Boundary of Clause 8.3 - Control of Nonconforming Product
WCHorn
Rubber, Too Glamorous?
#11
Actually my question has two parts:
1) Whether 8.3 clause of standard covers both manufactured and purchased products?
2) We have made one Employee Handbook in which code of conduct are mentioned plus leave taking procedures etc. This handbook is under the HR department. If someone is not following leave procedure then non-conformance should be raised. In our NC form we have to mention ISO standard clause as well. Kindly confirm which clause should be mentioned there? Is this 6.2.1 or something else?
Regarding the second question, I believe we're leading the poster astray. An employee handbook that cites procedures for employees to follow to request and take leave would not be part of the quality management system. In my opinion, this is a human resources issue that is unrelated to the QMS; I don't think any clause of the standard applies to that situation.:2cents:
snappy
#12
You are absolutely right. Thanks.
N
nabilpk
#13
Thanks ssz102
Can you please elaborate more that if a worker had trained then how 8.3 clause fits that???
ssz102
#14
my comment is:
if your employee don't know how to operate to cause NC, that's your training doesn't available
otherwise, the worker had known this operation will cause quality problem, i.e. the worker have awareness but they don't follow procedure to do, and caused the product doesn't comply with the standard, so i think this situation is belong to clause 8.3
welcome to correct for my comments
charanjit singh
#15
I agree with WCHorn. The example of a worker not following the leave procedure is a matter of conduct/discipline as laid down in your appropriate manual. Otherwise it will be mockery of QMS if we try to somehow fit every situation to requirements of ISO 9001
J Boundary Certification - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N True Position of slot Boundary with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Marco Bernardi Concentricity Tolerance: A Unilateral Boundary Situation (Minitab) Using Minitab Software 22
S Statistics of Gage R&R & Boundary Specifications Statistical Analysis Tools, Techniques and SPC 15
T GD&T: Boundary - Callout for an Oblong Hole (Slot) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
T Quality Boundary Samples Manufacturing and Related Processes 12
J Control and Handling of Limit or Boundary Sample - Molding company and we get flash Quality Tools, Improvement and Analysis 6
B Grain boundary effects in alloy depletion analysis - SAE AS7101 requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G Appearance Boundary Standard - Plastic Components Various Other Specifications, Standards, and related Requirements 9
J GD&T - True Position - "Boundary" under the feature control frame General Measurement Device and Calibration Topics 10
D Comparative References are usually Visual Standards sometimes called Boundary Samples General Measurement Device and Calibration Topics 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
D Layered Process Audits - FCA 9.2.2 - Exemption Clause? IATF 16949 - Automotive Quality Systems Standard 5
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S MDR GSPR Clause 17 - Software Requirements EU Medical Device Regulations 2
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
A ISO 13485 - Clause 8.3.3 appropriate actions in response to nonconforming product ISO 13485:2016 - Medical Device Quality Management Systems 2
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
A ISO 41001:2018 - Clause No.8 Operations Part Quality Management System (QMS) Manuals 2
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
R What is meant by Use of COMPONENTS WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT (clause no 4.9) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P Definition of production tooling in IATF16949 clause 8.5.1.6 IATF 16949 - Automotive Quality Systems Standard 4
K ISO 13485:2016, Clause 4.2.3 Medical Device File ISO 13485:2016 - Medical Device Quality Management Systems 4
B Clause 5.1.12 of Technical Standard IEC 62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
