Calculating Defect Rates
QualiTEE
Hi!
Our Sales department wants our goal rejection rate to be 2% of sales. Would 2% of cost be better?
We do already have some simple measurements in place to monitor our quality performance (none including dollars):
1) Total Closed Rejections Orders / Total Closed Accepted Orders
2) Total Rej Qty / Total Accepted Order Qty
3) Total Rej Qty / Total Qty Produced (rej qty + accepted qty)
We have a PPM calculation for option #2 above, but should that really be calculated using formula #3?
What other ways are companies monitoring and measuring quality performance?
Johnny Quality
Depends on the scope of your activities I suppose. I don't like using PPM as I believe it's a meaningless metric, especially if your products are "low volume".
I'd start with a Pareto of what your returns are and go from there.
formulas 1 and 2 are useless as rejects should be trended as a proportion - or percentage - of the total (rejected plus accepted)
ppm is not appropriate unless you actually process millions of orders and your rejection rate is substantially less than 1%.
(as a straight forward math calculation, ppm is no different than percentage - they both are trying to make a small number easier to digest. When ppm is used for denominators that are not in the millions or are 'predictions' based on small sample sizes and distributional models they are silly)
not sure about the percent of sales or cost. sales is a count right? if you did as a % of cost then you would have to convert the number of rejects to the $ figure they represent right? in any account you would still need to avoid the mistake of formula 1 and 2
QualiTEE
Would you then count part rework the same as remake, where each instance increases the total produced?
Example:
2 rework
1 remake
7 accepted
_______________
10 total
We are definitely low volume, so I agree that PPM seems silly. Our recent customer audit had recommended that measurement to us because that's what they use.
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
J Calculating Defect Rate or Percent of Rejection Manufacturing and Related Processes 4
J Calculating PPM for a Supplier on a Specific Defect - Excel .xls Spreadsheet Wanted Statistical Analysis Tools, Techniques and SPC 7
Marc Calculating Defect Rate (PPM) from a Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Calculating Risk Estimation ISO 14971 - Medical Device Risk Management 29
G Calculating Ppk for Design Verification - Variable Sampling Design and Development of Products and Processes 15
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
M True position, calculating theoretical distances General Measurement Device and Calibration Topics 0
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
A Calculating Carbon Footprint in the Organization Miscellaneous Environmental Standards and EMS Related Discussions 2
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
K Calculating Heat Dissipation Manufacturing and Related Processes 1
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
T Formulas for Calculating Coefficients for RTD / PRTD Calibration According to ITS-90 General Measurement Device and Calibration Topics 5
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Calculating Capability of Delivery Performance Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
B Please share a template for calculating Cp Cpk Document Control Systems, Procedures, Forms and Templates 3
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
