Calculating Percentage Contribution Ratio (PCR) in Minitab
christianos
I am wondering how to calculate this in Minitab. As far as I know other software for statistics sometimes can present that contribution in a graph and give a real %.
I was trying to find it in Minitab and I am confused.
Basically, the standard formula for this is:
p% (PCR) = [Variance (F) x mean square variance error] / total sum of squares x 100%
It seems I cannot get all of the components to calculate it.
Am I doing something wrong?
I can rely on Pareto charts to see which factor has an impact but it's not giving me any "numbers"
Also, as it is seen below, Main Effects are showed together. Is there any way to see these calculations for each factor?
Analysis of Variance for Option 1 (coded units)
Source DF Seq SS Adj SS Adj MS F P
Main Effects 4 1,1104 1,1575 0,2894 1,72 0,201
2-Way Interactions 6 1,4564 1,2768 0,2128 1,27 0,333
3-Way Interactions 4 1,1022 1,1087 0,2772 1,65 0,217
4-Way Interactions 1 0,2175 0,2175 0,2175 1,29 0,274
Residual Error 14 2,3516 2,3516 0,1680
Pure Error 14 2,3516 2,3516 0,1680
Total 29 6,2382
Many of Minitab's ANOVA routines have a Results button. The Results submenu should have a box you may select that states "Display expected mean squares and variance components" That will provide the information for which you are searching.
christianos
I chose Full Table and still cannot find which number express a Contribution Ratio in %.
Maybe the only way to do that is by calculating it using the formula which I put in my 1st post? However, I am looking for a faster solution.
steelejc15425
To my knowledge, the only place that percent contribution is in the output in Minitab is in the Gage R&R studies. Are you doing one of those? The most common one in Minitab is Stat > Quality Tools > Gage Study > Gage R&R Study Crossed.
If you're not doing a Gage R&R study, but you have two or more factors, you can probably still get percent contribution from the Gage R&R analysis tools. You'll just have to know which factor is accounting for reproducibility and which is for repeatability in the output. If you have two factors, you can use Minitab 15. If you have 3 or more factors, you'll need Minitab 16 so that you can use the new Gage R&R (Expanded) tool.
I don't have enough posts to add a link, but if you don't have Minitab 16 you can download a free trial from the Minitab website.
Is that what you were looking for?
Minitab does not express it in terms of a contribution ratio (other than in the Gage R&R routine). You can use the variance components table and the formula that you posted previously to manually calculate the ratio.
christianos
I tried to calculate it using my formula from the 1st post. As it is visible I have F value (Variance). I am not sure what should I treat as a Mean value: Seq SS or Adj SS and what treat as a MEAN Square variance error and as Total sum of squares?
However, If I know that information still I do not know how to calculate contribution of each factor using that formula. The Analysis of Variance for AVERAGE Option 1 (coded units) presents only values for Main effects and interactions. I would like to know what is the contribution of each factor.
Just to make it clear I was doing L16 Full factorial design replicated two times, using two blocks. However, I've found those blocks irrelevant as a p-value was very high around 0.800
Factorial Fit: AVERAGE Option 1 versus SPEED; FEED; OPt1; OPt2
Estimated Effects and Coefficients for AVERAGE Option 1 (coded units)
Term Effect Coef SE Coef T P
Constant 6,88843 0,01274 540,78 0,000
A -0,06805 -0,03402 0,01274 -2,67 0,018
B -0,04431 -0,02215 0,01274 -1,74 0,104
C -0,09201 -0,04600 0,01274 -3,61 0,003
D -0,10069 -0,05034 0,01274 -3,95 0,001
AB 0,07706 0,03853 0,01274 3,02 0,009
AD -0,05281 -0,02641 0,01274 -2,07 0,057
AC -0,01113 -0,00556 0,01274 -0,44 0,669
BC 0,00368 0,00184 0,01274 0,14 0,887
BD -0,06132 -0,03066 0,01274 -2,41 0,030
CD 0,06673 0,03336 0,01274 2,62 0,020
ABC -0,00120 -0,00060 0,01274 -0,05 0,963
ABD 0,05989 0,02994 0,01274 2,35 0,034
BCD 0,05646 0,02823 0,01274 2,22 0,044
ACD -0,02617 -0,01309 0,01274 -1,03 0,322
ABCD -0,03578 -0,01789 0,01274 -1,40 0,182
S = 0,0679362 PRESS = *
R-Sq = 85,34% R-Sq(pred) = *% R-Sq(adj) = 69,63%
Main Effects 4 0,184235 0,161772 0,040443 8,76 0,001
2-Way Interactions 6 0,129173 0,110231 0,018372 3,98 0,016
3-Way Interactions 4 0,053604 0,056200 0,014050 3,04 0,053
4-Way Interactions 1 0,009103 0,009103 0,009103 1,97 0,182
Residual Error 14 0,064615 0,064615 0,004615
Pure Error 14 0,064615 0,064615 0,004615
Total 29 0,440729
christianos
Rather it is not I am looking for. I am doing analysis of a full factorial design. Unfortunately, I have only Minitab 15 and 4 factors in total ;/
But thank you anyway. That information might be useful in the future.
Strictly speaking a factor should be random to be able to calculate a
%contribution.
Or am I wrong on that?
No. You are not wrong, but it all depends on what use you want to make of the % Contribution.
If you want the % Contribution to be repeatable in future studies, the factors should be random. However, if you only want to assess the relative magnitude of effects for this specific study, they do not have to be random.
Total 29 0,440729
This printout does not provide the information that you need. Did you analyze this as a Taguchi experiment? The components of variation may not be an option for Taguchi. I cannot remember. You might try using GLM to obtain the components of variation.
S Calculating Standard Error for a percentage (binary question) from a sample survey Statistical Analysis Tools, Techniques and SPC 1
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
A Calculating Carbon Footprint in the Organization Miscellaneous Environmental Standards and EMS Related Discussions 2
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
K Calculating Heat Dissipation Manufacturing and Related Processes 1
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
T Formulas for Calculating Coefficients for RTD / PRTD Calibration According to ITS-90 General Measurement Device and Calibration Topics 5
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Calculating Capability of Delivery Performance Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
B Please share a template for calculating Cp Cpk Document Control Systems, Procedures, Forms and Templates 3
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Calculating MTBF (Mean Time Between Failures) for the whole Production Unit Reliability Analysis - Predictions, Testing and Standards 2
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
