Calculating OEE Performance Measurement for a CNC Plasma Cutter
marcelbakker7
Hello everyone,
First of all thank you to everyone who has posted on this forum, its very usefull. Despite that a lot of information is on this forum I could not find a particular thing. I am doing an internship at a company wich cuts and forms sheet metal. My job is to implement TPM. One of the things I am working on now is a OEE (overall equipement effectiveness) measurement for a cnc plasma cutter. The cutter cuts different parts out of 1 piece of sheet metal.The thing is that I cant figure out a way to calculate the performance rate because every product is different. Does someone know a way to calculate the performance rate in this case?
Thanks in advance,
Marcel Bakker
marcelbakker7
Good morning Stijloor,
Thank you for your reply. Unfortunatly i can't find the awnser to my question with the search. The point is that I have no reference point to calculate the performance rate. This is because the cutter cuts different tonnages and parts every day. For example:
monday: 200 parts out of 20 pieces of metal of 20mm thick
tuesday 500 parts ouf of 40 pieces of metal of 8mm thick
The machine can cut faster on less thick metal so it can produce more parts/products with thinner plates. also the weight cant be a refference point because out of the one plate we'll cut 1 part and the other for example 20 (wich takes longer but might weigh the same).
Stijloor
Marcel,
Thanks for the additional information. I do not claim to be an expert on OEE. Today is Labor Day, many folks have the day off, but I am sure that you will get responses soon. I was just trying to "get you going." ;) I'll do some more research.
BTW, I found a calculator - ***DEAD LINK REMOVED***.
Stijloor.
marcelbakker7
Stijloor,
Thanks for trying, I appreciate the help and every bit of extra information is more than welcome. Happy labor day to you all i guess ;-)
Marcel
Hello Marcel, and welcome to the Cove :bigwave:
You may have to go for an average then.
With OEE = No. of good parts produced / No. of parts teorethically possible to produce you would need to select a timeframe long enough to even things out. I am NOT an OEE expert either though, so I would like to get a 2:nd opinion on that.
BTW, I found a calculator.
Yeah! That looks interesting. Good link: I bookmarked it right away.
/Claes
marcelbakker7
Hello Marcel, and welcome to the Cove :bigwave:You may have to go for an average then.
/Claes
Hello Claes,
Thanks for replying. I thought of taking an average too, but i'm not an OEE expert either so if anyone can confirm that it is OK to do or if anyone has another idea please do post!
@stijloor:
Thanks for the link, pretty usefull but unfortunatly I cant fill in the value "Theoretical maximum output per hour" (or if an average is OK to do, I could ofcourse fill in that...)
P
prototyper
You may have to be creative and devise another measure rather than number of parts. For example, total time spent cutting against total available time.
This could be easy to collect if the CNC cutter has software with timers.
marcelbakker7
Thanks for your reply, I thought of that too, but if you take the time spent cutting you wont catch the times when the machine is cutting on a lower speed. Cutting speed might be a possible measure point, but the machine also has a printer and 3 movable tables so you wont measure the whole machine. You can ofcourse measure all those 3, but technichaly its not possible to let the cutter log the speeds so the operator has to write it all down wich will cause more slowdown to collect the data than it will produce
Hello everyone,
Thanks in advance,
Marcel Bakker
I will see it this way ...
OEE is the time the machine is actually performing its task taken over 24x7. The premise is that unlike men, machine can work 24x7. Now we have two other things, the setup time and the down time. Once you have the OEE calculated over a spread time, then to improve upon it several steps can be initiated, which primarily aims at eliminating the various causes of the down time, reducing the setup time and then optimizing the working time. It is in this optimizing exercise that you apply the principles of manufacturing technology.
A Calculating Risk Estimation ISO 14971 - Medical Device Risk Management 29
G Calculating Ppk for Design Verification - Variable Sampling Design and Development of Products and Processes 15
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
M True position, calculating theoretical distances General Measurement Device and Calibration Topics 0
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
A Calculating Carbon Footprint in the Organization Miscellaneous Environmental Standards and EMS Related Discussions 2
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
K Calculating Heat Dissipation Manufacturing and Related Processes 1
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
T Formulas for Calculating Coefficients for RTD / PRTD Calibration According to ITS-90 General Measurement Device and Calibration Topics 5
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Calculating Capability of Delivery Performance Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
B Please share a template for calculating Cp Cpk Document Control Systems, Procedures, Forms and Templates 3
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
