Bullet Points vs Numbered lists
MissTSmith
I am updating some SOPs and have a question on numbering for the Reference Documents and Record/Templates sections
My documents are not standardized (bullet points vs numbering) so not sure which is okay or if it is just personal preference..;)
6.0 Reference Documents
  • 7600-0011 - WI - Supplier Corrective Action Requests,
  • 7600-0009 - WI - Receiving
vs
6.1 7600-0011 - WI - Supplier Corrective Action Requests,
6.2 7600-0009 - WI - Receiving
Thanks for your thoughts on this! :cool:
yodon
My "knee jerk" was to say "personal preference" but double-check your internal procedures to be sure they don't specify any particular way (please say no, please say no :) ). If an auditor tries to raise it as an issue, politely ask them to identify the clause they believe this is violating and ask them to provide evidence why the approach is ineffective.
All that aside, consistency is usually not a bad idea.
guna8184
ISO did not specified the use bullets or numbers,
You should refer back to your procedures what was written.
I agreed to Tagin, bullets are easier to read.
monoj mon
I agree with the comments that say "bullets are easy to read". However, I would also like to say that "Numbers are easy to track and cite".
Tracking: If in the future you add/remove more reference documents, then it would be easier to "track" how many additional reference documents you have added/removed.
Citing: If you use numbering, then it would be easy for you to cite the reference inside your SOP (e.g. Ref. 6.1, Ref. 6.2 etc.).
Ajit Basrur
I am with monoj mon on this - I prefer numbering schema for easy reference and in our documents, we allow until four level of multi-numbering (for example, 6.1.1.1) after which bullets are used.
Again, its your preference and there are no specific requirement - follow what works good for your organization
somashekar
vs
Let me also pitch in ... :)
You are making a SOP. This will be used by many at various times and can be quoted for any further communication. This could remain in use long after you leave the organization, and someone else may be in charge and likely more reference documents could be added. You are also careful enough to number the main section viz 6.0.
With everything correct said in the above posts, consider the same logic of numbering even if the numbered line is a reference and not any description statement.... like.,
6.0 Reference Documents:
6.1 xxyyxx
6.2 yyzzaa
Do you like my suggestion... :cool:
(I put the 6.1 and 6.2 with a tab space but the tab did not work. Then I put the 6.1 and 6.2 with a 5 space from the left margin. It looked fine when I did, as well as when I reopened the post to edit and put this statement, but as I posted, they all aligned to the left margin... :geek:)
Randy
As a 3rd party certification auditor (and that's all I do now) my preference is whatever works for you that you can also easily manage. It doesn't have to work for me or anyone else, just for you (organization), that's the sum total of it and everything else you can toss aside.
Marc
Note the post toolbar:
My :2cents: - Bullet points are good for Powerpoint presentations, but for formal documentation I would use ordered lists for precise documents. @somashekar has the reason:
6.1 xxyyxx
6.2 yyzzaa
Yes, you can do it however you want, but that does not mean it is a "best practice". In some fields they are not even allowed in documents (e.g. Many legal documents, most aerospace documents, etc.). Can you imagine the issues which would come up if, for example, ISO documents such as ISO 9001 used bullet points instead of ordered lists?
Having written documentation of all kinds since the 1980s, I would never use bullet points in documents other than in Powerpoint Presentations or forum posts.
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
Q Using Traceable Standards - AIAG MSA Manual Chapter II, Section B, 1st bullet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
M EU Basic UDI-DI Trigger Points - When is a new Basic UDI-DI required EU Medical Device Regulations 3
V Handling open points in design reviews 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Measurement - Center Points not taken into account Using Minitab Software 3
Marc Have you Lost some "Points"? (16 August 2018) Forum News and General Information 4
ScottK Dr. Deming's most neglected Points and Diseases Philosophy, Gurus, Innovation and Evolution 13
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Insights on Transactional Ticket Audits such Parameters, Weighting Points, etc ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Poka-yoke - Key Topics and Points Problem Solving, Root Cause Fault and Failure Analysis 11
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
F Control Points in a combined BRCv6 and IFS v6 system Food Safety - ISO 22000, HACCP (21 CFR 120) 1
A Clean Test according to ISO 16232 - Some points Other ISO and International Standards and European Regulations 2
Q Number of Calibration Verification Points - Calipers, height gages, etc General Measurement Device and Calibration Topics 6
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
E What are Theo Points in a checklist document for a TS16949 Audit IATF 16949 - Automotive Quality Systems Standard 1
S ANOVA/Regression - Analyzing a Dataset which contains over 4500 Points Using Minitab Software 3
BradM Covegratulations to BevD - 15,000 Karma points and a silver star Covegratulations 15
Sidney Vianna Covegratulations to Ajit Basrur - 15,000 Karma points and a silver star Covegratulations 22
Q Implementation of 8 or 9 Points Above/Below Centerline question Statistical Analysis Tools, Techniques and SPC 8
J Proper Amount of Data Points for Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 12
J Decision Tree using for CCP (Critical Control Points) Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J Defining CCP (Critical Control Points) in a Rice Mill Plant Food Safety - ISO 22000, HACCP (21 CFR 120) 9
M Determining Critical Control Points (CCP's) in Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 4
A Medical Device Electronic Systems Design - Points to be cleared EU Medical Device Regulations 2
S Advice for preparation of ADOA and POA audits - What are the most critical points? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G Points to consider while defining the Quality Policy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
B Having trouble writing a directive (procedure) that points to the right place ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S Audit Points for Auditing a Welding Supplier General Auditing Discussions 14
Q How Demings Point 9 (of his 14 points) is related to the FDA QSR Quality Tools, Improvement and Analysis 3
S Concise History of Quality ? Major breakthroughs, key turning points etc. Misc. Quality Assurance and Business Systems Related Topics 2
T Conducting the "are all points within the control limits" test when there is no LCL? Statistical Analysis Tools, Techniques and SPC 2
Q How to Control Hold Points in Manufacturing? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Ron Rompen Assistance Needed in Calculation - How to extrapolate/calculate points on a curve Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Conclusions from weird GR&R (Gage R&R) Results - 9 of 12 points have NDC of 1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P What are the points to be discussed in a Management Review Meeting (MRM) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M What are the strong points of Fraction Nonconforming vs. Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Accounting for (Symbols for) Data Collection Points in Process Maps Quality Assurance and Compliance Software Tools and Solutions 1
K How to establish critical limit for Critical Control Points (CCPs) Food Safety - ISO 22000, HACCP (21 CFR 120) 7
C Dial Bore Gage Contact Points leaving witness/burnish marks General Measurement Device and Calibration Topics 10
B Color Individual Points on a Control Chart? Using Minitab Software 7
P Help on Treatment of Points Outside of Control Limits Statistical Analysis Tools, Techniques and SPC 4
Marc Heads Up! Win7 Can Delete All System Restore Points On Reboot After Work and Weekend Discussion Topics 1
