Brass in medical equipment
EMengineer
Hi everyone,
We are developing surgical equipment (device which holds cardiovascular guidewire) and planning to use brass material as holder. The main question is brass a suitable material for such use? I find it antibacterial but not biocompatible. The contact with patient would be indirect contact with blood (according ISO 10993-1). This part is single use, thus we do not want to use expensive materials (titanium, cobal alloys, etc.), maybe there are alternatives? The main requirement is metal should be soft which allows easy processing. Maybe there is medical grade brass?
EMengineer
After some research what I have found is that brass should not be used where biocompatibility is required. Maybe some manufacturers used "ECO-BRASS" or similar lead free alloys and somehow managed to pass biocompatibility requirements. I found that guidewire used in vascular surgeries sometimes is gripped with grabber made from brass. I was surprised how it complied biocompatibility requirements (should be indirect blood contact which means more requirements to comply) as well as brass hubs used in needles.
planB
Some food for thought:
  1. "medical grade" is a marketing term that does not relate to any legal or standard requirement
  2. There is no restriction to materials, as long as you can demonstrate biological safety of the _final_ medical device within a risk management process when applied according to ist intended use (and foreseeable misuse).
  3. Apart from the (indirect) contact you are claiming based on your device's intended use, the (maximum expected) contact duration is key for you biological risk assessment. Moreover, indirect contact means that adverse biological effect can only be caused by inacceptable quantities of leachables, including particulate matter, released to the patient during use. In case you can address the related biologcal effects with either existing data, or data to be generated, you may be a in a position to substantiate the biocompatibility of you device even when made out of materials not commonly used for this purpose.
HTH,
EMengineer
HTH,
Finally we decided to go with stainless steal 316L (easier to avoid risks related with misuse as you suggested in #2). You gave me some good thoughts in #3. Thank you!
K BS 1400 1961 standard for Brass material Other ISO and International Standards and European Regulations 2
T Bright Dipping Process of Lead Free Brass Balls Gr200. Manufacturing and Related Processes 3
P ASTM B687 Brass Pipe Nipple Standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
H Normalising of Dezincification Resistant (DZR) Brass Manufacturing and Related Processes 3
V Cladding on Brass - Seeking companies that clad on parts such as brass pieces Manufacturing and Related Processes 1
ScottK Brass bar stored in green wood boxes tarnished Manufacturing and Related Processes 5
ScottK Surface Finish on machined brass (or other metals)- Attribute or Variable inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M Brass, Bronze & Copper. Will their chips or powder be harmful to CNC Machines? Manufacturing and Related Processes 4
H Tapping Brass Inserts - Taps breaking too frequently Manufacturing and Related Processes 12
ScottK Detecting non-visible defects in machined brass - Where to start? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
M Casting defect in brass gravity die casting - Manufacturer of taps, faucets Manufacturing and Related Processes 5
A Chrome burning and yellowness in chrome bath - Electroplating of brass Manufacturing and Related Processes 3
F Who knows DIN 1755 standard tolerance for brass tubes? Various Other Specifications, Standards, and related Requirements 0
B Are Brass weights obsolete? Should they be replaced by Steel weights? General Measurement Device and Calibration Topics 7
D Exclusion 4.2.3 Medical Device File ISO 13485:2016 - Medical Device Quality Management Systems 5
M Lifetime of medical device EU Medical Device Regulations 5
M UDI IVD Medical Device Class III US Food and Drug Administration (FDA) 0
E How to risk assess tooling? For a medical device and is it needed??? Manufacturing and Related Processes 2
P Definition of "Standalone" medical device Other Medical Device Regulations World-Wide 5
B Spare parts of medical device need CE mark? EU Medical Device Regulations 0
R EU MDR Article 22 applicability of medical device with components. EU Medical Device Regulations 4
M Medical Device AE Reporting SOP Medical Device and FDA Regulations and Standards News 0
M Class Exempt Medical Device Recall Question US Food and Drug Administration (FDA) 3
P Requirements for Exporting Medical Devices to Libya Other Medical Device Regulations World-Wide 2
B Technical Documentation for a medical device accessory Medical Device and FDA Regulations and Standards News 6
T Peru Veterinary Medical Devices Other Medical Device Regulations World-Wide 0
S Assembling technical file for a medical device ISO 13485:2016 - Medical Device Quality Management Systems 1
I Request for information regarding remote medical monitoring software (its technical documentation and the IUD system) IEC 62304 - Medical Device Software Life Cycle Processes 2
H Medical Devices Regulatory Intelligence for International Markets ISO 13485:2016 - Medical Device Quality Management Systems 1
K Class I Medical Device Registration EU Medical Device Regulations 11
V Retrospective validation medical devices Qualification and Validation (including 21 CFR Part 11) 7
K 2021/2226 on Electronic Instructions for Use (IFU) for medical devices Article 22 Packs EU Medical Device Regulations 1
B Telemedicine as a Medical Device EU Medical Device Regulations 4
S Definition of disease as per medical device defintion EU Medical Device Regulations 14
Q Class I Medical Device with measuring function (UK MDR 2002 / MDD) UK Medical Device Regulations 3
G No new regulations in Austria medical device register after 26th Mai, 2022 EU Medical Device Regulations 0
A What activities are included in the action of marketing you medical device in U.S.? Medical Device and FDA Regulations and Standards News 1
M CE marked medical device - do they need UKAS certified calibration provider ISO 17025 related Discussions 4
C Is there a definition of accessories for medical devices in China? China Medical Device Regulations 1
C Is there a list of products or classifications subject to medical device regulations in El Salvador? Other Medical Device Regulations World-Wide 0
R Class II Active Medical Device SYSTEMS and COMPONENTS Canada Medical Device Regulations 2
B Rework of a medical device EU regulations EU Medical Device Regulations 5
R Interesting Discussion Chapter 7.5 of ISO 13485 for manufacturers of mobile medical applications ISO 13485:2016 - Medical Device Quality Management Systems 4
S Drawing Requirements for Catalog Items (Class II Medical Device) US Food and Drug Administration (FDA) 3
A Registration of medical devices in Greece EU Medical Device Regulations 0
V ADDING NEW MEDICAL DEVICE / Product, WHEATHER THIS AFFECTS EXISTING ISO 13485 CERTIFICATION? ISO 13485:2016 - Medical Device Quality Management Systems 4
I Customer Feedback Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 6
C Regulatory Affairs in a start-up medical device company Career and Occupation Discussions 1
L Non Applicability of Clauses in ISO13485 for Medical Devices Medical Device and FDA Regulations and Standards News 4
M Medical Devices - DFM Medical Device and FDA Regulations and Standards News 5
