BS EN 62304 - Medical-Relevant Data C.5 - Definition of
DanMann
Does anyone have a definition of "Medical-Relevant Data" as it is used in BS EN 62304?
C.5 of BS EN 62304 says that IVDs that provide "Medical-Relevant Data" and where the software can impact the "Medical-Relevant Data" must follow IEC 62304, but otherwise it is not mandatory (unless I' misreading it).
My company makes instruments for pathology labs to process tissue samples, so no data is provided by the instruments, but the instruments can process the samples poorly and so lead to mis-diagnosis through incorrect performance of the software that runs the instruments.
yodon
I don't have the BS EN version but my :2015 version doesn't have that language. Can you provide a snippet? My version (where I believe this discussion originates around - correct me if I'm wrong) says:
...(if) failure caused by the software which results in an unwanted change of medical data (measuring results), IEC 62304 must be taken into account.
I believe what they're intending is that if the software contributes to the (in your case) possibility of mis-diagnosis, you should apply 62304.
DanMann
In BS EN 62304:2006+A1:2015 Annex C.5 (Relationship to IEC 61010-1) says "If laboratory equipment is used as IVD equipment, the measured results obtained must be evaluated in accordance with medical criteria. The application of ISO 14971 is required for risk management. If such products also contain software that can lead to a hazardous situation, for example failure caused by the software which results in an unwanted change of medical data (measuring results), IEC 62304 must be taken into account. " However, the instruments don't provide any medical data, they only process the tissue samples for analysis by a clinician.
There's a flow chart underneath within this section; the only path leading to the use of 62304 is:
Identify known and foreseeable risks.
Is the hazard covered by relevant safety standards? If No:
Does the device provide medical-relevant data? If No, no route leads to 62304. If yes:
Use ISO 14971 for risk management
Does software have impact on the medical data? If No, no route leads to 62304. If yes:
Use of procedures to verify the data? If Yes, no route leads to 62304. If no:
Use IEC 62304.
My argument would be that the instruments don't provide any medical-relevant data (so 62304 does not apply), but I was hoping there was a definition of the term somewhere so I could ensure my understanding of this term.
yodon
Compliance to standards is always voluntary. Are you looking for a way to not have to comply with 62304? Is there anything you feel is particularly onerous with the standard? If you conclude that there can be no harm from your software then it falls into Class A which is a pretty lightweight process.
Tidge
May I challenge one of the statements?
However, the instruments don't provide any medical data, they only process the tissue samples for analysis by a clinician."
It is conceivable that the mis-processing of the samples could require that another sample be acquired, or that treatment is delayed. There is a spectrum of different harms that accompany 'acquisition of tissue samples', including nasal swabs, lumpectomy, spinal tap. The manufacturer will have to decide the scale of the severity of the potential harms; some may go to eleven. (sorry, I couldn't resist).
P SOUP anomaly evaluation for MMA (Mobile Medical Application) IEC 62304 clause 7.1.3 IEC 62304 - Medical Device Software Life Cycle Processes 6
J Implementing EN 62304:2006 on existing and proven medical devices IEC 62304 - Medical Device Software Life Cycle Processes 6
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
C Software for Medical Devices - Requirements Content for compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
H ISO 14971 vs. IEC 62304 vs. 98/79/EC vs. ISO 13485 (Software Medical Device) ISO 14971 - Medical Device Risk Management 1
M IEC 62304, ISO 14971 and FDA Medical Device SW Guidance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
K ISO 14971 and IEC 62304 - Medical Device Software House ISO 14971 - Medical Device Risk Management 9
R IEC 62304 - Medical Device Wi-Fi Radio Requirements IEC 62304 - Medical Device Software Life Cycle Processes 5
A Requirements for Software to be CE Mark Compliant - IEC 62304 Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 14
M Applying EN 62304 - Medical Device Software Architecture - Level of Detail IEC 62304 - Medical Device Software Life Cycle Processes 21
S IEC 62304 Clause 6. Medical Device Software Maintenance Plan IEC 62304 - Medical Device Software Life Cycle Processes 7
Q ISO 62304 (Medical Device Software Development) Verification Requirements IEC 62304 - Medical Device Software Life Cycle Processes 1
M Software Toolkit for Medical Imaging - Need to claim conformance to EN 62304? IEC 62304 - Medical Device Software Life Cycle Processes 12
K ISO 62304 Software Risk Management and Medical Device Class IEC 62304 - Medical Device Software Life Cycle Processes 5
S One function, many devices? IEC 62304 and Medical Device Imaging Software IEC 62304 - Medical Device Software Life Cycle Processes 9
E ISO 62304 and Validation of Medical Device Software Tools IEC 62304 - Medical Device Software Life Cycle Processes 17
sagai Process Model for IEC 62304 - Medical Device Software Life Cycle IEC 62304 - Medical Device Software Life Cycle Processes 4
T IEC 62304:2006: Medical device software SDLC- CE Vs. Fda 510(k) submission IEC 62304 - Medical Device Software Life Cycle Processes 16
I Software Design SOP to ISO 62304 (Software life cycle for Medical Device) IEC 62304 - Medical Device Software Life Cycle Processes 3
K Medical Device Software - Design Outputs? ISO 90003 and ISO 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
Q 93/42/EEC Class I Medical Device Weigh Scale - Class A under EN 62304? IEC 62304 - Medical Device Software Life Cycle Processes 15
A Introduction of EN 62304 - Life Cycle Requirements for Medical Device Software. IEC 62304 - Medical Device Software Life Cycle Processes 43
W IEC 62304:2006 Medical device software - Software life cycle processes - Issued IEC 62304 - Medical Device Software Life Cycle Processes 10
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
A IEC 62304 safety classification, External Controls and off-label use related risks IEC 62304 - Medical Device Software Life Cycle Processes 5
S IEC 62304 software costs and time Medical Device and FDA Regulations and Standards News 3
S IEC 62304 - Software verification cost IEC 62304 - Medical Device Software Life Cycle Processes 3
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
K IEC 62304 - Functional and performance requirements for SOUP items IEC 62304 - Medical Device Software Life Cycle Processes 2
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
D IEC 62304 Risk Classification - With and without hardware control IEC 62304 - Medical Device Software Life Cycle Processes 2
M IEC 62304 Class A Project IEC 62304 - Medical Device Software Life Cycle Processes 15
B Clause 5.1.12 of Technical Standard IEC 62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
P IEC 62304 - evaluation of integration and system testing IEC 62304 - Medical Device Software Life Cycle Processes 4
P Risk acceptability alignment between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 6
D Required Checklist Showing Compliance to IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 11
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
S Relationship between IEC 62304 problem resolution and ISO 13485 IEC 62304 - Medical Device Software Life Cycle Processes 8
P IEC 62304:2006 A1:2015 - Software from the early 1990s IEC 62304 - Medical Device Software Life Cycle Processes 4
B IEC 62304:2015 vs IEC 62304:2006 + AMD1 IEC 62304 - Medical Device Software Life Cycle Processes 4
F IEC 62304 - Segregation and communication between software items IEC 62304 - Medical Device Software Life Cycle Processes 1
B Class IIB Device - IEC 62304 Software Classification IEC 62304 - Medical Device Software Life Cycle Processes 13
B IEC 62304 - Update Checklist IEC 62304 - Medical Device Software Life Cycle Processes 2
L Connection between IEC 62304 and Chapter 14 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M IEC 62304 - Develop an Architecture for the Interfaces of Software Items IEC 62304 - Medical Device Software Life Cycle Processes 8
