Bulk material vendor (supplier) change - PPAP resubmission? SAE J403 grade 1020 steel
Matts
Typically does a vendor (supplier) change dictate a re-submission on our behalf for the part/component?
The bulk material in this case is SAE J403 grade 1020 steel. The new vendor will produce the steel to meet the same material requirements as the original vendor (in this case chemical requirements).
When we notified our customer, they initially stated we could not change vendors, then stated if we wanted to, we would need to submit to them a level 4 PPAP for the drive shaft component; however they have not indicated what customer difined requirements would be requested above and beyond the level 3 PPAP.
We counter offered a level 2 including a bulk material test report, and a final part test report (including mechanical properties which is part of normal supply). We explained that our process was not changing and that the bulk material for all intense purposes was not changing. By providing the test report data it could be easily determined that the product supplied using the new steel vendor met their requirements.
The customer has rejected this offer and re-stated a level 4 PPAP with customer requirements TBD.
I realize that we are obligated to supply the customer with whatever PPAP requests they have, but I wonder if any one here has an opinion/suggestion how we may better make our case to supply only a level 2 PPAP?
You are getting hung up on the different levels, apparently thinking that this will lessen the work. PPAP requires that you perform ALL of the requirements REGARDLESS of LEVEL and keep them on file. The level only indicates what portion of that actually gets sent to the customer. The workload is the same regardless of the level, so you will not accomplish anything by arguing with the customer (other than irritating them).
Howard Atkins
Forum Administrator
:agree1:
This is the main message that we have been trying to explain all the time.
The requirement of PPAP is to perform all of the actions, the level only explains where the documents are filed
Matts
Thanks guys. There is a perception here that submission level = amount of work required (elements that need updating). I often hear "same as except...", but you're saying that isn't acceptable and I agree. I suppose a long time ago it was determined to pull the "same as except..." and because we didn't get caught, it has become the normal course of PPAP updating:mg:
Thanks again - I will discuss further with the persons responsible for PPAP submissions here.
Marc
Fully vaccinated are you?
I'll chime in here in saying that many times a reduced PPAP (as in testing done, etc.) is sometimes acceptable. It depends upon what is changed and the effect it will have on a product.
For example, take a change in paint supplier - Often the only testing that needs to be done is that related to the paint (such as salt spray or other 'durability' testing). So, in this case the only 'work' to be done is durability testing of the paint. In the case I am relating here, I got approval from the customer and all they wanted was results of the new testing.
The first thing I used to do was contact the customer and explain what I wanted to do, what my plan was and get their approval. Most of the time I have been successful in getting performance of a 'subset' of the original complete PPAP approved rather than to go through what is essentially the entire PPAP process. ***Be ready to discuss known and predicted effects of the change on the product***
As Miner pointed out the submission LEVEL is another aspect of submission which is totally unrelated to 'how much work has to be done'.
My point here is not to disput the others who answered in this thread, but rather to add to them and to add this: Before you do anything, have a plan, go over it with the customer, and go from there. But I will also add, remember many times customers will ask for more than they need. Try not to do more than you need to with respect to the known and predicted effects of the change on the product.
Out of curiosity, and to better answer, what do you plan on actually doing?
Matts
When I stated,
There is a perception here that...
The "here" was in reference to my place of employment.
We will again attempt to convince customer that a bulk material vendor change (supplying the same steel grade) does not require a re-PPAP submission per AIAG (Table I.3.2 third addition). We would like to forward a new warrant along with a bulk material test report (showing conformance to the print material callout) and to forward our final part test report (showing conformance to the print callout requirements). Hopefully similar to your paint customer, they will accept.
martin elliott
Still confused
I have been lurking on this thread and am still a little lost as I cant find the shall.
Looking at the tables 1.3.1 and 1.3.2 and 1.3.3 Customer notification and submission requirements.
If you change bulk material supplier for a sub-part which is not designed or specified by the customer and under your own design responsibility/control, but is subsequently used within a final product, and finally that change does NOT effect fit, form or function (i.e. bought to same national spectification), do you still have to notify customer?
Martin
Older but no wiser.
S Electronic (.xls or other) Bulk Material Checklist wanted APQP and PPAP 1
C PPAP Submissions for Thermoplastic Resins (Bulk Material) APQP and PPAP 3
G TS 16949 applicability for Bulk Material Product IATF 16949 - Automotive Quality Systems Standard 25
P Bulk Material Requirements Checklist to send along with my PPAP APQP and PPAP 2
D Bulk Material Supplier Control Plans APQP and PPAP 2
M For Bulk Material (eg. paint), are there any guidelines for Ford PPAP Requirements? APQP and PPAP 1
N Can I get a PPAP sample of Bulk Material (Plastic Resin)? APQP and PPAP 2
J We anneal aluminum tube (tier 2, bulk material) - Does CQI-9 apply to us? IATF 16949 - Automotive Quality Systems Standard 4
A Are Steel & Resin Suppliers Bulk Material Suppliers - TS 16949 PPAP APQP and PPAP 6
O Bulk Material PPAP - Design Matrix instead of a normal Design, Production FMEA APQP and PPAP 3
G Setting up realistic Quality Objectives - Bulk Material Handling Quality Manager and Management Related Issues 4
P Bulk Material PPAP (Resin Suppliers) APQP and PPAP 3
G Bulk Material Sample Standard Retention APQP and PPAP 2
R Bulk Material PPAP for PCB shop? What would be considered as bulk material? APQP and PPAP 5
G What is robust threshold range level? I.2.2.15 Bulk Material (Ap - F) APQP and PPAP 1
W DFMEA (Design FMEA) for Bulk Material - Resin for Plastic Injection Moulding FMEA and Control Plans 1
R Steel Slitting (coils) applicable to Bulk Material PPAP? APQP and PPAP 7
J Premium Freight for Bulk Material QS-9000 - American Automotive Manufacturers Standard 1
J Premium Freight for Bulk Material Misc. Quality Assurance and Business Systems Related Topics 1
S Strategies for reducing Sampling on incoming bulk material - low volume, ingots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
F SPC/Sampling on Bulk Material (Continuous Nonwoven process - total weight) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Are Polyurethane Foam Rolls Bulk Material? QS-9000 - American Automotive Manufacturers Standard 3
J Definition Bulk Material - What is bulk material? Coil processing plant Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 25
S Tips on Stat. Techniques in Bulk Material Process?Reduction of alumina to Aluminium Statistical Analysis Tools, Techniques and SPC 2
L Is BMAP (Bulk Material Approval Process) like PPAP? APQP and PPAP 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
U Run & rate for bulk materials IATF 16949 - Automotive Quality Systems Standard 6
S The perils of Bulk Packaging Customer Complaints 5
S Is FDA Establishment Registration for Bulk packaging Contract Manufacturers ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Environmental Monitoring for Biopharmaceutical Manufacturing of Bulk Drug Substances Other ISO and International Standards and European Regulations 1
J Canada Bulk Packaging and IFU requirements for Class IIa and IIb Medical Devices Canada Medical Device Regulations 2
B Bulk Materials (Lead {Pb} Alloys) PPAP Requirements APQP and PPAP 5
D How is transport of Dangerous Goods (limited quantity) regulated for Bulk Transport? RoHS, REACH, ELV, IMDS and Restricted Substances 9
D Sample Sizes for 'Bulk' Fluids/ Materials (Polymer Synthesis Process) Design and Development of Products and Processes 1
0 Sample divider for PET flake bulk samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Is AQL sampling plans applicable for Bulk Pharmaceutical Manufacturing (API)? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
S Batch Traceability for Bulk Materials which are mixed in the Storage Tank IATF 16949 - Automotive Quality Systems Standard 6
Q Level of PPAP - Bulk Chemicals Supplier Requirements APQP and PPAP 2
C ISO 27001 and Bulk Email Policy - Your Thoughts, Please IEC 27001 - Information Security Management Systems (ISMS) 3
N Re-Packaging and Re-Labeling Bulk Lots of Class II Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Incoming Inspection AQL Sampling of Bulk Textiles AQL - Acceptable Quality Level 3
S Gamma Sterilization: Change in Bulk Density vs. Revalidation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Gage R&R procedure for Bulk Chemicals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Acceptance Sampling for Bulk Materials - Anyone knowledgeable about ISO 10725? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B Unregistered Bulk Scrap Metal Suppliers - Do they need to be ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 10
A Calculating PPM for bulk-type product Statistical Analysis Tools, Techniques and SPC 1
C Bulk Materials PPAP - Is resubmission needed at line change APQP and PPAP 10
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
P Raw materials as bulk materials (polymer, adhesive, etc) for PPAP IATF 16949 - Automotive Quality Systems Standard 1
P Small parts trouble Kanban - Problems with the common small/bulk parts Lean in Manufacturing and Service Industries 8
