Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports
I
imcglone
#51
Re: Boss doesn't want Nonconformances called Nonconformances in Internal Audit Report
I like to think, perhaps misguidedly that we can work in a cooperative manner.
Typically if during an audit I think that things need to be tightened up or the implementation of a part of the standard is not adequately implemented I will raise an Action on the auditee and advise the team lead/manager. I will agree a time frame for the auditee to complete the action, advise them that I will return to check the action has been completed after the agreed date.
On the rare occasion that the auditee has not complied and cannot give good reason for non-compliance I will then raise a formal non-conformity.
By comparison, my boss the Quality Manager and other members of the team think we should just hit them with a non-conformance there and then.
I believe and generally find that this approach is less confrontational and results in compliance.
Am I incorrect in my approach?
howste
Thaumaturge
#52
There's nothing wrong with cooperation. However with the approach you suggested, I believe you may end up with mostly corrections and not real corrective actions. For the example given by Piningg, the auditee may have the one past-due item calibrated, but the reason it wasn't calibrated to begin with may not be determined. Any other past-due items may not be identified, and there will probably be recurrences with this and/or other equipment.
arios
#53
My experience is the exact opposite...we show the auditor the findings and CAPA's for the findings, and he essentially says "Good job, no problems." IMO, Internal auditors shoud be strongly encouraged to dig - and dig deep -
Agree.....as long as it does not become like digging their own grave :lol:
Picky internal auditors may not be the most popular in their own companies :eek:, but they are necessary.
Q
Quality-Geek
#54
Can you have a documented informal approach? What if these Actions were labeled "OFI" or "Preventive" or "Request for Information" or whatever other less-scary label you want to use?? That way people still do some investigating and make the necessary corrections but aren't raising the level too high for the finding. After all, the entire corrective/preventive action process should be appropriate to the findings, regardless of where/how the findings originated.
arios
#55
I hope the below classification serves as a guidance:
" INTERNAL AUDIT FINDING CLASSIFICATION:
Priority 1 non-conformance (Major):
For the purposes of this audit report, a priority 1 non-conformance (or major NC) includes those findings that fulfill one or more of the following scenarios:
1. Total failure to define, document, or implement an element of the quality system.
2. The existence of situations or products which clearly do not comply with the manufacturer’s and/or customer’s specifications, the ISO XYZ standard, the Quality System regulation, and/or other relevant regulatory requirements, and which were not adequately addressed by the systems for the Control of Non-conforming product and/or the Corrective and Preventive Actions.
3. The Non-correction or inadequate correction of major deficiencies derived from previous audit(s). Also includes repeated deficiencies of same or similar non-conformities from previous audit(s).
Priority 2 non-conformance (Minor):
For the purposes of this audit report, a priority 2 non-conformance includes those findings that constitute QMS deficiencies of a quantity and/or type to conclude that there is minimal probability -- in light of the relationship between quality system deficiencies observed and the particular device and manufacturing processes involved -- that the organization will produce nonconforming and/or defective finished devices or products.
Audit Observations:
For the purposes of this audit report, an observation describes an event that may require further follow-up and/or attention in order to enhance control and/or compliance. Based on its lower severity and/or incidence a correction may be sufficient to address an identified observation, however the auditee is encouraged to evaluate if the identified finding could deserve the initiation of corrective or preventive action(s) based on subsequent information gained after the audit.
Opportunities for Improvement:
For the purposes of this audit report, an opportunity for improvement constitutes a recommendation. The auditee is encouraged to consider the noted recommendations to enhance compliance, fill gaps, clarify procedures, and/or to consider public external reference materials as a benchmark to improve its own established controls and procedures."
The feedback from the cove members is welcome to improve these suggested definitions.
F
foiley
#56
Hi, I can see there is a lot of fruitful debate about what is essentially just a term which which is extremely subjective.
Obviously your manager has assigned a Non Conformance to a catastrophic systems failiure. In the end it is just a name. Every auditor I have ever met have different definitions around non-conformances. Even to the point of defining their own terms about classes of non-conformances...
I use a method of internal auditing where I don't call anything a Non-Conformance. I see auditing as a service, trying to assist the business as well as the compliance aspect. I define the structure within the internal audit report. I am very up front what I condiser acceptable and not acceptable. By the way I refer to a Non-Conformance as Recommendation. As in "I recommend you do something to fix this issue, so you can be compliant."
Auditing is a skill and involves negotiation. Defining non-conformances and when they are raised is part of the audit scope. I don't see there is anything wrong with your bosses request...
2
20110525R
#57
He can call them anything he wants, as long as your procedures reflect that name. Besides, the Registrars Auditors will call them Non Conformances (can you say Corrective Action Requests) when they don't see the terminology matching your Procedures (I figure you are either ISO 9001 or AS9100). Also, when they see you have no Internal Audits with Nonconformances, they're going to dig a little deeper in your procedures and practices, I know I would as an auditor. Auditors love it when management try's to "Lipstick up a Pig".
#58
I think you may be doing things differently than what is accepted practice by many auditors. There shouldn't be any subjectivity in it. We deal in facts. When you say you define what's acceptable, it sounds like you are defining audit criteria yourself, instead of using the organizations' QMS etc. Auditors don't call the shots, management do. Also, what's to negotiate? If you have facts and present evidence, there's no need for negotiation. Do you ever look at the effectiveness of the QMS? You won't have any problems with negotiation if you include that in your audit.
You may wish to revisit your audit methods to get better results and spend less time talking around things in your audits and spend more time bringing answers to management they can act on...
H
horselady
#59
Section 8.2.2 states "The selection of auditors and conduct of audits shall ensure objectivity and impartiality of the audit process". The way we do it here is the Lead Auditor (Quality Systems Mgr), reports to the very top management and doesn't work for the Quality Manager. The Quality Manager and Quality Systems Mgr. work closely together, but occasionally butt heads and keep each other "honest". That way, the auditors (who report to the Quality Systems Mgr during audits) report their findings objectively and impartially. If the QM has a problem with what's found and/or how it was classified, it's discussed with the Quality Sys Mgr (Lead Auditor). I hope this isn't too confusing sounding, it actually works very well and ensures impartiality.
Solinas
#60
Take the opportunity to rename them "Conditions Requiring Audit Proactivity." Then, run around saying in a loud voice how much CRAP you found in the area, and how much CRAP is going on.
Think of how the Powerpoints of the audit results will look!
Bev D Happy (Male) Boss's Day Coffee Break and Water Cooler Discussions 3
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Boss wants customer delivery signature specimen form Customer and Company Specific Requirements 16
Marc FCC boss says he'll SHAME broadband firms for fibbing on speeds After Work and Weekend Discussion Topics 0
J My boss wants me to investigate Mini Tab 15 or 16 - Help! The Reading Room 7
N Boss is too hard on me.... Career and Occupation Discussions 48
B How do I communicate my frustations with my boss ? Career and Occupation Discussions 7
B How do I tell my boss to write neatly without offending her? Career and Occupation Discussions 8
S Boss wants Quality Procedure for ISO 9001 Clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
Chennaiite Punishing your BOSS Funny Stuff - Jokes and Humour 1
R Looking into the eyes of your company's president, CEO, or boss Coffee Break and Water Cooler Discussions 16
Marc Is Your Boss a Bully? He May Be Incompetent Quality Manager and Management Related Issues 1
G Boss' Alarm Funny Stuff - Jokes and Humour 0
Chennaiite A Boss is a Boss? Coffee Break and Water Cooler Discussions 4
S Lessons learned? Asked by my boss to compile a list of lessons learned Preventive Action and Continuous Improvement 33
M How do I tell my boss I'm not qualified to do Internal Audits? Internal Auditing 32
Stijloor Chrysler's Campi (new purchasing boss) will move fast to buy global. World News 11
Stijloor What Your Boss Says and What He Really Means Coffee Break and Water Cooler Discussions 3
S How to ask Leave from your Boss !! Funny Stuff - Jokes and Humour 2
D A suggestion to my boss - What do you think and how will he react? Lean in Manufacturing and Service Industries 46
E My boss wants me to issue a CAR to myself, though I don't feel I am at fault Nonconformance and Corrective Action 27
M Summarise CSR? Boss asked me to design a template to summary the csr IATF 16949 - Automotive Quality Systems Standard 7
T How do I Audit Management Review? Do I audit my boss? Management Review Meetings and related Processes 30
F My boss wants a mix of Procedure and Form - Forklift and Manlift Equipment Document Control Systems, Procedures, Forms and Templates 5
M APQP Case Study? Boss wants to give a workshop on APQP APQP and PPAP 7
GStough What would you do? Former boss needs help General Auditing Discussions 39
W How to show the value of quality department to highest boss ? Career and Occupation Discussions 8
Claes Gefvenberg Unlucky boss... Funny Stuff - Jokes and Humour 7
J A2LA here, my boss wants to open China office now General Measurement Device and Calibration Topics 6
P My boss asked me to make a Quality Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Folks take your time & rate your boss - A link to a 'test' on another site Coffee Break and Water Cooler Discussions 2
M Integration and test - how to convince boss to change approach Customer and Company Specific Requirements 1
P CQT Exam: Info needed - Boss says he'll increase my pay and promotion if I pass Professional Certifications and Degrees 3
C My boss has asked me to improve our recall system - Seeking Ideas General Measurement Device and Calibration Topics 11
T How To Tell My Boss I Have Too Much To Do? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Boss perceives quality is not the front burner topic - How to keep it going? Misc. Quality Assurance and Business Systems Related Topics 10
D QMS (Quality Management System) Manual - The Boss Wants a 4 Page Manual - What to Do? Quality Management System (QMS) Manuals 455
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
G Supplier doesn't accept the complaints Supplier Quality Assurance and other Supplier Issues 20
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
D IEC 60601-1 - Essential performance doesn't make sense IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
S DFMEA when the supplier doesn't have design responsibility APQP and PPAP 15
S Risk Approach doesn't address External Issues (Auditor's Comment) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
B Our NB doesn't accept new clients for MDSAP Canada Medical Device Regulations 8
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
H ISO 9001:2015 Cl. 9.3.1 - General Director doesn't participate in Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L Toyota doesn’t use Six Sigma Six Sigma 1
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
