. Actual Data Using Minitab Software 6
P Screening DOE: A coming up headache story Quality Tools, Improvement and Analysis 4
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
V Analysing Results after DOE Using Minitab Software 1
V Analysis of DOE Results and Model Finalization Using Minitab Software 4
J How to Estimate the Number of Replicates on a DOE (Design of Experiments) Six Sigma 5
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
M Injection Moulding Minitab DOE - All P Values are 0 Using Minitab Software 7
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
Z A DOE in Minitab - 3 factors and 3 levels for each factor Using Minitab Software 12
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
B DOE Question: 3 factors with 2 levels and 1 factor with 3 levels Six Sigma 2
Z Help with running 3 factor DOE factor optimization Using Minitab Software 2
H Minitab DOE Analysis of Data and Transforming Using Minitab Software 4
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
P How to analyze DOE: 2 Factor, 4 Level Experiment Six Sigma 7
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
B Analyze 'Factorial Design' or 'Variability' - Difference when used for DOE Analysis? Using Minitab Software 1
L DOE (Design of Experiments) suggestions Using Minitab Software 7
L DOE (Design of Experiments) - Analyse Variation with Minitab Using Minitab Software 5
E 5^2 DOE (Design of Experiments) with 3 Replications, 5 Levels 2 Factors Statistical Analysis Tools, Techniques and SPC 6
