Calculate number of people in processes, considering cycle time/takt time = quantity of people
qualprod
Hai everybody
Could someone explain the basis to calculate number of people in processes, considering cycle time/takt time = quantity of people?
It doesn't fit in my mind how is calculated.
On the other hand, how can be possible to dimension number of people, without including person efficiency?
Is a very important issue.
Please feed me back, thanks
N
ncwalker
TAKT time is the longest a process can take to make the contracted amount. You get TAKT by dividing the time you run (like if you run two 8 hr shifts a day with no breaks, the time is 16 hrs) by the number of parts you are required to make in this time. No part of your process can be LONGER than this, or you will not make enough parts.
Lets say you have a TAKT of 5 minutes. And you have a manual paint process. What this means is, to paint your part, the operator must be able to get it done in 5 minutes. If you can add another operator (another parallel process) then each operator can take 10 minutes, the combined output must be 5.
qualprod
Thanks , but the question remains, what are the root basis to determine "crew to takt" how Many people needed for any process
Since, when cycle time is obtained, in none place was determined number of people, simply ct was obtained, but in The formula cycle time/takt time= crew , have a doubt reg arding, what is based on, who created such formula.
This formula holds for individual operations. Ncwalker’s example is this formula. A process that takes 10 minutes (cycle time) and a takt time of 5 minutes requires 10/5=2 people to meet takt time.
No person created the formula. It is basic “engineering”.
qualprod
Thanks, I can understand, your explanation as well the ncwalker viewpoint, but in lean, I have seen the next in lean manufacturing.
Cycle time/ takt time = quantity of people needed to work in any process.
E.g. seconds/seconds per piece= # of people?, Could someone clarify this?
I am confused on what your question is. you can convert minutes to seconds by dividing by 60.
qualprod
I searched on the net, And found this.
For crew to takt= cycle Time/takt Time, the reason= seconds-person/seconds, simple algebra seconds are eliminated, then have persons , But is a manual process, I wonder how to manage this issue when the time resulted of a process is a mix, person operating a machine.
What will be the results in the equation ?
Or the job is completely done by a machine?
OK, so your question was how the units cancel out to eliminate time and leave people. the effect of units is almost always a 'manual' thing as most math software doesn't take this into account. some specialized scheduling software will take units into account and requires you to enter the units for each variable.
you handle machine heavy operations in the same way. the key is understanding how many parts are made by the machines (in the same units of time as the takt time) that can be run by a single person. it will also tell you how many machines you need
N
ncwalker
First - just because you found a formula on the internet, it does not mean that it works.
First some definitions:
Machine Cycle Time : The time the machine cycles to perform the operation.
Total Cycle Time: The Machine Cycle Time PLUS the time to unload/load another part. Operator dependent.
Let's say I have a machine that has a total cycle time of 8 minutes, but a machine cycle time of 6 minutes. So on average, once the machine is done, it takes an operator 2 minutes to: acknowledge the machine has stopped, open the doors, swap out a finished part for a fresh blank, close the doors, and hit the GO button.
This means that running one machine, an operator would be busy for 2 minutes, and standing around for 6 minutes. What this means is I could add three more machines to the cell, WITHOUT adding an operator. They would be very busy running four machines.
Now TAKT time is the time required to make a part. If my TAKT time is 8 minutes, I am fine with one operator and one machine. But my customer wants to order 4 times as many parts. Well, I need 3 more machines. And my CELL TAKT time drops to 2 minutes, but my MACHINE TAKT time stays the same.
Case A and Case B in my example have different TAKT times, different cell cycle times, but the same number of operators.
You cannot determine number of operators from JUST TAKT and cycle times. It's simply not enough information.
The issue is that cycle time is for the part not the person or the machine. As you pointed out it also includes load an unload time and any other prep or inspection or data entry etc that is associated with actual part time.
There’s nothing wrong with the formula per se, it’s how you assign the correct values to the variables.
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
M Cpk - How to calculate when the number of samples is less than 30 pieces? Capability, Accuracy and Stability - Processes, Machines, etc. 7
D How to calculate the A4 constants in Median/Range control charts? Statistical Analysis Tools, Techniques and SPC 2
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
S How would you calculate this? Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 8
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
