Calculating OEE Performance Measurement for a CNC Plasma Cutter
marcelbakker7
#11
I will see it this way ...
OEE is the time the machine is actually performing its task taken over 24x7. The premise is that unlike men, machine can work 24x7. Now we have two other things, the setup time and the down time. Once you have the OEE calculated over a spread time, then to improve upon it several steps can be initiated, which primarily aims at eliminating the various causes of the down time, reducing the setup time and then optimizing the working time. It is in this optimizing exercise that you apply the principles of manufacturing technology.
Thank you for your reply. Fortunatly most of the problems of the machine i'm going to measure are in the availability. Ofcourse i could leave the whole performance rate out of the measurement but that wouldn't be according to the 'rules' of the OEE principle
P
prototyper
#12
Sometimes you can't tick all of the boxes and comply with the "rules".
How can you come up with meaningful measureable data on your process?
Look at what you can measure. You can record all downtime, make sure you capture all of the main reasons such as waiting for parts from the previous operation, waiting for the next operation to finish, breakdown of the tables, breakdown of the laser, etc.
From this you can calculate the machine uptime or availability.
You can monitor the in cell efficiency as a seperate issue i.e. the optimum laser cutting speeds, etc.
marcelbakker7
#13
Thought i'd give you guys an update on the problem, we did find a way to calculate the performance. Every draw file has 3 distances wich the cutter travels: Printing distance, Cutting distance an moving distance. For every 3 theres a theoretical maximumspeed so you can measure the performance. Unfortunatly this turned out to be too much work for the operators and ourself and we also didn't think there would be much problems with that piece of the plasma cutter.
So we came up with another sollution: Move some of the time measured with availability to performance. example:
Availability = (Total time - failure time) / total time
Performance = ((total time - failure time) - performance loss) / (total time - failure time)
under performance loss we calculate the times that there is no material, no crane to load, operator not ready to cut etc. So every time loss when the machine is able to operate.
Maybe not the best sollution, but it gives the numbers we need.
Stijloor
#15
Thank you Marcel!
Could you keep us up to date on your progress?
Some may be curious about what you will do with the actual data and subsequent actions.
Stijloor.
marcelbakker7
#16
Thank you Marcel!
Stijloor.
Sure, no problem. As soon as i've got some usefull information i'll post it:yes:
P
phil1234
#17
Hi Marcel
I am the Production Coordinator in a factory which has 5 cnc lasers and 1 cnc plasma cutter. We have manipulated the calculation of OEE to suit our plant - it is nowhere set in stone - make it work for your situation! We basically exclude performance/efficiency and only concentrate on machine utilisation and quality. We do random checks throughout all shifts on the feedrates the machines are running at and compare these to budgets; the figures are kept on a spreadsheet for further analysis and future budget setting. We obviously keep track of the Dollar amount each machine produces daily - you can substitute this for your performance/efficiency component if you want.
PS. See my other posts re OEE and machine breakdowns.
Cheers.
marcelbakker7
#18
Hi Marcel
Cheers.
Thank you very much for your reply. We thought too much in OEE standards too and thats why we also decided to manipulate OEE in such a way that it brings the results we want. basicly its the opposite of what you are doing, we're concentrating on performance/efficiency by measuring all the reasons why the machine isn't cutting. As mentioned earlier I will post some results as soon as we've got a good method to measure it. Were now measuring with just a piece of paper and a pen to see what reasons of inefficiency there are now so we can come up with a good measuring tool for the long term later.
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
A Calculating Carbon Footprint in the Organization Miscellaneous Environmental Standards and EMS Related Discussions 2
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
K Calculating Heat Dissipation Manufacturing and Related Processes 1
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
T Formulas for Calculating Coefficients for RTD / PRTD Calibration According to ITS-90 General Measurement Device and Calibration Topics 5
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Calculating Capability of Delivery Performance Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
B Please share a template for calculating Cp Cpk Document Control Systems, Procedures, Forms and Templates 3
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Calculating MTBF (Mean Time Between Failures) for the whole Production Unit Reliability Analysis - Predictions, Testing and Standards 2
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
