Bracketing for Validation - Processes that share some unitary operations
ifserav
I need some ideas and opinions, we have a bunch of process that share some unitary operations, although some have manual steps and other sutomatic steps, can i validate by unitary operation and avoid a lot of protocols?, any advice.
Thanks in advance.
Sergio ?vila
G
Gert Sorensen
Thanks in advance.
Sergio ?vila
There is no set way of validating a process, this means that you can define the test that will be the best to prove your process is within control. IF you can define a sequence of teststeps that are generic for your processes and explain why these teststeps are valid at various points in the process then by all means do. You might consider identifying these steps up-front (describe the approach in the VP, and identify the requirements and functionalities in the URS) and then validating them at the first teststep for which they are used.
However, at the very least, I would reference the generic teststep at each of the points where that generic teststep is used in order for an inspector/auditor to be able to follow your entire testsequence and verify the validity of that sequence.
I hope this makes sense to you. :bigwave:
v9991
Thanks in advance.
Sergio ?vila
query could have two perspectives, software-application & product/process.
from a software application perspective, we can build a case for avoiding that specific unit operation being excluded from testing in multiple main functions wherever it is used....
i.e., a sub-function or module being validated once, could be used in multiple operations.(considering that sub-function or module is actually well contained to handle all error scenarios)
from product/process perspective, answer has to be NO.
lets consider an example here... lets consider there is a common bulk, which is being either filled/compressed into different strengths/quantities.
the blending of bulk can be cross referenced, if its a common blend, but the compression/filling process MUST to be demonstrated & validated, as the process parameters, change parts are going to be different.
just by qualifying the unit operation, the need for the establishing/proving the process performance does not really go away. UNLESS you have (more than)-adequate means of proving that the new/current product fits into the qualified ranges!!!.
one argument could be process parameters used for the above strengths/quantities are same as that of qualification, but the change parts have to differ or the , if change parts are same, process parameters would differ....
hope this helps.
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
W Bracketing approach Problem Solving, Root Cause Fault and Failure Analysis 0
W Equipment Bracketing Approach US Food and Drug Administration (FDA) 0
Ajit Basrur Could a bracketing approach be used for Gage R & R ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V Can we apply bracketing & matrixing simultaneously for stability studies @ ICH Q1D US Food and Drug Administration (FDA) 1
L Validation of mixers Qualification and Validation (including 21 CFR Part 11) 0
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
A Applying agile model for Computer system Validation Medical Device and FDA Regulations and Standards News 2
H Production Validation- CE Mark ISO 13485:2016 - Medical Device Quality Management Systems 3
Watchcat Software validation vs design V&V? Other US Medical Device Regulations 27
M Initial Importer/Distributor and Software Validation IEC 62304 - Medical Device Software Life Cycle Processes 1
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M Validation of Data verification tool per 21 CFR 820 Quality Assurance and Compliance Software Tools and Solutions 1
G Number of Destructively Tested Devices Needed for Ethylene Oxide Validation Other Medical Device Related Standards 4
E ISO 13485 software validation ISO 13485:2016 - Medical Device Quality Management Systems 7
R SAP B1 Computer System Validation Qualification and Validation (including 21 CFR Part 11) 0
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Y ISO 13485:2015 Software Validation IQ/OQ/PQ ISO 13485:2016 - Medical Device Quality Management Systems 13
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
L Validation without Tolerance Qualification and Validation (including 21 CFR Part 11) 0
shimonv Test Method Validation ISO 13485:2016 - Medical Device Quality Management Systems 10
R Debug mode in software/device validation IEC 62304 - Medical Device Software Life Cycle Processes 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Melissa Process Validation of Rotary Heat Sealer Speeds Design and Development of Products and Processes 4
C Validation of process for releasing the UDI EU Medical Device Regulations 4
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
W Transport validation Qualification and Validation (including 21 CFR Part 11) 4
M Is validation required when consumables are changed Qualification and Validation (including 21 CFR Part 11) 7
C 8.3.4 Verification and Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Transport validation Qualification and Validation (including 21 CFR Part 11) 12
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
P Software verification and validation procedure IEC 62304 - Medical Device Software Life Cycle Processes 6
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 8
C Spreadsheet Validation and Release Qualification and Validation (including 21 CFR Part 11) 2
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
M Sterile packing validation tests to be performed and protocol Other Medical Device and Orthopedic Related Topics 1
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
C ISO 19227 Validation Cost Other Medical Device Related Standards 2
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
D Software validation team Misc. Quality Assurance and Business Systems Related Topics 3
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 4
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
