Building an OEE System to our Production Lines - New concepts to me
Ramizz
Hi all,
I am doing a study to help in building an OEE system to our production lines. I have downloaded many OEE materials and it seems that it's easier than what I thought.
The funny thing is that I am stuck with some simple concepts that I couldn't find a definition from any of the materials. These include:
1- Line efficiency (is it the performance or the availability part of the OEE, or maybe both)
2- Line effectiveness
3- Actual line capacity
4- Theoritical line capacity
5- Utilization or line utilization?
Could you please tell me the definition and/or the benefit of the above?
Thank you
Ramizz
Thank you Somashekar.
I still need to know the definition of those terms or at least their formulas (mainly the line efficiency, effectiveness, utilization and productivity).
We are developing an OEE calculator and the above listed are the missing items.
Please have a look at the attached image for the OEE calculator which would be the initial stage for having an OEE system for our production lines.
Note: Don't worry about the numbers because they're unreal.
Chennaiite
Never-say-die
In your example:
OEE = Availability * Performance * Quality
Availability = (Total time - planned down time - Breakdown loss )/(Total time - planned down time), which is (365)/(480) i.e 76%
Performance = Actual no. of cans produced/(Theoretical can that could be produced in 365 min) with theoretical cycle time 2250 cans/min
Hence, Performance = (346320)/(2250*365) i.e 42%
Quality = Total good Cans/Total cans produced, which is 1 - (17777/346320) i.e 94.9%
With that, OEE = 30% approx.
For the definitions/formulae you needed, as far as my understanding goes..
Line Efficiency = Performance considering total time i.e 480 min.
Utilization = (Total time - planned down time - Breakdown loss )/(Total time)
Hope it helps to some extent.
Ramizz
Thank you very much Chennaiite.
So is it true in the real world that:
1- Line utilization = (Total time - planned down time - Breakdown loss )/(Total time)
2- Line efficiency = Total production / line capacity
Or does they vary from business to business or there is no fixed way to calculate them?
Thx.
Chennaiite
Never-say-die
Thx.
I have come across different approach for calculating OEE, but the concept is expected to remain intact.
Ramizz
I have another question:
What is the difference between the Capacity Utilization and the Line efficiency?
Chennaiite
Never-say-die
Normally,
Utilization is the number of hours a facility is productive against the theoretical hours available. Like, in a given day, theoretically we have 24 hrs. But if a machine was in operation for only 12 hrs and rest of the hrs were not utilized on account of say, Scheduled stoppage, Breakdown, Material unavailability, etc, Utilization is 50% (12/24).
For Line Efficiency, lets consider the same hypothetical case above. Out of productive 12 hrs, say, the theoretically expected production is 1000 nos, but if the actual is 800 nos, Machine efficiency is 80% (800/1000)
P
palmer
Hi all,
There are other threads in this topic section that have debated this question. I think the answer lies with who is viewing this material? If it is for the people performing the work on the line it should be performance. They understand this. Under availability, are you wanting 24/7/365 numbers or actual shifts and days worked? I personally don't care for 24/7/365 unless your operation runs like that. The numbers that come from that are misunderstood by most who look at them. For instance, we are taught to strive for 100%. Unless you run 24/7/365 you will NEVER achieve this number. That is disheartening to those who don't view it the way the numbers were meant to be viewed.
See #1. What do YOU want from this number? Then use that for this question
See #1. Depending on what you want to use for capacity (24/7/365) or actual hours during a normal work week. Then do you base it on highest output achieved or an average. It should be an average for accurate predictions and forecasting.
See #1. (again) This probably should be based on 24/7/365 since it is theoretical along with the highest output achieved or calculated output. It doesn't mean that it will be met under normal circumstances. I have had to adjust #'s in the past that came up one way through calculation but NEVER met when actually produced.
I'm not sure on this one. I've never used it.
Thank you
Most of the questions depend on your answer to #1. Once that is defined you can make your answers for the other questions.
Good luck.
P
pthareja
Capacity Utilization = actual production/ rated plant capacity
e.g. some Fertiliser companies in India were working at a capacity utilisation of more than 100 % (say 125 %, due to the restrictions on profit retention, applicable only till 100%, necessitated due to price control on agricultural produce.)
Line efficiency? = the production efficiency of a line (output/ input)
A CDRH Learn and DICE for Building a QMS 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
B Building my own measurement equipment General Measurement Device and Calibration Topics 3
A Building up a global quality management system ISO 13485:2016 - Medical Device Quality Management Systems 2
A Building up a global quality management system 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
JAMESH Building a "Lean" Job Shop Training Program Training - Internal, External, Online and Distance Learning 0
DuncanGibbons FAA's Building Block approach to certification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
John Broomfield Informational Chartered Institute of Building - Code on Quality Management Service Industry Specific Topics 2
J Facilities - Placing our assembly group into a separate building ISO 13485:2016 - Medical Device Quality Management Systems 8
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A Process moved to new building - Now we are in trouble IATF 16949 - Automotive Quality Systems Standard 8
M Building Production / Manufacturing Facility for Class 2 Medical Device US Food and Drug Administration (FDA) 1
H Two Business Units Combined in the same Building ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L Building your own Leakage Current Tester IEC60990 Other US Medical Device Regulations 4
C Acceleration Calculation - Building Vibration Requirements Misc. Quality Assurance and Business Systems Related Topics 3
R How much Protective Current Rating of Building Branch Circuit should be considered? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Building Heavy Pollution Factory next to Medical Device Factory (ISO 13485) ISO 13485:2016 - Medical Device Quality Management Systems 6
S Building and Warehouse requirements of OHSAS 18001 Occupational Health & Safety Management Standards 8
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
M System Building - What are the key steps? Quality Manager and Management Related Issues 2
M Building an AS9100 QMS (Quality Management System) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
B Building a Class 10,000 Clean Room Manufacturing and Related Processes 2
P Specifying the building of a new Calibration Laboratory General Measurement Device and Calibration Topics 6
P Heavy Manufacturing Supplier QA - Building Units at a Supplier's Facility Supplier Quality Assurance and other Supplier Issues 1
Marc Green Building: A Real Estate Revolution? University Of Michigan Banks On LEED Sustainability, Green Initiatives and Ecology 1
E Building a Calibration Room Test Bench - Finding components, test leads, etc. General Measurement Device and Calibration Topics 8
J Building the QMS (Quality Management System): Getting Started Document Control Systems, Procedures, Forms and Templates 16
T Inspection Records for a Building Contracting Firm Service Industry Specific Topics 1
B Get design from outside. Is it an outsourced process? Ship Building ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Customer Care - Building relationships to acquire, satisfy and retain customers Customer and Company Specific Requirements 2
Marc World's largest building struck by lightning - The Burj Khalifa World News 3
DanteCaspian Recommended Andons? Building 3 light-4 light andons, with or without sound Lean in Manufacturing and Service Industries 8
C Long Term Risk of Building without full set of Released Drawings Design and Development of Products and Processes 2
P Quality control system in building sites - Construction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Building a Database for Equipment Failures Document Control Systems, Procedures, Forms and Templates 9
hogheavenfarm Extent of certification - Companies sharing manufacturing space in a building ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Leak Test - Building a master pump to calibrate pump tester Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Is 6 sigma suitable for ship building where the nature of work is non repetitive? Six Sigma 12
Antonio Vieira Requirement 7.3 Exclusion - Building Construction Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Y Outdoor and Indoor Team Building Program Suggestions Training - Internal, External, Online and Distance Learning 1
J Product Realization Plant Layout - Moving to a Larger Building - Need info Manufacturing and Related Processes 7
B PFMEA Risk Assessment - Transfer of Production to a New Building (Relocation) FMEA and Control Plans 9
H How to Start Building New Management System for OHSAS 18001 and to Start Implementing Occupational Health & Safety Management Standards 10
M Defining the Problem and Building Experience - For Discussion ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Building a Balanced Scorecard The Reading Room 11
S Visual Inspection Variation - What can we do? Building slot machines Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Quality Plan in a Service Company - Civil engineering service - Building construction Service Industry Specific Topics 4
C Building a Home and Cost of Poor Quality Coffee Break and Water Cooler Discussions 14
M What are all the possible building blocks or inputs for a process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Y ISO applied Information - Building the organization effectively ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Y Team Building Exercise - Training that boosts group motivation level Misc. Quality Assurance and Business Systems Related Topics 2
