Calculate Z-Score for Non-Normal Data - I have two set of data
U
utkarshdoshi
How do I calculate Z-score for non-normal data. I have two set of data. One is normal & other is non-normal. I have transformed the non-normal data to normal data in minitab but still not getting successful in calculating Z-score.
For normal data - I am good.
Thanks,
Darius
Re: Calculate Z-Score for non-normal data
Can you post some non-gaussian data, and what do you expect (why was your analysis wrong)?
why do you need to calculate a z score?
z scores by themselves are realtivley unhelpful - it's what you do wihthtem that matters and there are other ways of obtaining the intended answer besides using a z score.
U
utkarshdoshi
I would like to know the % probability of parts being out side of low specification. Yes - I found out another way to get the % and that is from the capability analysis. Looking at the PPM>LSL and then converting it to %. Seems to make sense. Do you agree?
absolutely not. this ONLY works with Normally disctributed processes. there are many great discussion of this issue with capability studies in this forum, my suggestion would be to perfrom a search and do some research on the issue and then come back with questons.
In the meantime if you post your data, explain the sampling plan for it and the process that created it, we can help with alternate methods of determining the % out of spec.
U
utkarshdoshi
Yes I know about the normal distribution only but what if you tranformed the data to normal distribution prior performing capability analysis. Still not valid?
Bev D is correct. Just because you can calculate a z-score, which Minitab's non-normal benchmark capability analysis will do, does not mean that you should.
The z-distribution is a standardized, normal distribution with a mean of 0 and a standard deviation of 1. By its very definition, it is not appropriate for non-normal distributions.
A better way is to fit the non-normal distribution and directly calculate the percentages from that distribution. Minitab will do this, and any decent statistical package should do the same. Minitab's non-normal capability will also provide the percentages out of tolerance.
in addition to Miner's input, I would add that the intent of capability studies is to truly understand the capability of your process. This means passively studying the variation over time: what happens as raw material lots change, operators change and set ups change? this helps us with the next step of improvign our processes and actively studying the inputs and output response. None of this can be accomplished by calculating a z score...
In our busy worlds, it can be tempting to go to a mathematical formula and calculate an answer - but that is really a non value add short cut that in the end only keeps us from understanding our processes....
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
R Sampling Plans - ISO 2859-1: 1999 - How to calculate the switching score? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A How to calculate weights for customer satisfaction score? Misc. Quality Assurance and Business Systems Related Topics 4
D How to Calculate Z Score Values Statistical Analysis Tools, Techniques and SPC 2
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
S How would you calculate this? Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 8
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
