Hello Mr. Atul,
The readings taken were from a machining operation on multi-spindle screw machine and the measuring instrument used was 0.001 Micrometer. The dia 6.75 / 6.45 is maintained by a roughing using dovetail form tool and finishing using circular size tool. We suspect that the sizing operation contributes to this non-normal distribution but the advantage of using this tool is that we can get a very good consistency in the job.
You had mentioned about some "transform" that could be used to solve this problem. Can you please elaborate and also tell me what effect it has on the formula used to calculate the control limits, Cp and Cpk. Please also note that the readings are not stable when X-R chart is plotted.Can you advice me what to do?
SPC for Diameters - Parts not Perfectly round so charts are useless
Use the X-Hi/Lo chart for each spindle, and you will have a clearer idea of capability. If the data collected in this manner is found to be "normal", your process is out of control (bad spindle bearings, etc.) For the uniform distribution the results should form the sawtooth curve, and its capability = UCL-LCL/USL-LCL.
