Calculating Bias - Is this method acceptable? MSA manual page 85
darkafar
MSA manual page 85 states “…select a production part that falls in the mid-range of the production measurements and designate it as the master sample for bias analysis. Measure the part n≥10 times in the tool room, and compute the average of the n readings. Use this average as the “reference value”.
I have no measuring equipment with better sensitivity. Our workplace is in an air-conditioned clean room. I don’t know what a tool room environment is like. I presuppose our clean room environment match that of a tool room. So I asked an operator to measure one sample 10 times, calculated the average, used it as the reference value, then asked the same operator to measure the sample 15 times, and then I followed the formulates given in the manual to decide if the bias is acceptable.
I did this because I believe bias is an important factor that no reason can justifiably exclude it. I used the same operator to decide the reference value because she used the equipment best, and she usually performed the measuring.
I question is, since I used the same operator, sample, environment, method, equipment, there is no reason why the averages would be different. So the bias analysis was reduced to a ritual.
Do you think my method acceptable? If you are in my shoe, what will you do?
No. This method is not acceptable. As you say, it is an excercise in futility, with no value.
If you were evaluating the bias of a shop-floor gage, you could use your clean-room environment as the reference since it sounds better than a tool room. However, you are trying to evaluate the bias of the clean-room. Therefore, your reference needs to be from a higher standard than the clean-room.
In this situation, you really cannot use parts, but should use master standards that have been calibrated at a higher level than your lab is capable of meeting.
darkafar
But I did it in complete compliance with the MSA manual, didn't I?
The MSA manual gave an example following the statement, and my way of performing the bias analysis is an emulation of the example. The example did not mention a master standard.
If a master standard and a better equipment are both unavailable, do you think it's meaningful to do a bias analysis with my method? How to convince the customer that the bias analysi is unnecessary?
The main difference between what you did and the example in the MSA manual is that the MSA manual uses a tool room to obtain a theoretically more exact measure of the part's true dimension than that of the gage to be evaluated.
In your case, you are not doing that. You are using the same gage to assess itself. Your bias should be so close to zero as to not matter.
Do you have a better gage or an outside source available?
darkafar
No. That's my problem. I guess what you mean is that the process to establish the "reference value" have to be different to the normal measuring process, so that the difference can be differentiated.
It really doesn't matter whether it's a better tool room or a better operator, as long as there is difference.
So that when the difference can not be established, it would be meaningless to do the bias analysis unless we want to cheat an overdemanding customer.
Am I right?
Exactly correct.
That was why I sugested using a calibrated standard of a high enough class. While it is not the product, the "true" value has been established by a qualified lab.
martin elliott
I agree with Miner, you cannot assess the bias of a measurement system against itself as a reference.
If its any value at all, my practice has been, for example, when determining the bias on a digital caliper (resolution 0.01 Accuracy 0.02), was to measure the standard part(s) in a more controlled enviroment using digital Micrometers (resolution 0.001 Accuracy 0.003).
If you cannot achieve this youself, you are left perhaps with an exercise of using an independant approved calibration laboratory that can measure the part to the required additional resolution/accuracy to make sense of the bias evaluation.
Having said all that, and not knowing your situation, are you convinced bias is an issue here beyond that reasonably expected to be covered by normal regular calibration of the instrument. If your problem is justifing such calibration periods then stability might be a better measure to consider
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
A Calculating Carbon Footprint in the Organization Miscellaneous Environmental Standards and EMS Related Discussions 2
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
K Calculating Heat Dissipation Manufacturing and Related Processes 1
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
T Formulas for Calculating Coefficients for RTD / PRTD Calibration According to ITS-90 General Measurement Device and Calibration Topics 5
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Calculating Capability of Delivery Performance Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
B Please share a template for calculating Cp Cpk Document Control Systems, Procedures, Forms and Templates 3
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Calculating MTBF (Mean Time Between Failures) for the whole Production Unit Reliability Analysis - Predictions, Testing and Standards 2
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
