C=0 Zero Acceptance Number Sampling Plan - Question
V
vphan27
My question is in regards to the statistical derivation of the sample size numbers in the Zero Acceptance Number Sampling Plan table by Nicholas Squeglia. I am unable to link to the sampling table my manufacturing company is using, but it can be seen if you copy and paste the following in your internet search bar: guidebook.dcma.mil/226/tools links file/stat-sample
Can someone please elaborate on how all the sample size numbers in the table are calculated? What statistics formula is used to calculate the sample sizes for a given lot size and AQL value?
For example for a lot size between 16 to 25 and AQL of 1%, the table says a sample size of 13 should be used. My question is what statistics equation/formula is used to calculate that 13 is the appropriate sample size for this given lot size and AQL? How is this calculation performed?
I understand how to use the table, however I want to understand where the numbers come from. If someone can please provide a detailed explanation I would truly appreciate it. Thank you.
Steve Prevette
Deming Disciple
There is a similar discussion happening on the ASQ "Ask a QA Professional" board there.
I did look up a table reference there, and it appears that the very large lot size calculations correspond to a binomial distribution at a 64% level of significance.
I've found sniffs on the internet that the finite lot size calculations are based upon hypergeometric distribution. But you run into a problem that the hypergeometric can only be calculated for integers (expected number of defects). There is a claim that some form of regression was used to generate the OC curves, and determine the non-integer calculations.
Steve Prevette
Deming Disciple
So are you the "Van Phan" on the ASQ board?
The key does seem that the table is based upon a relatively low level of significance, around 70%. I assume the sample plan assumes repeated sampling over time that will increase the level of significance with time.
S Justifying the AQL for a Zero (C=0) Acceptance Plan (Medical Device) AQL - Acceptable Quality Level 6
Marc Zero Acceptance Number Sampling Plan - C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
G Has anyone heard of the Squeglia Zero (c=0) Acceptance Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L Established a c=0 "AQL" or "RQL" table AQL - Acceptable Quality Level 5
Douglas E. Purdy C=0 Sampling for Variable Characteristics Quality Manager and Management Related Issues 14
M Determining c=0 AQL numbers Misc. Quality Assurance and Business Systems Related Topics 3
R What to Report when Using C=0 Sampling Plan Supplier Quality Assurance and other Supplier Issues 15
G Sampling Plan according to SAE ARP9013 C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Definition C - What the "C" in C=0 Sample Plan means Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
M AS9100A (old revision) - Required C=0 sampling plans if sampling was used? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
WCHorn AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
A C=0 and Skip Lot Sampling Plan Relationship Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A ANSI/ASQ Z1.4 tables for C=0 - Setting up a robust Sampling Inspection Scheme Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M c=0 Acceptance Sampling Plan similar to the N. Squeglia version Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C C=0 vs. AQL MIL Standard 105 E - Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Why sample size for c=0 sampling plan reduces across the increases of AQL AQL - Acceptable Quality Level 2
L Please Explain Inspection Levels including C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q C=0 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
T How to define c=0 Reject Rates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
V C=0 vs. ANSI/ASQC Z1.4 - Part Inspection Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A What is a good lot size? We use the C=0 Sampling plans at AQL %1.0 AQL - Acceptable Quality Level 9
R My C=0 sampling failed to detect parts are out of round Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
L What does "C" in C=0 mean? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
QChas The Source of "C=0 Sampling Plans Index Values (Associated AQLS)" AQL - Acceptable Quality Level 3
C Ansi/ASQ Z1.4 C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C C=O puzzle - What protection does C=0 provide a supplier? Statistical Analysis Tools, Techniques and SPC 15
C MIL-STD-105E vs MIL-STD-1916 - Is 1916 the same as C=0? Preventive Action and Continuous Improvement 4
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Certifying a "virtual" company with zero employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Sam Lazzara Time Zero testing in med device aging studies Qualification and Validation (including 21 CFR Part 11) 3
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
WCHorn Changing Sampling Accept Number to Zero, Arbitrarily AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
F Zero to certification in 6 months! Covegratulations 5
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Can Cp and Cpk be zero? Capability, Accuracy and Stability - Processes, Machines, etc. 10
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Rounding Uncertainty to Zero on a Calibration Certificate Measurement Uncertainty (MU) 7
L What is the Cpk for Zero Defects Six Sigma 4
optomist1 Differences and Advantages of using a Zero Positional Tolerance at MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Getting Zero for GR&R Reproducibility? Using Minitab Software 5
R Zero Acceptance Sampling Plans 5th edition by Squeglia - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Zero Acceptance Number Sampling Plans for Isolated Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Minitab error: Zero or negative degrees of freedom Using Minitab Software 16
T Zero Failure Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M AQL (Acceptable Quality Level) for Zero Defects AQL - Acceptable Quality Level 13
